Previous in Blog: Cape Cod Wind Project Moves Forward   Next in Blog: High Efficiency Solar Fuel
7 comments
Solar Mirage?
Posted December 19, 2010 7:00 AM
The ambitious joint Japanese-Algerian project seeks to build an oasis of solar power plants from desert sand. Silica extracted from sand in the Sahara Solar Breeder Project will be used to make solar panels, which in turn will be used to construct solar power stations. The latter will breed additional silicon factories and solar power systems, aiming to deliver 50% of global electricity by 2050 through a superconducting supergrid. Count the challenges: water supply, cooling system for superconductors...
The preceding article is a "sneak peek" from Alternative & Renewable Energy, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Alternative & Renewable Energy today.
Re: Solar Mirage?
12/19/2010 7:06 PM
Why not just tap the Btu's off of whatever they're smoking?
Re: Solar Mirage?
12/19/2010 10:33 PM
Two problems they are probably taking into account, dust storms, and dust in the air, solar panels efficiency drops about 1/3 due to dirty collector surface.
Re: Solar Mirage?
12/19/2010 11:36 PM
I read this statement in one of technical papers ,"19th century was the age of coal and the 20th century is the age of oil and 21st century will be the age of the sun". It is a good initiative. We look forward to hear good news to use more renewable energies in coming days to save planet earth.
Good Answers: 109
Re: Solar Mirage?
12/20/2010 4:21 AM
Silicon from Sahara sand will not at all meet the specs for photovoltaics.
This will result in metallurgical grade silicon (98% purity) used to produce transformer steel. Cost is near 1$/Kg
So there is a necessity of adding a leaching facility: too expensive, acids and water needed.
There is existing good and naturally clean silica in various places around the world.
This is used in glass-making (highly transparent glass needs low residuals), not only for optical grades.
To avoid the shading effects of dust storms the plant would need a place near the seaside and provisions taken to clean the surfaces by ? seawater after heavy contamination.
To provide protection against sand-storms with severe sandblasting effects damaging surfaces within hours there seems not to exist any solution.
Go with this activity to an island in the sun and beware of hurricanes.
RHABE
Re: Solar Mirage?
12/20/2010 11:54 AM
It sounds like a good time to build that man-made Sahara River.They could use
Soliel mirrored Panels. and They could build Buildings using sandblasted formed
glass bricks and rebar and de-salienation Plants for the Ocean water .ds
dsuzmay@gmail.com
Re: Solar Mirage?
12/20/2010 1:38 PM
Yes, I too think this can, eventally, be another way to economically multi-task the (real estate) ...
Re: Solar Mirage?
01/12/2011 3:54 PM
Why not just make in a solar thermal collection plant and collect heat from the desert floor? No solar panels needed. metal troughs with the coating that has dust slide off. Maybe collapsible troughs that can collapse into a sheilded area from dust storms. I still think even this is pie in the sky with out insane amounts of money, but thats what the Saudi wealth funds are for.
Anonymous Poster (3); ds (1); mrswamy (1); RHABE (1); Tornado (1)
