Industrial MRO Blog
Industrial MRO
The Industrial MRO Blog is the place for conversation and discussion about inventory and asset management, products and services, cost & energy savings and maintenance systems & solutions. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: How Much Automation Does Maintenance Need?   Next in Blog: Are You a Checklist Person?
8 comments
Do You Measure Maintenance?
Posted May 27, 2011 7:00 AM
As our lead story this month details, large companies have the personnel, resources, and smart management to identify, record, and disseminate best practices. At the same time, however, maintenance departments — even in large corporations — are often viewed as cost centers, not revenue generators, which means tighter budgets and less time for planning. Does your company measure the efficacy of your maintenance department? Do you learn from successes and failures?
The preceding article is a "sneak peek" from Industrial MRO, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Industrial MRO today.
Re: Do You Measure Maintenance?
05/28/2011 3:42 AM
Maintenance measurement is really easy; a good grease monkey should be able to administer 1440 pumps of a grease gun in an 8-hour day. Of course, this depends on knowing where all the zerks actually are, which is no mean task in a large facility.
Good Answers: 153
05/28/2011 5:40 AM
Tornado, I have no problem with your figures but it does assume 6 pumps per zerk, which in turn implies a routine maintenance cycle of two weeks. Go to a three week maintenance cycle and your figures are screwed. I would also recommend de-rating his preformance by a factor of 0.872 if he has to carry ladders to reach the zerks.
05/28/2011 9:33 AM
Be sure and wipe the fitting first with a clean rag, we don't want to "inject" gunk into the bearing
05/28/2011 10:13 AM
I think whoever wrote the lead for this thread has never worked in a process plant.
We expected to produce well over 8000 hours per year in the last plants I built/operated - less was lost profits and more was pure gravy.
The only way to achieve those hours was with very good maintenance.
Good Answers: 27
05/28/2011 12:28 PM
As long as you are only associating your existence to all maintenance associated costs, then it is correct to be labeled as a cost center!
It will be looked at differently and from the CEO's perspective, if and when you can count and quantify all maintenance efforts, as well as justify your performances based on the annual $$ amount save for the company.
To count as a revenue generating center, an emphasis and full understanding of the importance of your role must be first established! This holds true for all of the equipment under the program. A vital link leading towards their proper functions and equipment operations that will serve as a direct link towards the achievement of the company's vision, goal and objectives has to be set. A good starting point is equipment planning. Planning in a sense that one must NOT only incorporate the initial acquisition costs into the total cost of ownership, but should also include some projections for possible lost revenues that may result or due to some unexpected equipment failures and breakdowns. The key is a good maintenance program coupled with the proper perception in place!
vsar
05/29/2011 12:12 PM
Plant Availability in percentage = ( Calender Hours - Planned Shut down Hours - Break down Hours ) divided by ( Calender Hours - Planned Shut down Hours ) x 100
Maintenance departments have the annual task to deliver beyond certain target figure ( 98 % , 99% or 99.5% so on ).
Regards,
05/31/2011 5:40 AM
Google search gave About 1,880,000 results. I am using one but I do not how to share with you. It is in XLS worksheet. And this one is also good. http://www.lifetime-reliability.com/free-articles/maintenance-management/Useful_Key_Performance_Indicators_for_Maintenance.pdf
Subramanyam
06/06/2011 12:30 PM
In my organization, we use two matrix to evaluate the efficieny of maintenance. They are Preventive Maintenance & Reactive Maintenance. It has been established that reactive maintenance cost much more then preventive maintenance.
This is a simple measure to begin with and very effective as well.
asareshwala (1); Fredski (1); jhhassociates (1); kvsubramanyam (1); russ123 (1); Sganesh (1); Tornado (1); vsar (1)
