Previous in Blog: Wireless Sensor Network to Monitor Urban Environments   Next in Blog: Solar Flares Threaten GPS Receivers
5 comments
Solar Power Breakthrough: Solar Dyes Could Be Put In Windows, Clothing
Posted April 06, 2007 9:14 AM
From Metaefficient:
Researchers from the Nanomaterials Research Centre at Massey University in New Zealand have developed synthetic dyes that can be used to generate electricity at one tenth of the cost of current silicon-based solar panels. These photosynthesis-like compounds work in low-light conditions and can be cheaply incorporated into window-panes and building materials, thereby turning them into generators of electricity. Dr Wayne Campbell and researchers in the center have developed a range of coloured dyes for use in dye-sensitized solar cells. The synthetic dyes are made from simple organic compounds closely related to those found in nature. The green dye Dr Campbell is synthetic chlorophyll derived from the light-harvesting pigment plants use for photosynthesis. Other dyes being tested in the cells are based on hemoglobin, the compound that give blood its color. Dr Campbell says that unlike the silicon-based solar cells currently on the market, the 10x10cm green demonstration cells generate enough electricity to run a small fan in low-light conditions - making them ideal for cloudy climates. The dyes can also be incorporated into tinted windows that trap to generate electricity.
Re: Solar Power Breakthrough: Solar Dyes Could Be Put In Windows, Clothing
04/06/2007 11:42 PM
HI,
TO
WHOM SOEUER IT MAY CONCERN,
DEAR SIR,
I AM HAVING 3 ROOM FLAT, I USE 3 FANS , 3 POWER SAVER LAMP,
FREEZ, TV, COMPUTER.TO RUN THESE FROM 7PM. TO 7AM. WHAT CAPACITY
SOLER BATTRY IS REQUIRED, AND WHAT WILL BE LANDED COST FOR THIS WILL
BE FOR HERE IN INDIA. I STAY IN SUBERB OF MUMBAI,ie. DOMBIVLI. AT PERSENT
WE ARE FACING HEAVY POWER CUT, AND I FEEL INVERTOR POWER IS VERY
EXPENSIVE .FOR RUN ALL ABOVE SAID EQUIPMET IT COST ME ABOUT RS.200/-
REQUIST YOU SUGEST SOLER SOLUTION FOR SHORT OF ELECTRIC POWER.
04/07/2007 4:18 AM
HI ! FROM THE U.S.A.
i know money is tight but you can try to create your own solar pannels by getting info on the web, try solar collector building or making a solar electric generator, you might find some sight that will instruct you on the materials to collect and how to fashon them together to create a collector. good luck!
04/09/2007 3:33 PM
There is a solar panel and equipment manufacturer in India. TRy google India !
04/10/2007 8:57 AM
12/23/2008 1:51 PM
That's amazing we literally could have powerplants walking around. The sun will come out if the costs are at a fraction of their cost now.Excellent post!
www.makeyourownelectricity.biz
Anonymous Poster (2); Olson (1); PWSlack (1)
You might be interested in: Industrial Dyes, Dye Lasers, Solar Water Heaters
