From Autoblog:
Goodyear has developed a new self-inflating tire for commercial vehicles. The Air Maintenance Technology system uses an internal pressure regulator to determine when the tire is low. When pressure falls below a certain parameter, the regulator opens to allow air into a pumping tube. Here's the cool part: the tube runs around the circumference of the tire, and as tire rolls, it squeezes the tube, effectively forcing air into the tire through an inlet. Once the tire is properly inflated, the regulator closes off the pumping tube and the truck continues on its way without ever stopping or having to rely on an external compressor.
