Speaking of Precision Blog
Previous in Blog: 5 Contributions of Chromium to Steels   Next in Blog: Killed Steel
3 comments
6 Ways Barstock Can Lose Straightness
Posted July 09, 2010 9:00 AM by Milo
Straightness is perishable in bars. Straightness is often lost during handling operations, loading and unloading.
Correct handling preserves straightness. Straightness is critical for holding position and tolerances on today's highly engineered medical, aerospace, automotive and electronic parts.
Here are six ways that bars can lose their straightness.
Six Ways Bar Straightness Can Be Degraded
1) Mechanical damage to an end. If the bundle is struck by a lift truck, or if the bars catch on a rack or table while being hoisted with the crane, this can cause the ends of the bars that are caught to be deflected out of the bundle and bent.
2) Improper blocking and support at mill or on truck. Cold finished barstock, especially smaller diameters, really needs to be supported at multiple points along its length. This reduces the possible radius that the bundle can sag or droop between supports. The mills that I'm familiar with, (PMPA Tech members) are pro's and know the best way to support the product and to package it securely. Reputable mills put more bands on smaller ID bar bundles to preserve straightness when needed.
3) Truck loading and securing. The binders used to secure the bars onto the truck can cause a permanent deformation if they are not matched up with the blocking beneath the bars. I saw a trucker once use a 4 foot piece of pipe as a "cheater" to secure the binding chains 'one more notch.' You could hear the wood underneath the bundle being crushed. Chains are always bad news for cold drawn bars- nicks, and gouges and 'low spots.'
4) Improper unloading. Putting a spreader bar on so that there are multiple points of support for the bundle is critical, especially with the smaller diameter bars and small bundles.
I have seen shops unload bundles by using a single "hitch" at the approximate middle of the bundles. This causes a permanent camber over the length of the bars. Jerky crane lifts rather than smooth movements can magnify this effect.
Image above: This is bad...
5) Hand unloading or using a forklift. Small diameter bars especially can be bent by the way they are manually pulled out, lifted, and carried, instead of being placed on a table or rack. Using a forklift can also cause bars to be bent.
6) Frequency of handling. If you are buying from a service center, the number of times that the material has been handled can double or triple, compared to a direct shipment from the mill. Given that you may be buying non-bundle quantities, it is a fact of life that the number of lifts and handling increases dramatically with the additional destination of the service center, as well as in the act of splitting the bundle.
When you encounter bar straightness issues, characterizing the way the bar deviates from straightness can help you determine which of the above factors might be the cause.
Editor's Note: CR4 would like to thank Milo for sharing this blog entry, which was originally posted here.
Re: 6 Ways Barstock Can Lose Straightness
07/09/2010 11:00 AM
"Straightness is perishable in bars."
Boy, this is an excellent way to say it. I have always struggled to balance inventory stock points with the inevitable damage that occurs in storage and handling. If I order plenty of stock, it sits in the rack and gets damaged. If I order just enough to last one order cycle, then I run out... or a dingleberry fork truck driver beats the odds and damages some within a few days. My steel stock is mostly ten foot long pieces of rollformed hollow metal frame section, thus.
Another informational blog entry, Milo. Thank you.
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Petroleum Engineering - New Member Hobbies - Target Shooting - New Member
Good Answers: 150
07/10/2010 2:55 PM
There is one other point that needs to be stressed Milo, and that is stress relief. CF bars, depending on the alloy can stress relieve and distort just sitting on the rack/ shop floor. I've seen 5" round bar of a certain 25% Cr. duplex stainless turn into a banana just sitting on a pallet in the sun here in SE Texas. That particular alloy was well known to distort badly. Machining it to close tolerances was tricky. we would have to rough machine it, then set it on a pallet in the parking lot and let it set for a couple weeks and let the hot/cold day/night cycles stress relieve it before we finish machined it.
Who is John Galt?
Good Answers: 243
07/10/2010 5:02 PM
Rorschach, large diameter material is special case all by itself.
Of course the length between supports is critical, as the length and therefore mass, unsupported hanging over the ends.
But independent of grade, the larger diameters do not seem to have the strength needed to compensate for their mass. I believe that Galileo was the first to posit the square cube law, mass increases by the cube of the dimensional increase, while the area to support that mass increases only by its square. Thus at some dimension the mass ultimately overcomes the materials inherent strength...
http://www.msm.cam.ac.uk/phase-trans/design.html
I have seen this in practice: a 4" round 20 foot long cold drawn bar was rolled off a table and fell about 40" to the concrete floor, where it broke into several shorter lengths. There was no sign of cupping or internal ruptures from drawing, nor any transverse cracks.
But the material was not strong enough to support itself on impact. But what you said about developing a droop from improper placed support is a relevant point.
And if it was aging or stress relieving in the Hot texas sun, I will not dispute that either, based on the stresses left in the material from prior processing.
Fineprint: Galileo's Square/Cube Law is currently being used by some "creationist theorists" to hypothesize A) weaker gravity during the time of the dinosaurs; or B) Earths atmosphere being significantly denser in order to explain large sauropod size. They call this the dinosaur paradox.
I am not making such a claim at all. Milo
Register to Reply 3 comments
Doorman (1); Milo (1); Rorschach (1)
You might be interested in: Bar Code Software, Bar Code Cards, Bar Code Scanners
