Electronic Components Blog
The Electronic Components Blog is the place for conversation and discussion about analog/mixed signal, discrete & power devices, processors, interface & logic, passives, and memory. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Is the iPad a Technological Missing Link?   Next in Blog: Smartphones Predicted to Be PC Killer…
5 comments
Can a Transistor be Junctionless?
Posted April 07, 2010 7:52 AM
Irish researchers from the Tyndall National Institute claim to have developed a novel transistor exhibiting ideal electrical properties thanks to its junctionless configuration. Resembling an old transistor design initially proposed in 1925, the group's device consists of a silicon nanowire and a silicon gate, which is separated from the nanowire by a thin insulating layer and controls current flow in the nanowire.
The preceding article is a "sneak peek" from Electronic Components, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Electronic Components today.
Re: Can a Transistor be Junctionless?
04/07/2010 1:01 PM
I do not see much of a difference between this and a MESFET. I'll admit that patent protection may be obfuscating the details. But why would they then reference a 1925 design while simultaneously claiming a new transistor.
06/14/2010 11:46 AM
In a MESFET there is a Schottky junction forming the gate. Here, the device is a MOSFET. There are no junctions from source to drain and no Schottky junction. The use P-type polysilicon on the N-doped device allows one to obtain a desired threshold voltage, butr you could use a metal such as platinum instead.
04/09/2010 2:46 PM
I suspect that they mean that it does not have a traditional diffused junction, but a metallic & insulator "mechanical" junction. It would be interesting to know how low the heat/resistive losses are for the source-drain path, and how that relationship varies with gate applied voltage.
04/20/2010 9:13 PM
I think the heat/resistive losses will be the same but it could work at higher temperature.
06/14/2010 11:48 AM
It has the same heat losses as any transistor, but it works at higher temperature. See the article "High-Temperature Performance of Silicon Junctionless MOSFETs", Chi-Woo Lee, Adrien Borne, Isabelle Ferain, Aryan Afzalian, Ran Yan, Nima Dehdashti, J.P. Colinge, IEEE Transaction on Electron Devices vol.57, no.03, pp.620-625 (2010)
