Previous in Forum: The Hellcat is Fast!   Next in Forum: 1998 Sunfire 2.2L Won't Start
73 comments
Car Maintenance
02/18/2015 7:08 PM
I am in Sydney, Australia.
I have a 2007 Toyota 1.5 L Yaris.
I've been doing oil and filter changes since the car has done around 120,000 km.
I am using semi synthetic with 10w40. Spark plugs was replaced @ 139644 km.
Generally, it is a great car, but it tends to shake a bit when it's driven in the afternoon.
This has been happening for the last 6 months.
Don't seem to notice that much in the morning, but in the afternoon, after it is driven about 5 KM, and stopped at traffic lights, with gear stick on D(drive). I can feel it is shaking a lot. And, when I look at the rev gauge it is fluctuating around the 500 rpm.
And, if I put my foot on accelerator and bring the rev up, the shaking stopped.
I do oil and filter change at 5000 km interval. The car has done 150,000 km.
Any recommendations would be greatly appreciated.
User-tagged by 1 user
Re: Car maintenance
02/18/2015 7:36 PM
It's probably the front tires out of balance....do you rotate your tires regularly...?
Re: Car maintenance
02/18/2015 7:47 PM
Read the first post again. He's stopped when it's shaking.
Re: Car maintenance
02/18/2015 7:54 PM
So it's idling too low....change the air filter, and fuel filter....spray some carburetor cleaner on the throttle body...
Good Answers: 104
Re: Car maintenance
02/18/2015 7:41 PM
You might try www.yarisworld.com. First, take it somewhere (like AutoZone, Advance, or O'Reilly in the U.S.) and see if any engine codes come up. Could be dirty/fouled throttle body and several other things.
BTW, 10W40 seems pretty heavy for this little engine.
Re: Car maintenance
02/18/2015 8:29 PM
So, what grade of oil would you suggest to use?
Thanks.
Good Answers: 104
Re: Car maintenance
02/18/2015 9:53 PM
I'd use what the owner's manual says to use. Just quickly looking over the Yaris site, I think I saw 5W30, but the owner's manual is the final word. (My neighbor's new RAV4 calls for 0W20 or 5W20. 10W40 and 20W50 may not have the latest/highest/recommended API rating.)
Good Answers: 137
Re: Car maintenance
02/19/2015 4:13 AM
I agree with following the owner's manual, but I can't imagine wrong oil grade would cause the symptoms described.
Good Answers: 104
Re: Car maintenance
02/19/2015 8:28 AM
Agreed, this started as BTW .
Good Answers: 225
Re: Car maintenance
02/18/2015 7:52 PM
Driving in Sydney in the afternoon is enough to make anything shake.
That's why I live in Port Macquarie.
Good Answers: 102
Re: Car maintenance
02/19/2015 10:43 PM
Yeah, years ago I used to commute to work from the Central Coast to North Sydney.
Bumper to bumper at 120kph on the freeway in fog. Sh*t happened frequently.
I transferred to Perth.
Re: Car Maintenance
02/18/2015 8:45 PM
could be the dead cat you ran over..
Re: Car Maintenance
02/18/2015 9:21 PM
Could be as simple as a plug wire or coil pack going bad and it is not letting one plug get enough power to fire properly at idle.
This is a common problem on Fords of which all of our Fords have done that from time to time when a coil pack goes bad or a connector between the plug and coil gets moisture in it or a plugs electrode gap gets too wide.
I would say do a bit of checking and see if you can determine what cylinder is not firing when it idling by unhooking the plugs one at a time.
If you cant do that then the next easiest test is to pour some water on the hot exhaust manifold and see which cylinder is the coolest by watching which exhaust port area boils the water off differently than the other three.
Good Answers: 26
Re: Car Maintenance
02/19/2015 8:00 AM
Agree. Most people just replace the plugs and not the plug wires. Today's spark systems can run as high as 150Kv, in the old days it was more like 50 Kv.
Re: Car Maintenance
02/19/2015 10:10 AM
I also agree with tcm on this. Sounds like plug wires and/or the coil pack/SCM.
If they've never been changed, all the more likely this is the culprit.
Location: "Springwood", North Tamborine Mountain. Qld. OZ.
Re: Car Maintenance
02/20/2015 8:07 PM
Can't pour water on the exh. man.
Enshrouded by heatshield.
Stu.
"Nothing, is as it seems." Dr Wally.
Re: Car Maintenance
02/18/2015 11:35 PM
Are you sure it's not a Cavalier?
Good Answers: 122
Re: Car Maintenance
02/19/2015 8:16 AM
Air Bypass Valve may be sticking and needs to be cleaned or replaced.
Throttle Position Sensor may be dirty or faulty.
Engine Temperature Sensor may be faulted.
Engine Gas Recirculation Valve may be sticking and needs to be cleaned or replaced.
I would start with the EGR valve as it is the easiest to check and replace.
Good Answers: 11
Re: Car Maintenance
02/19/2015 9:43 AM
Check if oil level is at acceptable tolerances ( min- maximum). I suspect you overly exceeded maximum oil level. Is there any unusual noise besides the shaking?
Good Answers: 97
Re: Car Maintenance
02/19/2015 2:34 PM
It could possibly be a motor mount problem at the point of tarus stall speed.
CRTL-Z
Good Answers: 102
Re: Car Maintenance
02/19/2015 11:03 PM
2007 has OBDII.
Is it throwing any codes in addition to what appears to be a too slow idle speed.
It's summer in Sydney now. Is the shaking concomitant with airconditioning use in the afternoon?
Re: Car Maintenance
02/21/2015 2:31 PM
You may be right referring to the air conditioner. There is a circuit that increase the idle speed with air con on to compensate for the 3 to 4 kW needed for the air con, this also disengage the air con on urgent acceleration when passing or for steep hills. Will pay to investigate this. If we can just get the original poster to post some answers on our suggestions, like "I do not have an air con"
Re: Car Maintenance
02/19/2015 11:15 PM
I had this problem twice in two years happened to my 7 years old Nissan Latino Auto. The problem was due to spark plugs tension cables. At first it was one cable and the second was two cables. All's well now. My car is running smoothly. Thank God I didn't follow my mechanic to have overhaul done which would have caused a bomb. Paul
Re: Car Maintenance
02/20/2015 2:31 AM
You've changed the spark plugs and put the leads on incorrectly.
Typical symptom of two wires transposed.
Cheers,
Stu.
Re: Car Maintenance
02/20/2015 3:02 AM
For me, it may be as simple as too low tick over. 500RPM for such a small motor smacks of that. I would expect 850 - 950RPM myself.
Its certainly not a motor oil problem, assuming quality oil at the right mileages and ONLY OEM filters! But even if not, still most unlikely....
He did not say if the car was in neutral or in drive when it happens, but I suspect drive, and that his automatic gearbox may have a slight adjustment/low oil/wrong oil/water in oil problem, if the tick over is correct for this model of car....
There is still the possibility, that the tick over IS wrong, but correcting it might make the problem worse because of an automatic gearbox problem as well....the box could be "braking" the engine tick over.
But as most modern cars have the tick over controlled by the ECM, there is a possibility that the problems may come from there as well.....
As could bad engine timing due to a broken sensor/connector and engine is running in its "emergency - get you home - mode". Though this usually posts some sort of error for the driver that he needs to get a service/repair....
If it happens when in neutral sitting at a light, then I really must put my thinking cap on!!!
I almost forgot:- ITS NOT TYRES OR WHEEL BALANCE GUYS !!!!
Re: Car Maintenance
02/20/2015 8:50 AM
You have a Vacuum leak !
Good Answers: 137
Re: Car Maintenance
02/20/2015 9:50 AM
Last time I had a vacuum leak was in a car (much older than 2007, more like 1956, so maybe not comparable), which had pneumatic screen wash, and the vacuum hose occasionally came adrift. You could tell it had happened because the idle speed increased, and there was pre-ignition on switching off. OP's idle speed seems on the low side, as AG said in #22.
Re: Car Maintenance
02/20/2015 4:44 PM
Looking at your explanation it seems that the auto box try to lock the box in drive and pull the rev's down to 500, the g-box pump release the pressure at 500 rev's and as soon as it go up pump kick in and pull it down again. I will assume that you do left foot braking when you lift the rev's as you will slam into the car in front of you if you do not. Inside the bottom of the g-box is a filter that may bee need a replacement. Good luck.
Re: Car Maintenance
02/20/2015 4:58 PM
i forgot to mention that the Gearbox engage and disengage from traction is regulated by the vacuum sensor on the side of the box with a pipe leading and sensing the vacuum in the inlet mannefold. High vacuum as when the car is idelling will disengage the box and if you press the excelerator the vacuum drop and the g-box engage. If you have a leak in this pipe or the diafram in the sensor is punchered it will stay in g-box engaged as if you want to pull off and pull the rev's down. English is not my 1st language.
Re: Car Maintenance
02/20/2015 5:25 PM
You're getting closer.
The vacuum modulator in the transmission could have a leaking diaphragm.
Unusual fault to have tho', in this vehicle.
The vacuum doesn't actually disengage the drive tho.
The engine speed just drops below that point which the torque converter is designed to stall. [Check this yourself-- move the selector lever D--N--R. Feel the clutches take-up?]
Cheers'
Stu.
Good Answers: 102
Re: Car Maintenance
02/20/2015 11:08 PM
Last time that happened to me, tranny fluid was sucked up into the inlet manifold and the result was a spectacular plume of exhaust smoke that would make Batman green with envy.
Re: Car Maintenance
02/20/2015 5:08 PM
I read it that the shaking was a missfire.
Hence plugwires, etc
ANYTHING could be wrong. Non-closing/non-sealing valves included. Vacuum leaks -- do the brakes work as they were previously? On and on.
We can postulate for the remainder of the millenium and not actually get it right.
[This is getting a bit like the woman asked me the source of a "funny noise" over the phone. I asked "humourous or weird". Lost her!]
Anyway there are thousands of mechanics who will diagnose and repair the vehicle BEFORE serious damage occurs whilst you drive it with its fault.
Will you give us feedback?
Cheers,
Stu.
I'd personally be interested in finding out what actually is/was wrong.
Good Answers: 123
Re: Car Maintenance
02/21/2015 2:51 AM
Compare your recommended engine idle speed with your 500 indicated speed. I believe that it should be higher. There should be a device that adjusts that speed by allowing some air to bypass the throttle body. That could be sticking, gummed up. or broken. This is a start, not a sure fire solution. Good luck.
It is also not a driveshaft out of balance.
Bob
Re: Car Maintenance
02/21/2015 5:52 AM
Hi it most likely is your pilit baring. Have a Transmissions shop look it over.
Re: Car Maintenance
02/21/2015 7:04 AM
Im sorrry baring is not the right wored the right wored is Bearing, it is back behind the pressure plat. Like in told you take it to the Transmission shop. Good luck.Hope you get your car fix.
Good Answers: 102
Re: Car Maintenance
02/21/2015 7:22 AM
Welkum to da fourarm.
Seriously, it's always good to see some new members having a go.
Now all we need is the OP (original poster) to jump into this discussion with some follow up observations. Might be waiting a while.......
Re: Car Maintenance
02/21/2015 7:55 AM
Nah! Waste of time.
S.
Re: Car Maintenance
02/21/2015 8:07 AM
The spell checker on CR4 could help you write in a better manner...It won't fix everything, but it will alert you to the words not in the dictionary....I use it always and I am a reasonable speller, but typos are also found!!
Thanks in advance for your understanding.
Re: Car Maintenance
02/21/2015 9:21 AM
Andy it amaze me more and more that technical inclined people refer to the English used by other on this technical forum. My surname is Bornman(n) and English is my 3rd language and German my 4th. If we come on this site and address people out of respect in their UK English/ USA English/ South African English/ Australian English Language we do not need a reference to our Grammar. You are wrong with the spell checker because my Dictionary on my computer is set to check my spelling in my first language as well as English and unfortunately there are words that sound the same and spelled different in different languages. The word Baring in the place of bearing do not come up as a spelling mistake because the word is an existing English word. Revering to your German caption on the end of your post, I can give you Many English translations that will not be offensive as your translation. Example. HE who do not know, can realize (learn) lots (much).
I would like the Editors to mention at some place that this forum is multilingual and the language used will be English and that is not an English Grammar or spelling test, stay on the topic, English is not the topic. If the English used make the problem unclear, please ask clarity ON TOPIC.
Re: Car Maintenance
02/21/2015 2:59 PM
If you had used the spell checker on CR4, you would spell far better than using one set up for different languages. Surely that is obvious?
Your spelling in this post is suddenly better, can you tell us why?
My first language is English, my second is French, third is Portuguese and I learnt German last.....
Sadly your translation of that German phrase is well off key, mine is far more accurate to the original German meaning.....
"HE who do not know, can realize (learn) lots (much)."
Is simply very poor and wrong, just reading it in English shows that too.
Your version appears to be made by a very poor quality software translator. Its also grammatically incorrect in English too...totally screwed up one might say!!
My original German has no "gender". You (or your software) missed that completely and made it masculine!! Big error!
You also completely missed the inner meaning of the second part as well, it is actually a sarcastic comment that software will not understand at all....in fact, you or your software has completely missed the correct full meaning of the whole sentence in German and the writing of it in English is simply very poor as many here can read and understand!
Trust me, I have no need to lie to you....
Furthermore this is an American website and everyone here is asked to write in English for clarity and understanding for all.
Now sometimes, screwing up the grammar can change the basic meaning of a sentence. But sadly, there is no grammar help here on line. But with regard to safety, for example, a misunderstood sentence could injure someone...so it is important. I am sure you would not want to do that....
But getting the words right is easy using the spell checker s I have said before, though its still not 100% perfect. Provided you use it.....which I suspect you did in your last post, as it was far far better.
Your original posts read like a joke, the spelling was so awful....I was not certain either way......joke or serious!
Furthermore, I would not let anyone open themselves up to criticism that they do not even know about. I was trying to help you.
But if you are so certain that you know it all, then please continue in any way you see fit...I will refrain from helping anymore....
Have a great Sunday.
Re: Car Maintenance
02/21/2015 3:09 PM
You are exactly right, my writing did not go around the fact that you are not right in English or German but around the fact that you are a sarcastic person with no respect for others or their ability to accommodate you in your language. If you want to teach language to show your superiority, join a language forum.
Re: Car Maintenance
02/21/2015 3:26 PM
You appear to have some serious personality problems.
I was trying to assist you, you didn't understand that either, so I have no great hopes that you understand anything!
Please do not be surprised that if you continue to in an way shape or form try to continue this conversation, in the manner you have shown up to now, I will be talking to Admin.
Understood?
Do have a great day in spite of me....this is my last and only warning....
Register to Reply Off Topic (Score 8)
Re: Car Maintenance
02/21/2015 3:43 PM
You are welcome to speak to admin, you were the one insisting to make this forum a language training forum. I was trying to ask you to refrain from posting language lessons on an engineering question. You did not criticize me from the start of this conversation, I was trying to save face for the non English speakers from whom you could just not keep your snotty comments to yourself. Enjoy your crying to Admin. You do not need to speak to me again I will wait for Admin.
Re: Car Maintenance
02/21/2015 4:04 PM
You are welcome to run to Admin if you know that you are wrong and want to stop me from requesting that you stop belitteling people about their use of English like a teacher.
"Understood?, this is my last and only warning....." as if I'm your child. You did not criticize my language from the beginning but some other poor fellow that tried to make a statement ON TOPIC but not to your lingual satisfaction. All I was trying to ask you is to stay on topic with your comments and the topics here are not language.
You do not need to respond I will wait for Admin. Enjoy your crying.
Re: Car Maintenance
02/22/2015 1:34 AM
That is my right, yours too if you ever need it! Admin is there for everyone....
I have also found your BIG mistake with regard to my signature, you wrongly stupidly took it to be a translation of the German saying!
WRONG WRONG WRONG!!!!
I have TWO sayings on the same line, one German, one English, because I like them both!!! I am allowed that!!! There is no rule against it!!
SO JUST FOR YOU I HAVE NUMBERED THEM 1) AND 2), JUST SO YOU KNOW WHICH IS ONE AND WHICH IS THE OTHER.
I will mention again the PROPER translation of the first one (I already did it some time ago here), it is just this:-
"Those who know nothing, believe a lot!"
That is a correct, grammatical English language translation from the German that reflects both the original meaning and the sarcasm meant in the German version.
Also, you simply made yourself look silly to many here with your very poor attempt at translation to English (which is why I thought you were also the other poster with terrible English), as I already mentioned....... Grammatically and factually very, very poor.
I have worked as a part time translator (second job, own company) for many different publishing companies over the years, translating both French and German, usually technical books into English. Also a few books on cooking.
I believe I started in 1979, when I used to live in the UK. Then it was just French to English.
I have been doing it for a relatively long time, one or two books a year, always by request, I don't look for work. I am never the original author...
The very first basic rule of translating that some, like you completely ignore and always fall flat on their face by ignoring is:-
"YOU ONLY TRANSLATE INTO YOUR PRIMARY/FIRST LANGUAGE, NEVER FROM IT!!"
One of the best German born translators from German to English that I have ever read, is the one that translated the Novels of Gunther Grass to English, who STILL makes serious errors in the books because he never learnt the rule above.....he is also a Professor of English at a German University if I remember correctly and HE STILL CANNOT DO IT!!!
You proved the rule!
Register to Reply Off Topic (Score 9)
Re: Car Maintenance
02/22/2015 1:27 PM
You still do not get it. I want you to stop being a self appointed english teacher on a Technical forum.I do not care about your high horse achievements in language. What are your Engineering qualifications and what is your Engineering registration field and number at which registration institution. You are welcome to post as long as it is on subject or a comment about some engineering subject. In 1979 I already had 22 year service in a war in an engineering capacity. I know my english is 3 rd grade, but it is not a priority. The artisans and engineers I had the privilege to work with come from many parts of the world even England and if the world have to judge their capabilities by the english they speak, there will be no development or structures any where in the world. Engineering development and design and advancement fortunately do not depend on being english. Glad to see you are still talking to me. I do not have a problem with you, I respect your achievements as long as you do not use it to proof your seniority and pretend that english is proof of others intelligence. We all have our own fields of expertise and I am not forcing mine down your throat.
Re: Car Maintenance
02/22/2015 3:04 PM
Either like or lump it. (Do you know what that means?)
For someone who has not been here a full month even, you have some really rude demands, that will give me personal pleasure NOT to fulfill....
I am not changing just for you!!
Your complete lack of support from other long term members here demonstrates that rather well I feel.....
This is an English language forum. It needs to stay that way....completely....
You could of course improve your English, then I won't need to keep on saying something........only if I see a need!! Your choice....
Do have a great day......Bis bald! (G'Day Cobber in German!!)
Good Answers: 137
Re: Car Maintenance
02/22/2015 3:05 PM
If I can stick my oar in - I think this is getting out of hand and a little shrill . As I read AG's #36 he was just trying to be helpful, it doesn't come over as condescending to me.
Re: Car Maintenance
02/22/2015 3:20 PM
Many thanks, well put.
I hope you get through to him, but I really doubt it.
He joined on the 30-1-2015, he has already upset a lot of people......if he does not change radically.......
Forecast;- in one year he will be LONG gone....
Re: Car Maintenance
02/22/2015 6:07 PM
Who else did I upset by asking you to stop your English teaching on a engineering forum. You cant even count, 1, you.
Just stop it, you are wrong and this is not an English Forum, it is an engineering forum where we communicate in english as well as we can.
Your english does not make the engineering or questions and answers better. It stop people from commenting in their broken english.
Re: Car Maintenance
02/23/2015 2:15 AM
Your lack of simple good manners, drives me onto GREATER levels of possible CORRECTION than ever before!Especially anything you may write!!!
UNDERSTOOD?
Do also remember, even Hitler had a friend or two!!before the end!
You really don't get it do you?
Still I wish you a great day wherever you are.....
Re: Car Maintenance
02/22/2015 5:11 PM
I will support that statement.
This is generally an engineering forum.
Cheers,
Stu.
Re: Car Maintenance
02/22/2015 5:49 PM
Thank you, appreciated.
Re: Car Maintenance
02/21/2015 3:21 PM
Sorry, just for your information I was not the person you criticized on my spelling from the beginning. I was just making a point on this unnecessary posts on language on a technical forum. This forum belong to all the subscribers and you have not been appointed to be the language Editor.
Re: Car Maintenance
02/21/2015 9:04 PM
Suddenly your text has the appearance of being written by an English professor! Please explain!Seems like you set a deliberate trap from where i sit. I hope you found it funny, because i didn't.Jim
Re: Car Maintenance
02/21/2015 9:19 AM
It's an automatic transmission. Automatic transmissions do not have pilot bearings or pressure plates.
Re: Car Maintenance
02/21/2015 2:36 PM
meddy from Sydney, Australia, please comment on the suggestions. we do not know if you have an air con, have you tried something, did you sort it out, did you take it to Toyota?
Re: Car Maintenance
02/21/2015 9:15 PM
The Engine Management System adds extra fuel when the engine is cold and cuts it back once warm. ( choke ) To get the fuel mix right the EMS relies on a number of sensors. The throttle position sensor is prone to wear, the oxygen sensor is prone to burn out other sensors are prone to mechanical damage and the problem may not even be related to the EMS.Sucking a small amount of air affects fuel mix and causes these symptoms.Spark system breakdown causes these symptoms.Gearboxes are now part of the EMS and there can be sensor problems there as well. My Verada kept trying to change into 1st whilst at speed - faulty throttle position sensor.Please reply to some of the posters' questions to get a better answer.Jim
Re: Car Maintenance
02/22/2015 5:20 PM
I know that you have replaced your plugs ~11,000km ago, but I would pull them and check them for gap and carbon build up. Did you use the same make /rating of plugs as the originals? Champion plugs had a poor reputation for a long time, NGK are very good, likewise Bosch.
Re: Car Maintenance
02/22/2015 7:59 PM
Some further thoughts....
If your idle revs are too low it will idle roughly
If you have an induction air leak after the air metering you will have increasingly rough idle. this could be from loose manifold, manifold gasket, split hose, worn and leaking throttle shaft.
blocked PCV valve.
Faulty inlet air metering device (MAP/Flow) sensor.
You can use a length of hose as a sort of stethoscope to listen around the induction hoses, manifold etc for air leaks
Good Answers: 123
Re: Car Maintenance
02/27/2015 2:26 AM
As long as we are on the subject; I remember "I" before "E", except after "C", or when sounded like "A", as in neighbor and weigh.
Can you help me with the correct uses of ":", and ";"? Thanks.
Bob
In reply to #60
Re: Car Maintenance
03/03/2015 6:46 PM
Many, many thanks for all your suggestions.
This rough idling was there even before spark plugs were replaced.
Also maf sensor has been clean. The only thing that is not yet clean is the throttle housing.
Is it a very technical job to be done?
Good Answers: 123
Re: Car Maintenance
03/04/2015 12:46 AM
To clean the throttle housing is not hard to do, if you have the housing off of the car. But, it is not worth the effort to remove it because the housing can be plenty dirty, and cause no drivability issues as long as the throttle blade is clean along with the area of the throttle housing it mates to. This sounds like a chemical repair to me. Get a couple of spray cans of cheap carburetor and choke cleaner, and one can of emissions approved throttle body spray cleaner.
With a cold engine, remove the air cleaner assembly. Get an old t shirt, or something similar in size. Open the throttle, and push the rag in far enough to hold it as far open as possible. DO NOT TRY TO START THE CAR!!!!!
Use the cheap spray to spray away all of the black crud you can see in the throttle area. Let the shirt soak up the spray and not let it run all over the engine. That crap is very flammable. Move the shirt-rag as needed to get to all of the throttle blade, as well as all of the inside of the throttle housing you can.
When you think it is clean enough, remove the rag-shirt, and dry it all off. With the throttle fully closed, start the engine, If the engine has ingested any decent amount of that spray, it may run fast. If so turn the key off before engine speed gets high. Let it stop, and repeat. it will not take more than 2-3 tries before the excess spray is burned up. At that time it should idle on its own. Now with the good spray, direct short sprays at the intersection of the throttle blade, and housing. If the spray is too much, the car may stall. Not to worry, just restart, and spray shorter bursts. That should clean off all of the small air passages that MIGHT be causing the rough idle. when the spray no longer is cleaning anything, and the spraying is not achieving any improvements to the idle, you are done.
This should also help the automatic engine idle speed controller to maintain the correct idle speed. Good luck.
Bob
Good Answers: 137
Re: Car Maintenance
03/04/2015 4:25 AM
GA for detailed explanation. Fingers crossed for OP that it works! Hopefully he'll let us know.
Re: Car Maintenance
03/04/2015 1:11 PM
Like it!!!
Good Answers: 123
In reply to #64
Re: Car Maintenance
03/05/2015 2:03 AM
Thanks for the reply, but I think the OP's problem may be more than that. If the timing belt-chain-gears have worn, the camshaft will become retarded. That will lower compression. And no amount of cleaning will restore that compression.
An alternative to the posted method would be to remove the spark plugs, pin the throttle wide open, and hit the air intake with a pressure cleaner. Follow up with plenty of shop air. Then turn the engine over with the spark plugs out by hand a few times, then with the starter, then install the plugs, close the throttle and fire it up.
That should start some nasty letters.
Bob
Good Answers: 137
In reply to #65
Re: Car Maintenance
03/05/2015 4:04 AM
Is that an alternative cleaning method, not meant to help with problem caused by worn camshaft drive hence retarded camshaft? In any case that would not affect the ignition timing, only the valves, and it would have to be pretty severe to cause a problem. I once worked on an engine where it was one tooth out on the camshaft pulley (toothed belt drive) but it appeared to run normally.
I think I prefer your first method for cleaning!
Good Answers: 123
In reply to #67
Re: Car Maintenance
03/06/2015 4:03 AM
No actually the alternative cleaning procedure would work for cleaning the manifold on most any engine where the runners are not so twisted as to prevent the pressure washer from hitting the walls.
The retarded can timing by itself would not be too bad if the ignition timing is set by the crank. But if the ignition is set based on the camshaft position, as with a distributor, then the ignition becomes retarded as well.
The worst case I ever had was a Toyota Supra that needed a timing belt. After replacing the belt, the car came back with a complaint of no power. I pulled the plugs and found they were originals. I replaced them because the car had 98,000 miles. That made no difference. So I checked to see if the timing had jumped. Sure enough it had jumped one tooth. Well the AH that just put the belt on must have left the tensioner loose right? I pulled it back down, and the tensioner was tight still. Tightened it a little more, and sent it on its way. Two weeks later same thing, no power, and the timing is one tooth off. NAPA replaced it and never another issue.
Bob
Good Answers: 137
In reply to #68
Re: Car Maintenance
03/06/2015 5:25 AM
That's correct if the ignition timing is set up, then the wear occurs, and nothing is done. But the distributor can easily be re-adjusted to the correct firing point, and I was assuming that would be done. With a 2007 car I would guess ignition timing is controlled by the engine management computer, usually via a trigger on the flywheel, so it's not an issue.
Good Answers: 123
In reply to #69
Re: Car Maintenance
03/06/2015 2:26 PM
I think the only issue remaining is, What happened to the OP?
Bob
Good Answers: 137
In reply to #70
Re: Car Maintenance
03/06/2015 3:57 PM
Yes, it happens all too often. Speedy00002 with a Chevy cavalier didn't get back to say whether any of the many suggestions he'd received solved his problem.
In reply to #71
Re: Car Maintenance
03/07/2015 2:43 AM
OP came back as Meddy, it seems. He was back on 61. Need time to perform that cleaning operation
Good Answers: 137
In reply to #72
Re: Car Maintenance
03/07/2015 3:36 AM
Yes, you're right. Just hope he keeps us posted.
Re: Car Maintenance
03/05/2015 3:39 AM
Meddy, what does the car do in neutral?
Register to Reply 73 comments
Andy Germany (9); bigg (3); bob c (6); Brave Sir Robin (1); catman58 (1); Codemaster (8); Curtsometimesknows61 (2); Doorman (1); Fredski (1); JIMRAT (2); lyn (2); meddy (2); Noudge79 (1); Oomborrie (14); Paul Seah (1); SHOCKHISCAN (1); SolarEagle (2); spades (1); Stueywright (6); tcmtech (1); texasron (1); Unredundant (1); Wal (4); WAWAUS (2)
