Speaking of Precision Blog
Previous in Blog: 6 Ways Barstock Can Lose Straightness   Next in Blog: Steel Velcro - New Metallic Hook And Loop Fastener
5 comments
Killed Steel
Posted July 20, 2010 10:36 AM by Milo
Some things you want to have bubbles, some you don't.
Usually, bubbles are good.
In beermaking, yeast consumes the sugars in the wort and converts them into CO2 gas bubbles - carbonation.
In steel making, the main reaction is the combination of Carbon in the melt with Oxygen to form a gas. At the high temperatures involved, this gas is very soluble in the molten bath.
If the Oxygen that is available for this chemical reaction isn't completely removed before the steel is cast, the gases will continue to be forced out of the melt during solidification, resulting in porosity in the steel.
Bubbles and where the gas goes can be important in your steel part.
In order to control the evolution of gas, chemicals called deoxidizers are added to the steel. These chemicals, Silicon or Aluminum, Vanadium, Columbium, Niobium scavenge the available oxygen in the molten steel, react chemically to form solid oxide particles dispersed throughout the steel, rather than bubbles of Carbon Dioxide.
The amount and type of deoxidizer added determines the type of steel. If sufficient deoxidizers are added, no gas is evolved from the solidifying steel, and the steel is said to be "killed." The ingot drawing labeled number 1 shows a fully killed (deoxidized) steel showing only a shrinkage cavity, and no bubbles or porosity. (This shrinkage cavity would be cropped off in normal rolling practice.)
Because gas is still evolving, this beer is NOT KILLED.
Killed steel has more uniform chemical composition and properties than rimmed, semi-killed, or non-killed steels, and generally less segregation. The uniformity of killed steel and and its freedom from porosity makes these steels more suitable for critical components and for applications involving heat treatment.
Killed steels generally contain 0.15 -.35 weight percent Silicon as a deoxidizer, and may contain some of the other elements as mentioned above. These other elements may be used as deoxidizers or as grain refiners.
Steel grades with a Carbon maximum of 0.30 weight % and above, and all alloy steels are typically provided as "killed steels."
Free machining steels such as 12L14, 1215, and some 11XX series steels are not "killed" with Silicon, Aluminum, etc., due to their deleterious effects on tool life and machinability. The high amounts of Manganese in these steels form Manganese Sulfides to promote machinability, and also the Manganese scavenges excess Oxygen, preventing evolution of CO2.
Killed steel is specified so your critical parts won't have bubbles in them.
Killed steel for critical parts. Non-killed beer for critical after work down time.
Cheers!
Beer Bubbles Photo Credit
Ingot scan from a handout in my files originally after Making Shaping and Treating of Steel.
Beer Head Photo Credit
Bread with Holes
Editor's Note: CR4 would like to thank Milo for sharing this blog entry, which was originally posted here.
Re: Killed Steel
07/20/2010 10:42 AM
Damn you posting those pics, I could kill a beer right now... it's hot and clammy here (hmmm a few clams would be nice too)
Very informative as always.
Good Answers: 243
Re: Killed Steel
07/20/2010 10:16 PM
I've had clams in Vodka, Del, Never thought to soak them in beer.Hmmm
Come to think of it those were oysters.
Must have been the vodka.
Milo
United States - US - Statue of Liberty - Who is John Galt?
Re: Killed Steel
07/21/2010 6:07 PM
The Making, Shaping, and Treating of Steel.
My 13th b-day present -- 33 years ago tomorrow!
Thanks for the memory Milo ^_^
I'd've written a shorter post, but I didn't have the time.
Good Answers: 243
Re: Killed Steel
07/21/2010 8:32 PM
What a great gift for a young one! Glad to bring a little joy of engineering. Milo
Re: Killed Steel
07/22/2010 11:55 PM
I wrote a few paragraphs in that book
PEbobimm
Register to Reply 5 comments
Anonymous Poster (1); Milo (2); tick-tock (1); user-deleted-1105 (1)
