Previous in Forum: Question About Thinner   Next in Forum: Energy Consumption in a Crude Oil Refinery Distillation Process
Engineering Fields - Chemical Engineering - New Member
Calculating Partial Pressures of Air Chlorine Mixture
03/16/2015 1:02 PM
If I have 100kg mixture of air* & chlorine, total pressure of system is 60mmH2O how can I get either mole fraction ratio or partial fraction ratio. The real problem I am facing is that air too is mixture how then can I get its vapour pressure at say 25C temperature
*dry air may be considered to be 78% Nitrogen ( M.W. = 28.0), 21% Oxygen (M.W. = 32.0), and 1% Argon (M.W. = 40.0) Thus Average Molecular Weight of Air = (.78 * 28) + (.21 * 32) + (.01 * 40) = 28.96g/mol
Chemical Engineers are like high Temperatures & high Pressures
Pathfinder Tags: Ideal-Gas
Good Answers: 125
Re: Calculating Partial Pressures of Air Chlorine mixture
03/16/2015 1:53 PM
Looks like homework to me.
Try this, which one obtains from a google search.
Re: Calculating Partial Pressures of Air Chlorine Mixture
03/17/2015 12:27 PM
Use PV=nRT instead of PV=mR'T. Then works on PV=( nair+n cl) RT= PV air + PV cl
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
Good Answers: 137
03/26/2015 7:38 AM
From the information given, you can't get either. You only give total mass, but you need to know the masses of air and chlorine, then you can work out mole fraction and partial pressure of each.
Register to Reply 3 comments
Codemaster (1); Kulas (1); WJMFIRE (1)
