Previous in Blog: Electric cars come back to life   Next in Blog: Monorail made from wingless airplanes
10 comments
How I built an electricity producing wind turbine
Posted January 25, 2007 3:03 PM
From del.icio.us hotlist:
How I built an electricity producing wind turbine. Several years ago I bought some remote property in Arizona. I am an astronomer and wanted a place to practice my hobby far away from the sky-wrecking light pollution found near cities of any real size. I found a great piece of property. The problem is, it's so remote that there is no electric service available. That's not really a problem. No electricity equals no light pollution. However, it would be nice to have at least a little electricity, since so much of life in the 21st century is dependant on it. One thing I noticed right away about my property is that most of the time, the wind is blowing. Almost from the moment I bought it, I had the idea of putting up a wind turbine and making some electricity. This is the story of how I did it. Not with an expensive, store-bought turbine, but with a home-built one that cost hardly anything. If you have some fabricating skills and some electronic know-how, you can build one too.
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
Re: How I built an electricity producing wind turbine
01/25/2007 11:56 PM
nighthawk:
Thanks for an interesting article!
Greg
"The more I learn, the more ignorant I realize I am."
01/26/2007 1:52 AM
Hi There,
It's great and i'll try to make one.
Thank you for the post.
01/26/2007 3:54 AM
For comparison, a major DIY chain in the UK has just begun retailing a domestic wind generator of about the capacity indicated in this article that retails for just under £1500 including professional installation and local taxes. The value of the electricity produced under average UK wind conditions is just sufficient to amortise the investment over 12 years or so, so unless one can add value to a property by installing one, the economics are only marginally attractive - at the moment. That will change: as the value of electrical energy goes up and the all-up installed cost comes down, the attraction will rise over time. In the UK, a Planning application needs to be approved in most cases before one may be installed on the home, adding to the cost.
Of course, a home-brew one would knock a big chunk out of the £1500 above...
Very informative, and thank you for an interesting post.
01/26/2007 5:20 AM
Hi nighthawk, I built my own windturbine 30 years ago while living in Norway. First I salvaged an alternator from an old Volvo PV, then I salavaged the wiring and components such as the AC to DC converter from a Ford Granada. I then constructed a gear-box with cogs from an old lathe so as to gear up the alternator 1:4. At the time halogen bulbs for motor car use had just come on the market in Norway. I bought 4 car batteries of 60amp each and proceded to light up my log cabin in the middle of nowhere. This was such a success that I made a further three for my friends. Since then I have often wondered why nobody else has thought of this.
01/26/2007 10:49 AM
Excellent post. Thanks!
Perhaps I shouldn't admit this, as there may be some automotive restoration buffs who have me pilloried...
But I used the dynamo/generator from a 1962 Alfa Romeo 2600 cabriolet in my wind turbine. If/when it fails I've got a similar piece from a 1962 Allis Chalmers D-15 tractor.
High tech need not be high tech!
Give me Liberty, or give me my Money Back!
01/26/2007 6:45 PM
Hi Nighthawk, thanks for the inspiration. Awsome piece of land you have!! I've been dreaming about building an electricity producing wind turbine for a long time. In my design I want to use an automotive altenator. They come fairly cheap, already has a pulley on and have mounts. (I want to step up the rpm with a fanbelt thus have the turbine on a seperate shaft with two heavy duty bearings.) This way I can also put more altinators around the same shaft... Altenators have a far better efficiency than generators and they have a build in regulator. Disadvantage , they need power to make power, so if the battery is totally runned down it might not generate any power. Also another question is ...Does the build in regulator/rectifier suited to charge more than two,three four batteries? What will the case be when the amps are so high? Can any one comment on this?
Also inspired by this design of wind turbine .. Posted earlier in Cr4
"Remember... if women don't find you handsome, at least let them find you handy." - Uncle Red
01/27/2007 4:45 AM
Hi oomsarel, If it is not a problem in a motor car then there will be no problem when using an alternator with a wind turbine. Most commercial turbines use an alternator. You will not have a problem charging 1 or 100 batteries. The turbine I built 30 years ago is still going strong, and it will as long as I clean and grease it once a year.
01/26/2007 7:57 PM
Oh, and take a look at Mike's telescope and turbine pages (linked on the bottom of his windmill writeup)...this guy does a lot of fun stuff!
01/27/2007 7:04 AM
its great and i love it
01/29/2007 11:37 AM
Use single pole alternator, no input current field needed. One positive to + baterry terminal, The - baterry terminal is to the chassis. It has internal voltage regulator.
It has self generating internal current field. I think Bosch make this one.
Usually is used for Genset. American made should be available too, Delco Remy ?, check around. I used to test those alternators.
Use the AC condenser fan , 26 to 36 inches are better with high pitch angle, 33°.
the hub size is interchange from 1/2" 5/8 and 3/4".
One 12-Volt battery with high storage capacity of 100 Amphour.
Use should be able to make this less than $ 700.00.
Armanto
ME
andyhorning (2); Anonymous Poster (1); Avadiar siva (1); Greg G (1); jon (1); oomsarel (1); PWSlack (1); Scapolie (2)
