Previous in Blog: IMPLUX: Omni-Directional, Vertical Axis Wind Turbine for Urban Environments   Next in Blog: The Kitchen-Table Industrialists
9 comments
Strong, Tough and Now Cheap: New Way to Process Metallic Glass
Posted May 13, 2011 2:27 PM
From Science Daily:
Stronger than steel or titanium -- and just as tough -- metallic glass is an ideal material for everything from cell-phone cases to aircraft parts. Now, researchers at the California Institute of Technology (Caltech) have developed a new technique that allows them to make metallic-glass parts utilizing the same inexpensive processes used to produce plastic parts. With this new method, they can heat a piece of metallic glass at a rate of a million degrees per second and then mold it into any shape in just a few milliseconds.
Re: Strong, Tough and Now Cheap: New Way to Process Metallic Glass
05/13/2011 2:41 PM
Good article--thanks for calling it to our (my?) attention!
Good Answers: 130
05/14/2011 12:57 AM
Very interesting - excellent posting
05/14/2011 3:00 AM
Nicely explained, without hype or jargon. I too appreciated this well-written article.
05/16/2011 12:24 AM
A little confusing:
"Common window glass and certain plastics take from minutes to hours -- or longer -- to crystallize in this molten state, providing ample time for them to be molded, shaped, cooled, and solidified. Metallic glasses, however, crystallize almost immediately once they are heated to the thick-liquid state."
Star Trek fans will be glad to know they have invented transparent aluminum.
05/16/2011 7:34 AM
I'm not sure exactly what you are confused about, or whether you are still confused or not. I guess I see the potential for confusion in that last sentence:
... crystallize almost immediately once they are heated to the thick-liquid state."
And think what "they" really meant to say was more like:
... crystallize almost immediately after they have been heated to the thick-liquid state and are just (barely) starting to cool."
05/23/2011 10:24 AM
Yep, sure glad Scotty didn't hit the delete key. Did you notice the time loop formed when the Starship Enterprise was named after a late 20th century Space Shuttle of the same name which was itself named for the Starship Enterprise? Similar to an interesting time loop involving Presidents Kennedy and Lincoln that centered somewhere around 1947. Roswell, or an unforseen result of Hiroshima/Nagasaki?
Just because it has a patent doesn't mean it is the best solution. Just because it has no patent doesn't mean it won't work. A patent is only a license to litigate.
Hobbies - Musician - New Member United Kingdom - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Transportation Engineering - New Member
Good Answers: 48
05/14/2011 5:20 AM
Very interesting indeed. This could revolutionize the way we make certain products.
05/14/2011 6:10 AM
Brilliant artical, and this could solve a lot of problems!
Spencer.
06/09/2011 10:41 AM
great article. I worked on a metallic glasses project in the 80's as an exchange student in Germany. Back then we were always limited to producing only thin strips. The limiting factor then was the inability to attain the phenomenal cooling rates required. Obviously they have overcome this by now. I can see how they attain the rapid heating - the article mentiones pulse heating (not sure whether it is induction heating or similar). But I could not make out from the article how they attain the rapid cooling. Does anyone have an idea?
"Keep on keeping on"
34point5 (1); BJInvention (1); Ethanolics Unanimous (1); Holzfeller (1); rhkramer (2); StandardsGuy (1); Tornado (1); xanasax (1)
