Previous in Forum: Looking for an Emergency Disconnect Switch of 200~300ADC 500+V   Next in Forum: Exhaust Fan Capacitor
VersaMax Micro PULS Controller
02/28/2015 6:30 AM
Hi,
These days for automation microcontrollers have become very popular. I am concerned with one microcontroller called VersaMax Micro Controller called IC200UDR010.
It appears to be a 28 pin - 16 pin for VDC in; 11 pins for relay out; 1 pin for 24 VDC out.
It is said that this microcontroller is expandable upto 4 units.
What is this microcontroller typically used for?
Regards,
Re: VersaMax Micro PULS Controller
02/28/2015 9:52 AM
Control
Good Answers: 97
03/01/2015 10:01 AM
The UDR010 is a PLC with 16 inputs and 11 outputs.
It can drive a stepper driver chip with 2 of the outputs (step and direction)
Basic example : To skim a surface with a router you will need to connect limit switches on min and max X , Y and Z.
If you start left bottom you will start by pulsing the X in the + direction until the limit switch is triggered then you stop the pulses and pulse the Y stepper a few pulses positive. Then you pulse the X stepper in the negative direction until the limit is reached and etc etc,
I prefer a CPU as a CNC because a CPU can PLC but a PLC cannot CNC.
