Previous in Forum: Distance Between Two Points By Change of Coordinates by Shifting Axes Near Or Far   Next in Forum: Problem with Ordering Online
9 comments
Special Property Of Straight Lines
03/04/2015 10:00 AM
Find the equation of the straight line passing through two lines, where the two lines are passing through origin, Let the two lines be a1x+b1y=0 and a2x+b2y=0 Then find the equation passing through them, where the given two lines passes through origin. THANKYOU
Mathematicians are the kings of science
Re: SPECIAL PROPERTY OF STRAIGHT LINES
03/04/2015 10:07 AM
First, we do not do homework.
Second, your phrasing is ambiguous about what this third equation is supposed to define.
Third, we do not do homework.
Good Answers: 137
03/04/2015 10:09 AM
You can't have a line (straight or otherwise) between 2 given lines, only between specified points on the lines.
BTW, what level of education are you at?
Re: Special Property Of Straight Lines
03/04/2015 10:25 AM
Iam not asking anyone to do Home work, actually we also don't do homework. Cant't we draw a line intersecting two lines at two different points P and Q, where the two lines passing through origin. There by forming a triangle, two lines are given, one we need to find. Actually I have discoverd something new, so i want to present this property to world. I have posted this quest to get an idea whether this property exists or not.
03/04/2015 11:46 AM
This is simple geometry. If line A and line B intersect anywhere they intersect in only one point. If they intersect then lines A and B together also define a plane. If line C also exists in the plane defined by A and B then line C must intersect either line A or line B at least once. Line C need not intersect both A and B.
03/04/2015 5:56 PM
"two lines are given, one we need to find."
What color would you like the line to be?
03/04/2015 10:39 AM
a3x + b3y = 0
03/04/2015 11:10 AM
a3x + b3y = c3, just be to completely general.
03/04/2015 12:30 PM
I'm waiting for Durga to discover the wheel.
Good Answers: 183
03/05/2015 6:58 AM
Any line in the plane of the 2 lines and which is not parallel to one of them 2 will cut both.
Your problem is - I appologize for the term- stupid and not worth to be discussed.
Register to Reply 9 comments
Codemaster (1); Durga prasad (1); lyn (1); nick name (1); redfred (2); Rixter (1); Usbport (2)
