Previous in Forum: What is the Minimum Safe Distance to Locate a Substation from a Classified Plant   Next in Forum: 60Hz, 220-240 V Treadmill
10 comments
Substation Cut Out Inputs
03/15/2015 7:48 AM
What are the inputs required to prepare the substation cut out details.
Good Answers: 109
Re: What are the inputs required to prepare the substation cut out details.
03/15/2015 8:46 AM
You are way over your head here.
Cut out the substation first and then look at the inputs.
Is it maybe possible that you send the full scope of work that has been assigned to you so we can find professional help?
You will need to pay a consultant to do your work.
03/15/2015 11:43 AM
You are obviously NOT QUALIFIED to be asking these questions and most certainly NOT QUALIFIED to be working on or designing such systems.
Now, go away, before you kill someone.
03/15/2015 4:13 PM
03/15/2015 4:43 PM
Get whatever company you work for to hire a professional consultant, given the questions you are asking on CR4 you should NOT be performing this kind of incredibly dangerous work.
Re: Substation Cut Out Inputs
03/15/2015 11:57 PM
Somebody had to do it.
03/16/2015 12:07 PM
Hey... can you make those out of bacon?
03/16/2015 5:20 PM
Sure. Regular or crispy?
03/17/2015 2:27 PM
Mmmmmm... bacon shirts!
03/17/2015 2:39 PM
Their all the rage down in the Hamptons.
Good Answers: 42
03/20/2015 10:25 AM
What do you mean by Substation cut out ? In the first place the question appears to be a question put up to you in interview/ test which you did not understand and want some one here in this forum to explain to you . Normally a circuit breaker is installed at the incoming Cable or Overhead line feeder to the substation which is used to switch On/ switch Off power to the Substation .It can a ACB, OCB, MOCB, VCB etc depending up on the Voltage and kVA / MVA capacity of the Substation( Indoor / Outdoor) . So all details are required to give you a technical answer. So study your problem understand it and come back with a question.
Register to Reply 10 comments
Doorman (2); IdeaSmith (1); jack of all trades (2); lyn (3); SolarEagle (1); V.I.Abraham (1)
