Previous in Forum: No Such Thing as an Electrical Failure   Next in Forum: AC Meter Voltage Readings with Different Frequencies
23 comments
Good Answers: 54
Why Use a 3 Phase Motor in a Washing Machine?
03/05/2015 1:56 PM
I am helping my sister repair her washing machine and I came up with something I thought was a bit odd. I removed the motor to test it and to my surprise it's a 3 phase motor.
Going way back to my power electronics course, I remember 3 phase power and the benefits, however you need a 3 phase source to run the motor. The washing machine runs off 120VAC at 60 Hz, so there's a circuit to convert it from single to three phase, which then powers the motor. If these washing machines are made to fit a price point, I would think that cheaper is better (for the manufacturer).
For reference, the washing machine is a Frigidaire Affinity Front Load. I bought the same machine (but with GE nameplates) for my rental and I had the same problem she does (drum will turn when washing, but won't spin to dry).
Back to my question; why go through the expense of creating circuitry to provide 3 phase power and the added cost of a 3 phase induction motor?
Re: Why use a 3 phase motor in a washing machine?
03/05/2015 2:02 PM
On a project I did last year, a 1/2 horsepower single phase motor cost $100 more than the same 3 phase motor. I used the 3 phase motor with an inexpensive VFD.
03/05/2015 2:11 PM
Because in the end it comes out cheaper for washing machines. Remember, electronics are cheap now days so the multi-speed motor becomes a large part of the costs.
03/05/2015 2:17 PM
Good Answers: 54
03/05/2015 3:44 PM
Its a multi speed, since the motor controller changes the frequency of the current to control the speed.
I remember from power electronics that a 3 phase motor speed is dependent on the frequency, since each phase is 120 degrees out of phase from the other two; the stator turns to keep up with the rotating magnetic field.
Back when I was in college, it would've been less expensive and more reliable to use a transmission to control the speed vs electronics and a 3 phase motor. I get it that nowdays, it's less expensive and more reliable to control the motor speed with electronics.
Good Answers: 54
03/05/2015 3:46 PM
GA for coming up with the manual on the unit. You got the correct model!
Good Answers: 151
03/05/2015 2:29 PM
I think using a 3 phase motor with a VFD is done to eliminate the mechanical transmission which used to be the most expensive and vulnerable component in a washing machine
Good Answers: 54
03/05/2015 3:30 PM
I think you're right. When the washer wouldn't drain, I thought it might be the transmission, but there isn't one on this washing machine.
So using a VFD, the speed is controlled by frequency vs a mechanical transmission. Less cost due to a simpler manufacturing process and probably less parts.
03/06/2015 12:34 PM
Spot on!
Also, the VFD allows many speeds both for washing and spinning plus simple electronic reversing!!! Mine goes up to 1600RPM when spinning....I am sure there are even faster machines out there.
Good Answers: 225
Re: Why Use a 3 Phase Motor in a Washing Machine?
03/05/2015 3:36 PM
A number of reasons:-
Because they also use an inverter to create the 3 phase, they then also use it to vary the frequency of it, this allows them to vary the motor speed over a very large range for the different wash cycles without the need for complicated gearing.
They don't have any brushgear.
Traditional split phase motors have a finite number of starts per hour due to overheat concerns, hence the expensive gearboxes and clutches for agitator action, the 3 phase motor has no such issues and so direct drive can be used.
The 3 phase motor has greater starting torque and more power for a smaller package, some of them are almost flat.
The electronics are much cheaper and getting more so all the time. Earlier 3 phase units required 3 Hall sensors and up to a dozen wires between the motor and the controller in order to achieve commutation, latest technology uses just one sensor and a logic control chip in the motor itself.
You may even find that the pump in the machine is also 3 phase, again because there are no brushes, its a smaller package, and it's much easier to reverse rotation for recirculation and drainage processes.
Good Answers: 54
03/05/2015 3:53 PM
I just realized that a front load washer may not be able to have a transmission. The drum is very large and it's belt driven from the motor. Due to the size of the drum (depth), the pulley for the belt is right at the back of the unit - no room for a transmission behind it.
I guess a transmission could be incorporated into the open cavity below or above the drum (in one of the four corners), but it wouldn't be the same as the top load washer transmissions, which attach directly to the drum.
Good Answers: 97
03/05/2015 4:03 PM
I'm curious to know what type of motor drive line and load filter or reactor is used.
I don't see it in the diagrams.
CRTL-Z
Good Answers: 122
03/05/2015 5:55 PM
Speed control management and energy savings.
03/05/2015 11:52 PM
Yes 3 phase is common, and look at the growing THD occurring at the distribution network level with all these household devices coming with switch mode power supplies and VFDs. If the harmonics are addressed with active filters, see how they magically disappear from the lower harmonics only to appear above the 51st harmonic.
Good Answers: 97
03/07/2015 10:19 AM
As the pumps I am associated with, have built-in phase monitoring, I find what you say to be absolutely true. The difficulty of filtering these harmonics at a very low current electronic component level, from VFD transient line noise, is difficult indeed. The EU has regulations governing these transients, The U.S. does not at the present.
CRTL-Z
03/06/2015 4:27 PM
Oh, well. There goes my normal source of 110V motors for tinkering!
Robert A. Heinlein (1907-1988) "There is no worse tyranny than to force a man to pay for what he does not want merely because you think it would be good for him."
Good Answers: 225
03/06/2015 4:33 PM
Yeah - but these new 3 phase ones are normally permanent magnet devices, so you can quite easily convert them into 3 phase generators, lots more scope for tinkering.
03/07/2015 12:07 PM
For the same reason most sanitary mixing tanks have a three phase motor on the mixer and a 120VAC VFD to run them. Where I work we build about a hundred of these every year and it is the lower cost way to go.
03/08/2015 1:27 AM
Many of us got caught by the same design flaw in the $mall controller board(dollar sign added for emphasis). BTW: I seem to recall that the motor also carries a 400 VAC rating on it--increase the voltage while producing 3-phase and provide the same power with smaller gauge wire.
clint.bowman@comcast.net
Good Answers: 804
03/11/2015 5:14 PM
As mentioned earlier, speed control, inherent reversing capability and energy savings. The motor efficiency it typically a lot better, as in 10-15% better, which is a large part of the energy consumption of a washing machine. Then also when running the pump, which is a goodly part of the typical cycle, you can vary the flow without using a valve and save energy by reducing the losses associated with running the pump at full speed and choking off the flow. The energy saved improves their overall energy efficiency rating of the appliance, which in some areas is now mandated to be at minimum levels unattainable with older less expensive designs.
10/21/2019 10:28 AM
In the same line, I have a GE 175D5106G036 3 phase motor and want to use it in a band saw. I have been looking everywhere for the layout of the pins and haven't found it yet. Any help will be greatly appreciated. thanks you all.
10/21/2019 10:53 AM
Use a sensitive Ohm Meter to identify the fields and their connections. Its not rocket science!
This should help:-
How to Check Winding Resistance on a 230/460V, 3-Phase, 60Hz
10/22/2019 6:16 PM
Thanks a lot!
Good Answers: 804
10/21/2019 9:06 PM
That GE motor is only about 1/2HP and is not designed to be used on a machine like a band saw, it will get full of dust and debris and fail quickly. They purposely don't give you the pin-outs because they don't want the liability of someone using it inappropriately like that.
Register to Reply 23 comments
Andy Germany (2); Autobroker (4); bluebelly (1); clint420601 (1); cristle (1); gringogreg (1); jack of all trades (1); JRaef (2); Kilowatt0 (1); LRamos (2); Phys (1); SHOCKHISCAN (1); SolarEagle (1); spades (2); Unredundant (2)
