IF YOU WANT TO GET WATER FROM A WELL
Water level 73 feet below 1382 foot surface.
There are a few cute ways to get the water from your well even discounting a bucket brigade of Dallas Cheer Leaders.
The reason you have heard that you cannot siphon water over 35 feet is that (at sea level) the atmospheric pressure is approximately 14.7 PSIA (absolute). This would theoretically raise water 33.9 feet in a perfect vacuum. All that is required is to adjust the local pressure in the well above ambient enough to complete the lift.
#1 Put a cap on your 6" Dia well casing with a tube through it or (double sided pipe fittings, for bulk head effect).
Connect a tube or pipe that will extend 140 feet from the well cap to below where the surface of the water in the well will be after it is depressed by pressure. Flexible nylon with some weigh on the end would work. That is a long way for rigid pipe and definitely not rigid plastic.
Add a pressure port (eg. 1/4 NPT) to the well cap.
Connect compressed air to the cap pressure port. Pressure as low as 25 PSIG will provide enough lift once you prime and start a siphon but the flow will be unenthusiastic.
Since a cubic foot is equivalent to approx' 7.48 gallon you will displace 7,480 gallons of water with 1000 cubic feet of compressed air. At a dollar per 1000 SCF of compressed air you can water a lot of cows for a buck. If you are filling a pond that will be extra. You can pump much water with a bottle of nitrogen as well.
#2 Much less fun would be to trench and bore horizontally into the well casing about fifty feet below the top of the well and use a natural siphon.
If you decide to go with the Dallas Cheer Leaders give me a call.
Edited 3/23/07 with thanks to Kceum & GW
