Previous in Forum: RIP Terry Pratchett   Next in Forum: Zebra Frac Water
11 comments
Perplexity
03/13/2015 10:58 AM
Hello,
can someone help me clarify the following subject:
from equation mc^2=hf ( m=mass , c=speed of light , h=Planck's constant , f=frequency),rewritten as mc^2=h/t, what inerpretation would have the new equality,mt=h/c^2 derived from the previous one.
Thank you.
User-tagged by 1 user
Re: Perplexity
03/13/2015 11:16 AM
c=+/-(SQRT(h/tm))
Re: Perplexity
03/13/2015 11:45 AM
You're using t=1/f in there. In this case, t is not just some time period picked out of nowhere, it's the period of the wave. I can't think of any reason for wanting to express the equality in the form you've written it.
Re: Perplexity
03/15/2015 3:00 AM
To calculate the quantum unit mass of the energy?
Where the Quantum Energy of E is substituted for mc^2 (I don't believe mc^2 is the complete relativity value.)
I believe the quantum energy equation would read E=h/2pi *v where v is the frequency. By defining v as c/l where c is the speed of light and l is the frequency of the radiation it becomes
mc=h/2pi* l
m=h/2picl
Is that possible?
Also; when using h it often resolved to h/2pi; that is the figure often used for h. You see what a picl that could cause?
Re: Perplexity
03/15/2015 3:08 AM
l = wave length not frequency.
Good Answers: 137
Re: Perplexity
03/16/2015 12:30 AM
No, it isn't. It should be c^2 or the dimensions are wrong. Also E = h/(2*pi)*v is only correct if v = angular frequency, radian/s = 2*pi*f, so it comes back to E = h*f.
What is "the complete relativity value"?
Re: Perplexity
03/16/2015 2:10 AM
Thank you for the education.
I had seen the famous e=mc^2 in some other form many years ago.
Good Answers: 137
Re: Perplexity
03/16/2015 7:16 AM
No problem, actually h/(2*pi) comes into formulas so often that physicists define it as ħ (h-bar). Or at least they did when I graduated nearly 50 years ago!
Re: Perplexity
03/13/2015 5:51 PM
Since Planck's constant h and the speed of light c are both constants, the interpretation would be that the two variables m and t, when multiplied together, form a constant quantity.
You should now draw your own inferences from that.
Good Answers: 137
Re: Perplexity
03/14/2015 5:33 AM
It means that a photon, though it has zero rest mass, has relativistic mass h*f/c^2. And momentum h*f/c.
Re: Perplexity
03/14/2015 3:35 PM
There is an uncertainty in mass. "Virtual" particles can exist for some short time, the amount of time being inversely proportional to mass.
http://rationalwiki.org/wiki/Virtual_particles
Re: Perplexity
03/24/2015 8:53 AM
What about non-virtual (real) particles? ΔxΔp ~ h such that for any particle (say a proton) whose position is entirely fixed to a very finely known position, the momentum of said particle can be completely uncertain (can be anything from a very low number to an exceedingly high one, perhaps high enough (energy) to capture an electron perhaps and produce a zero temperature neutron (that would be a really, really cold neutron). Other captures related to the the electron capture could lead to tritium, or even something I call "quatrium": 4H, which although it has a bound ground nuclear state, is pretty unstable with respect to 4He + β. Net result? low energy nuclear fusion, and Brillouin Energy is soon to go public when the COP exceeds a factor of three over energy input. They are up into the COP~2 area now, that I am aware of.
The thing about mass x period might imply that the natural frequency of more massive objects has to be higher than less massive ones, but this seems counterintuitive as we already know the Larmor frequency is more dependent on the inverse of size.
Register to Reply 11 comments
Codemaster (3); Gavilan (3); James Stewart (1); JohnDG (1); Massey (1); Rixter (1); Usbport (1)
