Previous in Blog: Device Skates Between Oil, Water   Next in Blog: Black Holes Could Act As Cosmic Rosetta Stones
2 comments
Where to Put Food on the Grill for Perfection Every Time
Posted June 14, 2012 8:50 AM
From Lifehacker:
You may think grilling is easy, but as with all cooking, there's an art to it. You can't just slap anything on the grill and eat it in a few minutes. Here's how to arrange food on your grill for perfect, thorough cooking.
Good Answers: 299
Re: Where to Put Food on the Grill for Perfection Every Time
06/14/2012 10:19 AM
This is the most ridiculous thing I have read in quite a while...
Every backyard BBQ master know that you start with three times as much coal as is probably necessary, give it fifteen minutes or so (the steel body of the grill should be glowing bright red), and toss a hunk of cow onto the warping steel grate. The orientation of the meat on the grate doesn't really matter, it's going to be thoroughly cooked. Whole potatoes should be dropped right into the coals (Alum foil? Are you kidding me?) for about half an hour; these can be scooped out with a shovel with long enough of a handle that only second degree burns are likely. Black layers of charred spud can be cracked off, and you will find a white nugget in the center about the size of a pecan: this will be raw.
THAT is how you use a grill.
06/14/2012 1:55 PM
"Black layers of charred spud can be cracked off..." and then eaten.
/Just to finish that thought.
