Previous in Forum: A Photo of Light and Wave Duality   Next in Forum: Special Property Of Straight Lines
8 comments
Distance Between Two Points By Change of Coordinates by Shifting Axes Near Or Far
03/04/2015 9:32 AM
Let us assume that there are two points in a space (plane surface), 'P' and 'Q'. Let the space be divided into 4 parts by a horizontal line y-axis and by a vertical line x-axis Now what I want propose is:- " Let us consider two cases- case(i): when the plane(space) is divided into 4 parts in such a way that the point 'p' is near to origin and 'Q' is some what far away from origin. Give some readings to the both axes(x,y axes). Now calculate the distance between 'P' and 'Q' (obtained coordinates) using the distance formula, Let the distance be 'R' case(ii):- Now again plot two points in plane with distance 'R'( same above distance). Divide the plane in such a way that the point 'Q' is near to the origin and the point 'P' is some what far away from origin. Now calculate the distance between the obtained coordinates, the distance will be exactly as case(i) distance ie., 'R' , Therefore the coordinates obtained may be different but the distance will be equal ie., case(i)=case(ii) Hence proved Thankyou
Mathematicians are the kings of science
Re: Distance btwn two pointsby change of coordinates by shifting axes near or far
03/04/2015 9:40 AM
Analytic geometry 101.
Good Answers: 145
03/04/2015 9:42 AM
It looks like you posted your completed homework. This is probably the first time that has ever happened. I award you full credit for this question.
Good Answers: 918
03/04/2015 10:02 AM
"Hence proved Thankyou"
Actually, you haven't proved anything as all you have presented was the problem, but no mathematical proof.
So, what are you trying to accomplish with your post? Do you have a specific question?
Good Answers: 137
03/04/2015 10:05 AM
What's it telling you except that 2 points can be same distance apart as 2 different points? Pretty obvious I'd say.
Re: Distance btwn two points by change of coordinates by shifting axes near or far
03/04/2015 10:13 AM
eg:-case(i)=>P(1,1) Q(2,-1) Then R=sqr(5) case(ii)=>P(2,1) Q(3,-1) Then R= sqr(5) Therefore case(i)=case(ii) Therefore different points but equal distance, the coordinates differs by distance from axes
Good Answers: 918
03/04/2015 10:43 AM
Okay, but you are not proving anything that hasn't been proved millennia ago. What's your point here?
Re: Distance Between Two Points By Change of Coordinates by Shifting Axes Near Or Far
04/21/2015 12:39 PM
i didnt understand
Good Answers: 137
04/21/2015 1:28 PM
Don't worry, neither did the OP
Register to Reply 8 comments
Anonymous Hero (2); BruceFlorida (1); Codemaster (2); Durga prasad (1); Usbport (1); vijay guntimadugu (1)
