Previous in Blog: Trading Digital Privacy for Convenience   Next in Blog: Computer Chips Inspire New Water Purifier
2 comments
Philips Ups Ante on LEDs with 60-Watt Bulb Replacement
Posted April 14, 2010 11:31 AM
From GreenBeat:
Just a week after General Electric unveiled its light-emitting diode bulb capable of replacing 40-watt incandescents, Philips has already one-upped it, announcing that it will start selling an LED equivalent of 60-watt incandescents by the end of the year.
Re: Philips Ups Ante on LEDs with 60-Watt Bulb Replacement
04/14/2010 12:28 PM
Yes! Look forward to finding those under my Christmas tree.
Not so much for the electricity savings, but heat savings. In Florida that makes a difference.
Good Answers: 11
08/05/2010 8:41 PM
AH,
Have you tried any LEDs yet? I've installed a few for trial 1W to 3W reflective type in both 12v and 240v with generally good results.
One fitting which I bought with 2 x 10w CFLs in it killed the top lamp so I installed a 1w LED in its place, the light was definitely better and the instant on was better than waiting to see if the CFL would light but the fitting killed it too. I took the fitting out and did some rewiring and installed a 3w downlight shining into the same stairwell from above.
I replaced most fittings with recessed downlights containing 20w CFLs some time ago so am comparing. When the new lamps become available, I'll once again become an early adopter.
I replaced the incandescents mostly for better light quality and I've definitely achieved that. The whole thing is a work in progress especially such locations as my electronics workshop and my metal working machines, as better lights become available I will use them. I will when I get to it see how LEDs work over rotating machinery, obviously strobe is the issue in question. Presently I have a 12v 50w halogen on the body of my mill, while the light is good it has burnt my forehead a few times.
Where I've found CFLs to be of limited benefit is the PAR38 lamps in the sensor lights, at least one incandescent is needed to operate reliably.
