Previous in Blog: Climbing a Ladder in a Pipe (April 2026 Challenge Question)   Next in Blog: Sensors and Senseless (June 2026 Challenge Question)
17 comments
Who Watches the Watchmen? (May 2026 Challenge Question)
Posted April 30, 2026 12:00 AM
My watch is 1 second slow.
Your watch is 1.5 seconds fast.
We both agree to stand here until the show the same time again (12 hr clock)
Question 1: How long will we stand here, waiting for the watches to display the same time?
After that we will leave. But we will meet back up when we simultaneously have the correct time again.
Answer, updated 5.27.26
Rixter gets it, in answer No. 9 (down below)
Question 2: How long until we meet back up again?
Re: Who Watches the Watchmen? (April 2026 Challenge Question)
04/30/2026 7:46 AM
What does "1 second slow" mean, "one second behind real time", "one second per day slow", "one second per hour slow", etc?
04/30/2026 9:58 AM
That's a great question! Taking it to the absurd extreme of both errors being per second, one watch would stop, while the other would run 1.5 times too fast. The next uncertainty is the range of the watches: 12-hour, 24-hour, weekly, monthly, lunar cycle, tides, or even the rare watch that tracks the numeric year.
05/01/2026 10:32 AM
OK, let's assume it means loses 1 seconds per hour and gains 1.5 seconds per hour and they both start out at the same time.
If you took a picture every hour, "My watch" second hand would back up 1 sec, "Your watch" would move forward 1.5 seconds, gaining 2.5 seconds per hour on mine. It would gain 1 minute in 24 hours, 60 minutes in 60 days, and 12 hours (the same time) in 720 days.
Add a third watch which runs perfectly. "My watch" loses 1 second per hour, 24 seconds per day. There are 60x60x12=43200 seconds = 1800 days between times "My watch" shows the correct time.
"Your watch" gains 1.5 seconds per hour, 36 seconds per day. There are 43200/36 = 1200 days between times "Your watch" shows the correct time.
The times that all three watches show the correct time are every 3600 days, providing that they all correspond at all..
So, the two watches will match after 720 days. For all three to match, a total of 3600 days or 2880 after the first meeting.
Question 1: How long will we stand here, waiting for the watches to display the same time? 720 days
Question 2: How long until we meet back up again? 3600 days
Reply Good Answer (Score 5)
05/03/2026 6:56 AM
Clarification of #9:
Times "My watch" is correct: 0,1800,3600,5400,... hours
Times "Your watch" is correct: 0,1200,2400,3600, ... hours
Both correct: 0,3600,7200,... hours
05/03/2026 11:01 AM
Oops, should be days...
Times "My watch" is correct: 0,1800,3600,5400,... days
Times "Your watch" is correct: 0,1200,2400,3600, ... days
Both correct: 0,3600,7200,... days
05/29/2026 11:09 AM
This is a Deceptively Simple Situation.
IF THE CLOCK SPEED IS THE SAME (correct speed) on both watches:
1: each watch will show the same time again in exactly12 hours.
2: since one watch is showing slow, and the other watch is showing fast, but running at the same clock speed, they will NEVER show the absolute correct time. You can wait till the cows come home.
Re: Who Watches the Watchmen? (May 2026 Challenge Question)
04/30/2026 10:34 AM
Should this read something like:
1 second per hour slow.....
05/01/2026 12:38 AM
If you assume both timepieces keep perfect time, and the display is 0:0:0 to 12:12:59, it seems that they could never be the same? Or could they?
05/29/2026 9:24 AM
On a 12-hour digital display, the numbers would run 0:0:0 to 11:59:59.
05/29/2026 10:34 AM
Well, no, that isn’t correct.
A digital watch set to display in a 12 hour format would display a range of 12:00:00 (midnight or high noon) to 11:59:59.
A digital watch set to display in a 24 hour format would display the range of 00:00:00 (midnight) to 23:59:59.
05/01/2026 3:07 AM
The statements are 1 second slow and 1.5 seconds fast. There is no reference to gaining or loosing time therefore there will always be a difference of 2.5 seconds. That means we will be standing there in perpetuity!
Tony Aston
05/01/2026 7:12 AM
So using a 12 hr. clock, it is irrespective of how fast or slow the two watches are without knowing the frequencies of the two time losses. Per minute, per hour per day etc.
Are both watches gaining / losing time equally or does one gain / lose a minute and the other per hour ?
On the assumption that the gains / losses are per Minute both watches will read the same time 12.00 24 hours later.
Good Answers: 27
05/01/2026 8:22 AM
Not quite clear on the type of watch (digital or analog) in question, but normally for (my watch), or whoever looked first on his/her's own timepiece will always note to have a slower time.. a lag in time.
The time difference can be due to the person's response or reaction time, rather than the type of watch the other person is wearing.. in noting the others actual (your watch) time..
Whenever you and I agree to put our watches side-by-side and look at the same instance together, in my view will determine the time in question.
Since both watches, yours and mine hopefully will continue to keep on ticking, while time passes..
vsar
05/01/2026 9:05 AM
The possible source for this challenge, from Chegg:
8. My watch is 1 second fast per hour and my friend's is 1.5 seconds slow per hour. Right now they show the same time. How many days later will they show the same time again?
At this time, if I insert a credit link to Chegg I get zapped as a spammer.
05/08/2026 8:54 PM
Answer: How long it takes for us to both reset our watches to the proper time. So around 5 minutes
05/15/2026 7:15 PM
Answer 2: After we have reset our watches we can wait a while, then check if our watches are out, and if they are we can then calculate the error and the time taken to give the error, and then calculate a theoretical time when we would come back and have the watches the same again
However this would never happen, because a watch is there to serve the wearer, so, it would be pointless wearing a watch that is out for so long. The watch would be updated or reset to make it in time again
We could then just say that next time we meet we can reset the watches to be in sync again so the answer is: How long until we meet back up again? When ever we decide to meet up next. since we are probably friends and think more of our friendship than a watch
With math's there's mostly right and wrong answer's, but with people there's mostly better or worse solutions
05/18/2026 4:03 AM
Great puzzle, the watch drift math is deceptively simple until you actually sit down and work it out. Took me a minute but satisfying once it clicks
Doorman (2); El Perro Grande (1); fzitta (1); Randall (1); redfred (1); Rixter (4); rwilliams (1); The Wizard (1); Tony Aston (1); Uffasy (1); vsar (1); VSted (2)
