The question as it appears in the 05/24 edition of Specs & Techs from GlobalSpec:
Imagine a smooth metal ring running around the Earth's equator about the width of a sidewalk. Now imagine a metal cable wrapped around this first ring so tightly that nothing can squeeze between the cable and the ring. You may assume that the ring and cable are perfect circles. Now this cable, which does not stretch, has three extra feet added to it and is made to magnetically float up and off of the ring so that extra three feet of slack is then equally distributed around the Earth. This now gives you an equal distance between the ring and the cable anywhere you checked it around the planet. What is that distance? What about if you do this using a soccer ball instead of the Earth? Is there a way to make sense of this without resorting to math?
