OpenSource Solutions for Computer Aided Engineering Blog
The OpenSource Solutions for Computer Aided Engineering Blog is the place for conversation and discussion about OpenSource Computer Aided Engineering (CAE) resources available for modern personal computers. There are a myriad of solutions available in the marketplace for a number of different engineering and scientific applications, but it is not always easy to find the most appropriate solution for a particular circumstance, because many of the packages emanate from University research departments or Government development projects that do not have access to sufficient resources to publicize their products adequately. While the primary focus will be on numerical analysis solutions (FEA, CFD, Signal Processing, SPICE electronic simulation, etc.), we will occasional touch on other aspects of CAE such as Computer-Aided Drafting (CAD), 3D modeling, data acquisition (Test and Measurement, etc.), and other such technologies that can add value to the engineering process.
Previous in Blog: OpenSource CNC- From CAD to FAB   Next in Blog: OpenSource Rapid Prototyping (3D Printing)
7 comments
Hidden Treasures of Open Source Software
Posted October 09, 2011 9:00 AM by cwarner7_11
While surfing about on the Internet the other day, I came across a hidden treasure of Open Source code hiding in plain sight, sponsored by the United States National Institute of Standards and Technology. The site, NIST Digital Library of Mathematical Functions, is best described in their own documentation:
"In 1964 the National Institute of Standards and Technology...published the Handbook of Mathematical Functions with Formulas, Graphs, and Mathematical Tables, edited by Milton Abramowitz and Irene A. Stegun...The online version, the NIST Digital Library of Mathematical Functions (DLMF), presents the same technical information along with extensions and innovative interactive features consistent with the new medium [of computing technology]...
"...The technical information provided in the Handbook and DLMF was prepared by subject experts from around the world...The validators played a critical role in the project,...[providing] critical, independent reviews during the development of each chapter, with attention to accuracy and appropriateness of subject coverage...All of the mathematical information contained in the [print version of the] Handbook is also contained in the DLMF, along with additional features...The DLMF has been constructed specifically for effective Web usage...The NIST Handbook has...[the] objective...to provide a reference tool for researchers and other users in applied mathematics, the physical sciences, engineering, and elsewhere who encounter special functions in the course of their everyday work..."
The site includes a link to the Guide to Available Mathematical Software, which is a cross index of mathematical software in use at NIST. Of course, not all of the software included in this cross index is Open Source, but that which is available as Open Source (possibly subject to application-specific licensing constraints) can easily be downloaded and used either independently, or incorporated into one's own code. The Guide also provides a cross-reference between commercial and Open Source software packages that implement specific algorithms.
As a quick example of the gems available here, let us look at a small application called "envelope", which is a "program for calculating envelope curves for oscillatory data", developed by Marjorie McClain of NIST, which is in the Public Domain. This program does something I have often felt would be very helpful in the primary stages of studying noisy time-series logged data, and something I have actually done through a time-consuming process of physically observing the data and estimating the envelope from a graph of the raw data. None of the analysis packages (both commercial and Open Source) I typically use provide a simple automated means of accomplishing this (which doesn't mean they don't provide it- it just means that if these packages do offer the capability, it is buried so deeply in all the bloat, it can't be found).
When one downloads the package, one winds up with a *.shar shell archive file, which is essentially an ASCII text file that combines all (hopefully) of the necessary components of the package. One unpacks such files with the simple command, "sh [file name]". This particular package contains a "manual" and some test data. But we also run in to a couple of issues. The program uses an obscure screen graphics render (Volksgrapher) for its output, and the program was originally written in Fortran 77 (which was the de facto standard back when it was written). The first problem is easy to overcome: since we don't need yet another plotting routine, we just comment out the calls to the graphical output in the source code (we could just as easily replace these calls with calls to something like gnoplot, but we are still in the evaluation stage).
The second problem seems a little more ominous at first, because the gcc Fortran compiler (ubiquitous in the Linux community), gfortran, does not like Fortran77 (I suspect this is a problem one will encounter with many of the packages encountered in such repositories). The old g77 compiler is no longer supported, and I don't want to risk corrupting my current libraries with legacy versions. But all hope is not lost. There is a program called f2c, a public-domain Fortran-to-C converter, or the The fort77 utility, which is an interface to the FORTRAN compiler that accepts the FORTRAN-77 language. Since both of these are available from the Ubuntu Software Center for my particular distribution, this seems safer than trying the older g77 package. We try compiling with the sample command provided in the *.shar file with fort77:
f77 -o envelope envelope.f smooth.f efc.f initpt.f env.f pchic.f pchfe.f savenv.f \ r1mach.f vg.a vgx11.a -Bstatic -native -libmil -lX11 -lm
This, of course, doesn't work because the vg.a, vgx11.a and libmil libraries are apparently related to the Volksgrapher package, which we have not built so we do not have them on our system. Also, we note that the flags "-Bstatic" and "-native" are not legal in fort77. By eliminating the plotting routines and the illegal flags, the program compiles the first time around with the command:
f77 -o envelope envelope.f smooth.f efc.f initpt.f env.f pchic.f pchfe.f \
savenv.f r1mach.f -lX11 -lm
(NOTE: it is likely that we could eliminate the link to the X11 library as well).
But, does it work?
The package includes some test data and sample results we can use to evaluate the program, so we run the "envelope" command we just created with the "test.dat" file included with the archive. Our output generated by the program agree exactly with the sample output files, telling us the program is running as it was designed, doing what it was designed to do(and it did it too fast to time!). Using LibreOffice Calc to have a look at the output:
Looks good, exactly what we expected, but this looks like pretty clean data compared to what we are usually working with. How does the program work with some real-world data?
Here is an example of some data from a project:
As seen in the above illustration, the original envelope curves (dashed lines) seem to follow the data fairly closely, but are too close together, missing a number of peaks. We fix this by shifting the upper curve by 0.5 in the positive y direction and the lower envelope curve in 0.3 in the negative y direction. I suspect the reason the curves did not fit the data as well as they fit the test data has to do with the "initial smoothing" routine. But, with these preliminary results (which took all of 15 minutes to develop, including loading the results into LibreOffice Calc to plot them, studying the results, re-running the "envelope" program with new tolerances a couple of times and modifying the plots a couple of times to see the new results, etc.), we now have some valuable information that we can use for further analysis.
This little exercise has been intended to illustrate some of the more esoteric advantages of Open Source software. First of all, we have a public domain tool readily available for solving a particular issue with minimal investment (in both dollars and time). We have a tool that does one thing very, very efficiently, and we do not find ourselves wading through all sorts of bloat in a commercial package (or, even some of the larger Open Source projects)- we get to our solution much faster. If we are not pleased with the way the software works, we have the option of modifying it to suit our own needs (i.e., we dropped the program's original graphic output interface. Note that this did not require a high level of programming expertise to accomplish). The little application is pretty much platform independent, so long as one has the appropriate compiler.
Plus, it is really nice to see our tax dollars going for something that is practical...
The NIST site is not the only site where such practical Open Source software can be found. A couple of others (to which the NIST site also links):
  • netlib: A repository of freely available software, documents, and databases of interest to the numerical, scientific computing, and other communities. The repository is maintained by AT&T Bell Laboratories, the University of Tennessee and Oak Ridge National Laboratory, and by colleagues world-wide. Most netlib software packages have no restrictions on their use.
  • Collected Algorithms of the ACM: Software published by the journal ACM Transactions on Mathematical Software (TOMS).
  • Computer Physics Communications Program Library: Software associated with papers published in the journal Computer Physics Communications.
Re: Hidden Treasures of Open Source Software
10/10/2011 5:20 AM
Nice - deserves a few stars. Stuck with win XP, so I may have to write myself an unshar if I can't find a trustworthy one (manual unpacking would take ages). Then there's f2c (or maybe f2b) to start hunting for!
netlib has lots of handy stuff - there's quite a lot in c and c++, but even if the fortran needs to be translated to c (or vb) by hand, it's useful to have the algorithms.
Thanks.
Good Answers: 213
10/10/2011 9:51 AM
Thanks for your interest and kind words.
As to being "stuck" with Windows XP, I still run an old machine with Windows 98SE because of some legacy software necessary to access some ancient (but useful) data acqusition hardware- in one case, the manufacturer no longer exists, in another, the manufacuter wants to sell me a new piece of equipment rather than provide either updated drivers or source code so that I could write my own. I also run an XP machine for a similar reason- but it's Excel 2000 that keeps me with XP (newer versions of Excel don't cut it, in my opinion).
If you have the compilers, most of the algorithms shoudl build as easily on a Windows box as on a Linux (or other *.nix) box...
You could have a look at some alternative Linux distros that could be run as dual boot or from a LiveCd or usb drive, or possibly in a virtual machine like VirtualBox (my preferred solution, although Larry Elison makes me nervous about continued support- he is publicly adamantly opposed to the concept of Open Source) or VMWare. A couple of compact Linux distros that might interest you are Linux Mint or Damn Small Linux. To build a usb drive, have a look at PenDriveLinux (this can be handy for playing with Linux on someone else's computer- like a company computer. Does not leave a trace of your activities on the source machine, and you can save your work on the pen drive). There are, of course, other options- these are just the ones I am familiar with.
10/10/2011 10:12 AM
Thanks for the pointers - I'll have a play.
I'm "stuck" partly because of legacy software I rely on, and partly because of customers requirements (they also have legacy software to deal with).
Software I develop in VB6 will run happily under Windows 7, but I'm fretting a bit about what will happen when Windows 8 comes along - MS say that VB6 support will only go as far as 7.
Good Answers: 213
10/10/2011 10:30 AM
Legacy support is one of my bugabears...
Note that the example "envelope" I explore in my blog was written back in the late 1980's- not only legacy, but ANCIENT by modern standards. Still functional, still useful.
I fear that "mainstream Linux" is following the more-is-better eye candy bloat marketing model- witness the current "desktop battles" between the Gnome3 fiasco and Ubuntu's switch to Unity (even more of a fiasco). Don't break my functionality with your idea of "cool"!
Fortunately, there are those on the periphery that still think of computers as tools, rather than artwork...
10/10/2011 10:48 AM
Still lots of very good "ancient" stuff around!
As a rather OT aside, I downloaded and installed the eclipse Java IDS and the Android SDK (plus a few other required or recommended bits and pieces) over the weekend, thinking I'd have a play with Android "apps".
I followed the tutorial ("Hello, Android") and ran the app. To quote the tutorial documentation: "Depending on your environment, the Android emulator might take several minutes to boot fully...". It took 45 minutes from launching to having the "Hello" message appear on the Virtual Device.
I don't know what kind of supercomputer one is expected to have to run this sort of software.
10/10/2011 12:58 PM
Hi cwarner7_11,
How so? I'm curious, because I use both 2000 and 2003. Other than that screwy ribbon menu in 2003, I've not come across any real differences.
Good Answers: 213
10/10/2011 1:11 PM
Where do they hide the data analysis package- things like the FFT function?
And the graphics rendering in 2003 is way, WAY slower than 2000- try plotting 6000 x-y data points, then change the scal to look at a region in more detail, or try adding or changing some titles...
2000 on XP (or, even better, on 98SE) is so much more responsive- even when run in a virtual machine.
By the way, OpenOffice/LibreOffice Calc is not much better than 2003, in my opinion...
But, as they say, opinions are like unspeakable body orifices...
cwarner7_11 (3); JohnDG (3); Mikerho (1)
