Previous in Forum: Civil Engineering   Next in Forum: Think I Need to Build One of These!
51 comments
Should I Shovel the Snow off my Roof?
02/26/2015 12:03 PM
I live in upstate NY and this has been a year of plenty of snow and very cold temperatures. My house sits quietly with a roof well covered in snow of between 8 and 14 inches. We actually had much more but most has been blown off from windy days. I face the question of: Should I climb up there and clear the snow? The house is well insulated and there has been little in the way of melt off or ice build up. There are lots of variables with this question including were we are in the season, weight of snow and roof design. Any suggestions? what would you do?
Good Answers: 76
Re: Should I shovel the snow off my roof?
02/26/2015 12:17 PM
Per JavaHead:
ADMIN: if you see this - could you edit the post (removing the link) due to it referencing superseded information? Thanks.
From NY State - Dept. of State:
[Link Removed - due to Superseded Standard]
This might help get you started.
Good Answers: 179
02/27/2015 9:42 AM
This document is based on the old ASCE 7-98 Standard, and has been greatly revised several times since it's publication.
The current standard is ASCE 7-10 "Minimum Design Loads for Buildings and Other Structures". It is scheduled to be superseded in 2016 with ASCE 7-16.
Good Answers: 76
02/27/2015 10:13 AM
Thanks for pointing that out...
No sense in having outdated information out there - lest it propagate ;-)
Edit: And that is one of the issues with sending the ill-informed out into Google Land. I consider myself slightly informed and the above is a prime example how easy it is to get 'bad/wrong' information from a seemingly 'reputable' source.
Good Answers: 179
02/27/2015 10:18 AM
You're welcome.
Good Answers: 918
02/26/2015 12:37 PM
8" to 14" is something I would not worry about, particularly if the wind blows it off, which tells me it is probably a lightweight snow.
Other factors would be when the house was built. Generally, the newer the construction the better the capacity of the roof.
Your bigger worry may be falling off the roof and unless you have significantly more snowfall to add to the amount already up there I would leave it alone.
02/26/2015 12:40 PM
What do your neighbors do?
I'd say snow load on the roof is most critical.
Sadly, living in Arizona, I have no practical experience with this.
02/26/2015 12:49 PM
Is not only the snow load on your roof, it's when it melts and refreezes. The ice can creep under you shingles and when that melts then you have ice melt leaking between your windows or inside the house (depending on the weather). And the ice on your roofs eves creats a dam and compound the problems.
02/28/2015 1:31 PM
Ice dam formation has more to do with attic ventilation, insulation, and overhang of the eves. If the melting occurs due to heat loss from underneath and the melted water refreezes because the eves overhang and there is little or no heat loss from underneath, then you have two things; an ice dam, and a problem.
02/28/2015 1:33 PM
Agreed
02/26/2015 12:50 PM
What's snow? I would probably build a slide......so no help here....
02/26/2015 12:52 PM
Then again when you get a lemon, you're a make lemonade kind a guy.
Good Answers: 266
02/26/2015 3:34 PM
So what your saying he should open a snow cone stand. Remove it a scope at a time.
02/26/2015 6:10 PM
Italian lemon ice....
02/27/2015 12:28 AM
You're a certifited 'merkin - every situation has a positive angle. Brits would make a depressive soap opera about it. I could go on, but I'd have to regail you all with depressing snow stories and stuff about weather.,,far be it from me to harp on about winter being worse over here a few decades back.......
As I was saying,,,,,, I vividly recall falling into a 10' ditch of snow one winter when I was all but 3' tall. Had it not been for some of the elder kids I'd have ended up like Tollund Man. Shaddup up all ye who think it might have been for the better ! Times were hard, and if opportunity had presented my elder sis would have been in that ditch. Kind fate has left her with a house that has a flat roof extension. The things are a nightmare in general, but the thought of snow is funny. She ain't no engineer, and the day may come when there's payback.
Why the question ? Shovel it offf as much as possible when you get a window of oportunity. Before you slice me, bear in mind this is not a problem that often occurs in Blighty.
Good Answers: 76
02/26/2015 12:55 PM
Just looking at that gives me the chills, I am so happy I live in Houston now ;-)
I have had my fill of Great Lake Snow Effect.
Good Answers: 26
02/27/2015 8:45 AM
Houston, voted the worse drivers in the US. I am down the street in Baytown. We dont need to worry about snow.
Good Answers: 76
02/27/2015 10:05 AM
Yeah - I would have to agree on the caliber of drivers here, but proportionally-speaking I think the ratio might be the same... there are just so many more here.
02/27/2015 10:22 AM
Welllll - I lived in Houston for a while, and despite living most of my life in the snow bands off Lake Erie (I saw -25F on the thermometer this year)the coldest I've ever felt is the day it hit 32 F in Houston with the usual high humidity, and I tried to take a walk. That damp chill to me is far worse then our dry cold up north here.
02/26/2015 12:57 PM
LOL.. been there done that. Five years ago my son snow boarded from the peak of the garage to a landing ramp very similar to your pic. As the father I just held my breath. Thanks for refreshing the memory!
Good Answers: 76
02/26/2015 12:53 PM
Also found:
http://design.medeek.com/resources/snow/snow_calculator.pl
Which requires Ground Snow Load, which can be gotten from:
http://design.medeek.com/resources/snow/newyorkgroundsnowloads.html
Based on personal experience, when I use to live in Chardon, Ohio (snow belt) I used 24" as my threshold. Anything above that, I'd climb up. But mostly because mine would usually drift with one side almost completely devoid of snow and the other quite covered.
But, as AH said, you're likely good.
Good Answers: 92
02/26/2015 12:59 PM
A foot of snow should be no problem- assuming 50% water content that's still only about 30 psf deadload (water weighs around 62 lbs per cubic foot). If you're still unsure, call the local building department and check to see what code requirements for roof loading were when your house was built.
Good Answers: 151
02/26/2015 4:05 PM
The problem is not what snow is on the roof now, it is what might be added to it in the next month before it can melt off. The greatest threat is cold rain. When the temperature is below about 40º F, rain will not melt snow. The snow just absorbs the rain like a sponge. The 50% water content will quickly become near 100% water content.
Good Answers: 151
02/26/2015 3:04 PM
Having lived in New England all my life, my usual philosophy regarding shoveling snow is if I wait long enough it will go away. That said, the first consideration is the pitch of the roof. My houses have all had high pitched roofs (12/12) and I never had a problem with snow. And even if I had, I would not have attempted climbing on them and shoveling.
We still have March to get through, and we can expect to have at least one more major snow storm, probably a wet heavy snow and possibly a heavy cold rain before the snow on your roof melts. If the pitch of your roof is low enough that you feel comfortable working on it, and it is a single story house, I would say, shovel it.
Good Answers: 11
02/26/2015 3:25 PM
I would stay off the roof at all costs unless it is absolutely necessary. Roofs are never meant to be tread on, shoveled, or slid down! Not only for the safety reasons....keeping your footing on a sloped, slippery surface, but for the damage that can be done to the roof itself. In cold weather, asphalt shingles are very brittle and easily damaged by impact.
Roofers in your area are set to get rich, once the great melt-off commences and all the new leaks in the roof reveal themselves.
People Living in Competition, All I want is to have my peace of mind - Boston
02/26/2015 3:57 PM
Thanks and great feedback from everyone. I've done more research and found that 1 ft3 of snow can weigh any wear from 1 lb to 21 lbs depending on the moisture saturation level. I also learned that the trusses used for my house are rated at 60lbs per square foot. So that basically tells me that I can take up to 3 feet of the wettest nastiest snow before I'll have a problem. Snow drifts could be a potential problem for others but it doesn't apply to my situation. I think I'm going to stay off the roof.
Before anyone gets on a snow covered roof I think it would be a good idea to talk to their local building codes department to get a better understanding of their roofs strength.
reference: http://building.cdaid.org/images/Handouts/Shovel%20Roof%20Snow.pdf
Good Answers: 151
02/26/2015 4:11 PM
Sounds good to me. Crack open a cold one, sit back and wait for the snow to go away
02/27/2015 7:40 AM
Good choice. But when it starts to melt & refreeze and melt and refreeze, if you have the usual shingle roof you may start leaking at the overhang and just above. There are ways to remove it from the ground if it is a single story house. Either way if you are over 50 years old you don't have the balance and strong bones you once had and should stay off the roof. At 74 I solved the problem by moving to Dallas Tx. No more snow problems but it seems I can't get away from ice on the ground. Busted an arm falling off the ground a while back. So who am I to talk.
Good Answers: 145
02/26/2015 4:44 PM
I know that in #14 you decided that you do not have a problem but ... if the snow is light enough that some of it blows off would an electric leaf blower allow you to dramatically reduce the amount of snow on the roof?
02/26/2015 5:27 PM
First off, congrats on having snow on the roof. People will say 'what the heck', but it's commonplace in Blighty to see some houses devoid of snow in a heavy winter- the house is leaking heat.
Upstate NY is a different kettle of fish. How you need to react depends upon pitch of roof and it's construction, not to mention wind loading. The unstated question is about will this cause roof collapse(?).
Even with full load data I'd be very wary of suggesting limits.
Take this with a huge pinch of salt (pun aside, you could chuck it up there), if you are comfortable with working 'roped up', I'd get up there and shove some of it off before the risk of any more. Most constructions will take a foot of snow, but do you want to risk it getting worse. That is a very arbitrary opinion and complete guess, all I can offer is that weather permitting I'd try clean it down it bit if/when you can.
Good Answers: 918
02/27/2015 7:48 AM
"First off, congrats on having snow on the roof."
I thought you were talking about hair.
02/27/2015 8:04 AM
Nice try. I'm sure there's still smoke in the chimney.
Good Answers: 918
02/27/2015 8:23 AM
Roger that. ;-)
02/27/2015 8:38 AM
How the flip did you know he was on my tick-llist of blogs to visit !!!! He somehow publishes them faster than I can read them.
I've not the foggiest if this works...
Good Answers: 918
02/27/2015 10:07 AM
"Who would think that at became part of Morse"
Sounds like one of those silly adverts we get on CR4 from time to time. ;-)
02/28/2015 2:14 PM
Strange but true... The silly sods should have asked CR4 members to vote, the place woukld have errupted with suggestions. '@' seems sensible, but if somebody can send an email, then....
This has nothing to do with the question at hand, but pondering this might be safer than going outside in blizzard conditions. Besides, you just never know when Morse might come in handy ().
Good Answers: 122
02/26/2015 5:59 PM
I do not miss shoveling snow from my roof, the sidewalk, and the driveway nor the wind.
Snow loading can be very harmful to your home and needs to be removed before the depth and weight of the snow exceeds the roof load rating.
The moisture content of snow varies making it very hard to estimate the weight therefore it is a good idea to keep the snow removed when it is around a foot deep so that your weight in addition to the weight of the snow does not exceed the roof load rating.
If you do shovel the snow off, begin at the edge and clear a path at least 3' x 3' where you are going to stand before you transfer your weight onto the roof surface and keep a 3' x 3' open area void of snow around you at all times while shoveling.
Also; Be aware that there will be ice under the snow and depending on the roof pitch it can be hazardous to your health so use a safety harness and rope or cable to tie off to so that you do not slide off and fall from the roof.
Don't tie off to a vehicle unless you control all of the ignition keys. My buddy did that in the past and when his wife came out of the house and took off in the truck to the store he got one hell of a ride over the peak of the roof and down to the ground then to the hospital.
02/26/2015 7:25 PM
I would love to have some snow on my roof right now! In buenos Aires we have had two weeks @ 35 to 37ºC I am working in the machine room and bilge of my steel boat (currently on a yard)... and despite 2 aircons at full speed, heat is unbearable!
Good Answers: 15
02/26/2015 11:00 PM
For every action, there is an equal and opposite criticism.
Good Answers: 179
Re: Should I Shovel the Snow off my Roof?
02/27/2015 9:32 AM
There's a lot of factors involved regarding the roof framing capacity to safely support a Snow Load.
Some of these factors that must be taken into account include (assuming wood framing): framing type (roof rafters vs. prefabricated wood trusses); framing span; roof pitch; wood species, and hence allowable stresses; wood framing sizes; framing connections; snow depth; snow moisture content; accumulated ice depth at the roof shingles interface due to warm roof (snow melt and refreezing); actual construction Dead Load (roof building materials weight); and, Attic storage Live Loads.
Frankly, 14-inches of snow depth isn't something to worry about and it's common, unless the roof is a flat one, or the roof was poorly constructed or designed. When you get snow depths in the 24-inch or higher range, then it is time to start worrying, especially if you've experienced several storms that have deposited alternating wet snow and mixed precipitation.
Another thing to worry about is what is termed an "Unbalanced Snow Load", where the winds have blow snow from one side of the roof to the other side, thereby causing deeper-than-normal snow drifts. Over the years I have seen a great number of roof framing failures due to this sole condition.
As others have said before me, I would be more worried about ice-dams forming along the eaves and melted snow and ice penetrating under the roof shingles and roofing felt (tar paper).
If you are concerned about the water penetration, then invest in a good snow rake with a long telescopic extension handle. You must take into account that if you're standing on the ground that you'll need a substantial length. Either than, or you'll need to stand on an extension ladder propped against the roof eaves.
One half of my house roof is 16-feet in width. I use a 40-foot long aluminum snow rake handle to reach the roof ridge line. It sure helps to clear the sticky snow off the PV Solar panels! I also have installed roof "Heat Tapes" along all of my roof eaves in addition to the roof gutters and their downspouts. they work incredibly well.
Yes, I'm an Upstate New Yorker as well, and seen some bad stuff happen to roofs here in the Capital District and Mid-Hudson Valley, including my own.
Signed,
CaptMoosie, PhD, P.E.
Civil, Structural, & Environmental Engineer
Good Answers: 27
02/27/2015 9:34 AM
Do Not Do anything, leave the snow on the roof alone! It will be dangerous for anyone to climb up on any pitched roof at this time of the year!
My NY house was built in 1937, typically pitched with slates as roofing material which are very slippery, specially when wet! Through all these years, whatever snow accumulations on it just either melted or breaks into chunks and slides down on their own without anybody's intervention! Specially true after a couple of continued sunny day exposures...
Multi-dwelling apartment buildings are normally different since they mostly have flat roofs??
vsar
02/27/2015 9:57 AM
If it's a flat, level roof: I'd consider it.
If it's a sloped or peaked roof: Fuggedaboutit! You don't want to break you neck falling off the roof. It's pointed like the top of your head for a reason, ya biscotti!
(I hope I did a good 'New Yowk' accent on that response. If it was a poor rendition, or if it's 'too good,' I appologize.)
Good Answers: 26
02/27/2015 10:39 AM
When i was in upstate NY (still have a PAID FOR house there) i took some M80s and threw them on the roof. Started a mini avalanche.
02/27/2015 12:41 PM
If it's wet snow, I would get a stepladder and a hoe or a rake and pull off what I could reach, and forget the rest.
Good Answers: 102
02/27/2015 11:54 PM
What would I do? I'd move to somewhere it doesn't snow. Although I've had similar problems with leaf and branch accumulation on roofs. Rotten leaves are slippery. No escaping some chores.
What did you do last time you had snow on the roof?
How about opening the attic door and letting some warm air in to heat the roof a bit so it heats the roof/melts the underside of the snow and watch it slide off...probably onto your head when you slam the front door on the way out to work.
I've had to deal with ice accumulation on towers. For some reason, 2m long falling icicles were deemed hazardous. Removal involved a very large mobile crane with a man bucket and a man in it swinging a bit of 4x2 at the structure.
Try whacking the snow off.....or....get a piece of 4x2 and a hammer drill with a big bit or a chisel bit, climb up to the eaves using a stable ladder with your kit, don't attempt to get on the roof, place the 4x2 on the roof or barge board and let rip with hammer drill against the bit of 4x2. Alternatively, if you have one, a concrete compactor (vibrator) would shake things up nicely too.
Make sure somebody is video recording the process.
02/28/2015 4:30 PM
It mostly depends on the pitch of the roof. Living in a ranch type house, my rule of thumb, if snow has accumulated to about 10 inches and you are expecting rain or freezing rain, cleare at least half way to the peak across the entire roof. At a foot or more, remove the most you can. The more the pitch, the less worry there is. If it is hard to walk on due to pitch, do not worry.
Good Answers: 151
03/02/2015 11:26 AM
by the time this post finally fades away, and if you have not made a decision yet, it will be July, and the snow will (hopefully) be long gone
Good Answers: 109
03/02/2015 8:47 PM
If you can safely do so: YES!
Good Answers: 32
03/03/2015 11:16 AM
I had a friend who moved to Vermont and moved into a new home, Cape Cod style, he had built. The contractor advised him to buy a "snow rake" and he thought that his leg was being pulled since he was from New Jersey and moving north. After a particularly heavy overnight snow storm on top of earlier accumulation, he went to go out his front door. It wouldn't budge and neither would the back door. He called the contractor who then asked if he had bought a snow rake and kept the roof cleared. The contractor came over, cleared the roof, jacked up the beams in the basement to fix the settling issue due to the extra weight. I used a 25 foot aluminum handle snow rake to clear off the gutter areas as far back as I could due to water leakage through the window areas under the overhang because of ice damming. My advice, buy a snow rake, use it and call it preventive maintenance. It's cheaper than replacing sheetrock.
Spinco
03/11/2015 12:08 AM
Be careful when you are up to such works. I have my indoor cleaning done by professional house cleaners at Orangeville ( http://www.handimaids.com/services/recurring-cleaning/ ) since I am allergic to dust. It always helps me to stay healthy. Dont go to do things if you are at risk. Dealing with snow, that too on roof, It's always advisable to seek help. Hope this helps!
05/22/2015 5:57 AM
I think the number one factor would be when the house was built. Generally, the newer the construction the better the capacity of the roof. Hope you fix it.
Good Answers: 102
05/22/2015 6:19 AM
Snow would have melted by now.
This might be a good time to install some permanent roof access ladder supports and work anchorage points.
All the rage in Oz. (for cleaning leaves and general maintenance not shovelling snow but same sort of shite happens)
Register to Reply 51 comments
adreasler (1); Anita1215 (1); Anonymous Hero (4); AverageJoe (1); Beenaround (1); BruceFlorida (1); CaptMoosie (3); gringogreg (4); HullRider (2); IdeaSmith (1); JavaHead (5); JNB (1); Kris (5); laurawhite (1); lyn (1); mikenelson6 (1); Munster (1); ozzb (1); pappio (1); phoenix911 (4); Phys (1); r&ddoc (1); SHOCKHISCAN (1); SolarEagle (1); Spinco (1); StandardsGuy (1); texasron (2); vsar (1); Wal (2)
