Noise walls are expensive and, in some cases, downright ugly.
Built an average cost of $1-million (USD) per kilometer, these outdoors barriers
are designed to reduce noise levels from roads, rail lines, and airport
runways. Often, they also block the line-of–sight between nearby neighborhoods
and planes, trains, and automobiles. Although most noise walls are still made
of wood, masonry, or metal, some noise barriers are now built from earth or
other materials – and colored something other than gray.
In some places, transportation professionals are required to
include noise walls in their plans to build or expand roadways, railways, or runways.
For example, highway engineers in the United States may be required to estimate
traffic noise from a new bridge in a busy urban corridor. But just how accurate
are these traffic noise predictions? And how acoustically effective are the
noise walls that state, federal, and provincial tax dollars pay for?
According to a technical report from the International Institute
of Noise Control Engineering (I-INCE), there is "a strong body of evidence" to
support the use noise walls as a means reducing surface transportation noise.
The "best description of barrier performance", the report continues, is
insertion loss, which the I-INCE defines as "the difference in the noise
environment before and after the noise barrier is built". Typically, common
values for A-weighted insertion loss range from 5 to 12 dB.
Are noise walls the best way to reduce noise levels?
Source: I-INCE
Publication 97-1
