Workbench Creations Blog
Workbench Creations
Previous in Blog: DIY Peddle Tractors   Next in Blog: The Continuing Adventures of Home Renovating Noobs
5 comments
Kitchen Renovations, Part 4
Posted May 21, 2010 9:00 AM by frankd20
Cabinet Installation
Putting in cabinets can be rewarding, but it is one thing that you should measure twice before securing everything in place. I started with wall cabinets since it's easier to get to without the base cabinets in the way. I set them at the standard height using a simple bracket made out of wood. The bracket was mounted to the wall so that I could rest the base of the cabinet on it and it would be at the correct height.
I first removed all the doors on my cabinets to make setting them easier. Once the first cabinet was level and at the right height, I secured it into the wall. I had a long level and some clamps that I used to help me with the rest of the cabinets. Since I wanted to make sure the tops of all the cabinets were level, I clamped my level to the first cabinet and then put up my second one and clamped it to the level as well. I moved down the wall, sliding the level down each time and clamping the next cabinet to it before securing it in. When I was done, all the cabinets were nice, level, and at just the right height.
The base cabinets were a little more difficult since my floor wasn't quite as level. It is important to get the tops of all your base cabinets at the same level since the countertop needs to sit on top of them. To do this, I used a bunch of shims, my long level, and clamps. First, I had to find the highest spot on the floor so I knew where all the other cabinets needed to come up to. As I said in an earlier post, my floor had a half-inch drop to the center and although I needed a few shims to reach this for some of the cabinets, it wasn't that difficult.
The process was basically to put a cabinet in place, get it level, and then place one next to it and make sure they were even. This took a bunch of trial and error, moving shims around and putting the level in different places until I was happy everything was level. With the cabinets all level, I screwed them into the floor and wall to lock them in place.
Re: Kitchen Renovations, Part 4
05/22/2010 3:10 AM
you are doing a great job... After installing several hundred of them though I found it easier to use a laser level to set the cabinets. If you set it up before you set the first one you can put a line around the room at the proper height then all you need is a smaller level to get them from front to back.. It is a very rewarding job when you step back and look at it and say I did that... Keep up the great work..
05/22/2010 9:16 PM
I have an old house. Nothing in it is square or level. One time this contractor about went crazy trying to get everything square and level. The solution was to set the square and level aside and align everything with the existing architechture. Otherwise it looks funny. The only thing I level are my record turntable and my appliances. Especially my range. I prefer not to have my eggs run to one side of the pan.
Of course it helps to have a good stove. My brother had bought a new range and none of the burners were level. When it began to fall apart we replaced with an older Frigidaire build-in unit I had in storage. He was amazed at the difference in quality.
05/24/2010 2:56 AM
Hi frankd20,
Your kitchen is starting to come together and looking very nice. Good job.
Here in the UK almost all base cabinets come with adjustable legs; which can be screwed in and out by hand; negates the need for messing about with those dam fiddly shimmy things. Is this type of thing available in the USA. Also the wall units are hung on two metal wall bracket via an adjustable hook like assembly attached the the cabinet. The level and fixing can then be adjusted from inside the cabinet. These things are alot more fiddly, especially when your walls are not perfect.
Keep up the good work.
Ireland - Member - New Member Engineering Fields - Energy Engineering - New Member
05/24/2010 9:14 PM
Well done always like to see someone do something themsleves.
A few comments. There are 3 things in the building trade that do not exist:
  1. Level floors
  2. Plumb walls
  3. Square corners
Once you get over the anger, frustration and shock at the above, you start to treat building work as a puzzle to solve and not as a self-assembly kit.
I am a big fan of Sir Norm Abram (at least he should be knighted ) and I have seen adjustable feet on cupboards and adjustable wall brackets for cabinets on his show. Honestly these are much more effective than shims and wedges etc.
Pardon me for saying, but you seem to have an enormous dearth of socket outlets. Suggest you add copious amounts more before tiling. Also no outlets for under-sink devices, such as disposal units etc. Just a comment.
Keep up good work.
I love deadlines; I love the whooshing sound they make as they pass by. - Douglas Adams
05/24/2012 8:32 AM
I think you got lots of experience because you have explained it like a master. Perfect work needs pure dedication towards work and it looks like that you are totally dedicated towards the work.
renovations burlington
Anonymous Poster (1); BabyGuinness (1); Charlie Greenwood (1); jackswwagar (1); Ric Bennett (1)
You might be interested in: Cabinets and Casework, Biological Safety Cabinets
