HVAC Blog Blog
HVAC Blog
Previous in Blog: Is Your HVAC System Secure?   Next in Blog: HVAC Takes Center Stage and Common Sense Makes a Curtain Call
Does Flu Prevention Begin with Proper HVAC Maintenance?
Posted March 09, 2011 7:00 AM
What happens when clean hands simply aren't enough to stop infectious spread? Sneezing and wheezing sufferers who insist on struggling through work are the worst culprits since it's their infectious breaths that inevitably travel through air ducts. Probably the most basic flu prevention maneuver is to upgrade your HVAC filtration system to high efficiency air filters. These filters are so specialized you can choose specific filters for specific viruses.
Prevention isn't just up to proper equipment. Technicians should also be careful to wear tear-resistant gloves and face air respirators when installing replacement filters, making repairs to dampers, or removing filth from exhausts.
As a building supervisor or commercial HVAC technician, what preventive measures do you routinely take in stopping the spread of flu and other infectious diseases in your buildings?
Re: Does Flu Prevention Begin with Proper HVAC Maintenance?
03/10/2011 1:59 AM
In the R&D sector, we would finish our air loop system by using an air scrubber to kill or remove harmful materials. In the early days we made our own scrubbers, later we could buy them. Ozone injection from arc is great, you may need to have a down stream duct that is lined with PVC, Kynar, Etc. or some other material that is resistant to ozone effects. A less costly way is to use UV, however this works poorly in a single pass system. Good luck!
