Previous in Forum: Tap Set   Next in Forum: Another Question about Gaskets !!
Marine Engine for Road Use
07/11/2007 6:14 AM
Hi,
I have been asked to adapt a marine engine (V6 Johnson Evinrude I think) for use in a car for motorsport use. The engine has no thrust bearings on the crankshaft, and I need to fit a gearbox and clutch, which will put thrust on the crankshaft. I am just wondering as to how to go about removing this trust, that I will have added, from the engine. Is there a gearbox with an enclosed clutch/flywheel out there, so all I will need is to get a driveshaft made up, or will I have to add bearings of some sort outside the engine? Thank you in advance.
Re: Marine Engine for Road Use
07/11/2007 10:53 PM
Your Best bet will be to ask for help/Co-operation-Hardware from
http://www.teng-teng.com/pros.htm
Pose the problem-ask for a mutual development effort.
You will enjoy visiting Wenling -and their Techteam is full of young friendly enthusiasts.
07/12/2007 9:59 AM
There are some small road racing cars that use outboard motor power heads.
SCCA Formula 500.
I built a Garden Tractor for Pulling Competition using an old inline Mercury 6 cylinder.
I used a "1-1/4" Four Bolt Flange Bearing (Large Housing) SKU: UCF207-20" with a tapered roller bearing hooked to the crankshaft of the Mercury with a flex coupler. I cannot remember what I used for a transmission except it was a small tractor trans. I also built a Trike using a the same engine with a snowmobile CVT drive. It worked quite well and was very fast.
I would look into the F500 for what you need as know they use snowmobile and outboard motors.
Good Luck
07/15/2007 7:37 PM
This sounds very promising! How did you go about cooling this engine, since a marine engine uses a waste system, and thats not really an option on land! How did you attach the gearbox to the engine, or were they able to be sort of independant? I have come across a Harley-Davidson gearbox, the Sputhe made gearbox, as it attaches to the crankshaft via a belt, and has the clutch enclosed with the gearbox, which seems like a possible method of getting power to the wheels!
07/12/2007 11:14 AM
Strangely enough, I ran into the opposite problem a few months back, which was putting a Ford 3.8l V6 into a custom boat. My boss had the engine and I had to make it work. What kind of horsepower/ torque are you working with, and what kind of car is it going in?
07/15/2007 7:32 PM
Well, I think I'm looking at 200bhp, but far more torque, in the high 300's. It will be going into the back of some small car like a fiat, or opel corsa, that size car, for autograss use.
dollysviking (1); Graham (2); MUKULMAHANT (1); prbarry (1)
