In October 1909, Nikola Tesla filed his first patent for what has since become known as the Tesla turbine, a rather simple
machine consisting of a stack of closely spaced and smooth-sided discs.
The turbine takes advantage of a fluid's properties of adhesion and
viscosity to either pump that fluid with input from an electric motor
or to use the motion of that fluid to turn the turbine as an engine.
A few months after filing a subsequent patent on the turbine in January 1911, he approached the automotive periodicals of the day, touting the turbine's practicality for automobiles.
Both The Automobile and The Horseless Age described
the turbine in detail, noting that it could run on any fluid, including
steam or gasoline (the latter properly mixed with air and ignited in a
preliminary combustion chamber). The Automobile reported
that, as a gasoline engine, the turbine could achieve 60 percent
efficiency; as a steam engine, it could achieve 95 percent efficiency.
Tesla claimed that a larger engine of the same design installed at the
New York Edison Company's Waterside station made 200hp off of 125
pounds of steam pressure, and that he could develop engines that would
weigh between one and four pounds per horsepower.
Read the Whole Article
