Speaking of Precision Blog
Previous in Blog: 5 Benefits of Cold Work in Steels   Next in Blog: 5 Reasons To Anneal Steel
5 comments
Hardness vs. Hardenability: There Is A Difference
Posted June 25, 2010 8:00 AM by Milo
Don't confuse hardness and hardenability. Hardness is a material property. Hardenability is a way to indicate a material's potential to be hardened by thermal treatment.
Hardness is resistance to penetration. Hardenability describes how deep the steel may be hardened upon quenching from high temperature. The depth of hardening is an important factor in a steel part's toughness.
The brinell test uses a 10mm hardened steel (sometimes carbide) ball and various levels of force applied over a specified time.
The softer the material, the deeper the penetration, the wider the impression.
The width of the impressions is measured optically and averaged. (Wider impressions mean the ball penetrated deeper, thus, the material is less hard.) The Brinell hardness number is calculated by dividing the load applied by the surface area of the indentation. Prior to today's direct reading instruments, the measured indentation diameters could be looked up on a reference chart and the corresponding Brinell hardness number given.
The Rockwell test is similar, but uses different forces and either a smaller ball indenter (Rockwell B scale ) or a diamond indenter (Rockwell C scale).
Hardenability- Jominy Test
In the Jominy test, a standard specimen is heated then water quenched from the end, and a series of rockwell hardness tests are taken in 1/16th inch increments along the length of the specimen.
Jominy test measures potential depth steel will harden.
It is the influence of the steel's chemical makeup (Carbon and Alloying elements) that determine how a deeply a grade of steel will transform to martensite for a particular quenching treatment. This means that for each grade being heat treated, mechanical properties are a result of cooling rate (quench). An excellent web page on this can be found here.
So what of the difference between hardness and hardenability?
Hardness is resistance to penetration under specified conditions of load and indenter.
Hardenability is the ability of a steel to acheive a certain hardness at a given depth, upon suitable heat treatment and quench. Hardness can be measured in steels in any condition. Hardenability presumes that the steels will be heat treated to acheive a targeted hardness at a given depth.
One is an actual property, one is a measure of potential.
And now you know.
Web resources:
Gordon England Thermal Spray Coatings
Farmingdale State College School of Engineering Technologies
Editor's Note: CR4 would like to thank Milo for sharing this blog entry, which was originally posted here.
Good Answers: 58
Re: Hardness vs. Hardenability: There Is A Difference
06/26/2010 7:59 AM
Most material properties we specify are measured in units traceable to standards. These include tensile, yield, elongation, density, surface finish, etc. Hardness is a property that can not be linked directly to international standards. This is why it is often referred to as "superficial hardness". When you push an indenter into a piece of metal you are measuring a property related to the metal's hardness superimposed on the work hardenability of the metal.
06/27/2010 3:39 AM
Well, jumpin' Jominy! I never heard of that one before, but there ya go, hopping along at 1/16-inch increments from one mini-Rockwell test to the next...until they peter out, I suppose.
Australia - Member - New Member Engineering Fields - Mechanical Engineering - New Member
07/01/2010 9:39 PM
Here is an excellent U tube vidio of a Jominy test.
http://www.youtube.com/watch?v=qW0aUbTWtVM
Dont get on to the roundabout if you dont know how to get off
07/01/2010 11:33 PM
That was excellent! I've never witnessed this test; the Charpy test I saw many years ago was cool, though (pun intended).
06/27/2010 8:39 PM
One must also take into account brittleness.
Mr.Ron from South Ms.
Register to Reply 5 comments
garth (1); ronseto (1); Tornado (2); welderman (1)
You might be interested in: Hardness Testers, Linear Shafts, Rotary Shafts
