A question was presented approximately as follows:
"I would like to supply 200 psig to a 20 foot long, 1/4" tube (We will take that to be .25 I.D.) that has 1/8" holes every 3 inches".
We do not understand many facets of the existing situation. At the known risk of assumption we will divide the 20 foot length of tubing by .25 foot (3") to determine that the number of 1/8" holes is 80.
My friends I messed this up and need to start over right after good morning.
At 200 psig each 1/8" hole could flow as much as 48 SCFM and 80 of those critters could flow 3,891 SCFM to atmosphere. That would require a
The question may have been posted in jest or something is missing.
This one becomes a "NEVER MIND".
Some remedies might be:
- Reduce the number of 1/8" diameter outlet holes.
- Reduce the diameter of the outlet holes.
- Increase the ID of the supply tube.
- Increase the supply pressure.
- Tell us what you wish to accomplish.
