Having snakes as pets can be a very rewarding
experience - as long as you are well-educated about your pet.
General
Responsibilities
At first glance, it may look like snakes are easy
to take care of, but there are many rules that a snake – or any reptile – owner
must follow. Most of these rules are dependent on the type of animal you have.
Housing
When it comes to cage size, the bigger the better!
Baby snakes can be housed in 5-10 gallon tanks. Young snakes grow quickly,
however, so they will soon need larger cages. To keep from spending a lot of
money, many people keep their young snakes in modified Tupperware containers
until they are sold, or old enough to be kept in adult snake cages.
All reptiles must be given a place to hide. A hide
can be a half-log, a plastic container with a hole cut in it, or a shoebox. The
hide is a place to which the animal can retreat when it sleeps or needs a dark
place to feel safe. Elevation change is important for all reptiles, especially
arboreal snakes. Not only will it make the enclosure look nicer, but it will
provide the animal with something to climb on and keep it more active.
The cage must have a warm side and a cool side.
The efficiencies of a snake's bodily functions are often dependent on the
ambient temperature. These temperatures are determined by the species of snake.
Snakes that are native to warmer areas require warmer cage temperatures. The
required level of humidity is also species-dependent.
Water must be refilled and replaced regularly. The
cage must also be checked daily for feces. You should also make sure that the
cage door is secure, or that the lid has a lock or something heavy on top to
prevent your snake from escaping. Avoid aromatic substrate, or bedding, because
it can irritate the snakes. Some substrates are designed to retain moisture for
snakes that require higher humidity; however, these substrates are more likely
to grow mold. Some are better for burrowing, some are washable and reusable,
and some just look better than others. It is your job to determine which is
best for you and your snake.
Feeding
Newborn snakes are usually fed every week.
Juvenile and adult snakes are usually fed every other week. Larger snakes, like
large pythons and boas, can have larger gaps between feedings. No matter what
feeding schedule your snake is on, it is very important that the feedings
happen regularly. Snakes become accustomed to feeding schedules and are likely
to become restless if a feeding day is missed. They are also more likely to
mistake your hands for food, especially if you have recently handled a small
mammal.
Although some snakes only eat fish, birds,
rabbits, frogs, or lizards, most are content with frozen/thawed mice or rats.
Frozen mice are easy to buy and store in large quantities. This is very
convenient for snake owners because buying or breeding live food can take a lot
of time and money.
Handling
Interaction with your snake is extremely
important. Snakes become familiar and are more comfortable around their
handlers. Snakes with "attitudes" can often be tamed by frequent socialization
with handlers.
When handling a tame animal all you have to do is
support it gently. There is no need to grip onto the snake. Otherwise, it will
feel trapped and is more likely to become frightened. For more skittish
animals, on the other hand, it is better to have a slight hold on the snake.
Handling a nervous snake should be done in a quiet area with very little foot
traffic. The snake will feel safer while around you.
When handling a large snake, make sure that you
have at least one other person around. Even snakes that have no history of
biting their owners can occasionally become frightened, aggressive, or mistake
a body part for food.
Choosing
a Pet
Corn snakes and ball pythons are popular pet
snakes for children. These snakes are relatively inexpensive and, if they are born
and raised in captivity, maintain very even tempers. This is especially
important when they are being handled by children.
Although snakes that are under a few months old tend to
be cheaper, it is not recommended that you purchase them. The death-rate of
young snakes is very high, and they are very easily stressed. At that age,
snakes are also very skittish and will flail when frightened.
Make sure the animal is healthy before adopting
it. Pieces of leftover shedding may indicate improper housing/ humidity, but they
can also indicate a health problem. Any creases in the eye caps means that the
snake does not have full visibility. So know what the snake is supposed to look
like. An abnormally thin animal is very likely to be ill. Check the nostrils
and mouth. Any discharge or bubbling indicates a respiratory infection, which
is common in snakes. Also look for open-mouth breathing, coughing, or loud
respiration. In any of these cases, the seller should be alerted to the
problems so that he or she can take the animal to the veterinarian. If you are
rescuing a snake, a vet should be consulted about whether the snake needs
special attention such as nutritional supplements and specific feeding
instructions.
Size is also a very important factor in choosing
your pet. Corn snakes grow to be about 1.2-1.8 m (4-6 ft). Some rat snakes grow
to be larger. Most ball pythons are only .9-1.5 m (3-5 ft) as adults, though
they have a much stockier build than corn or rat snakes. Snakes this size can
comfortably live in a 30-gallon tank but, as I said earlier, the more room you
can give your snake the better.
Do your research and make sure you know how big
your snake will get and how quickly it will grow. That baby Burmese python may
look really little and cute in its cage now, but within 4-5 years it will reach
its adult length. Not many people have the room, or the money, to care for a
4-6 m (13-20 ft) snake! It's hard to find people who are willing to take in
such a large animal. This is how these large snakes end up on the streets. It
is a big problem in the southern United States. Not only are these snakes not
native to the area, they are also a threat to local wildlife and humans. No one
wants to walk outside and see a 2.4 m (8 ft) python sitting in a bush – this is
how the Snake Room got its Burmese!
In Part II of this series, we will take a look
at common problems new snake-owners tend to have and how to avoid them. Thanks
for reading!
