Previous in Blog: Tiniest Trickle Will Speed All-Electronic Lab-on-a-Chip   Next in Blog: $2 Billion Later, Bloated Spy Blimp Finally Kills a Cruise Missile
17 comments
New Efforts Aim to Track, Remove Space Debris
Posted September 24, 2012 10:38 AM
From EE Times:
More than 500,000 space debris are orbiting the Earth, and their rising population increases the potential danger to all space vehicles.
Re: New Efforts Aim to Track, Remove Space Debris
09/24/2012 1:34 PM
...have the USAF get the Air Borne Laser (ABL) into space and put it to good use, "zapping" all that spacial flotsam!
09/24/2012 2:07 PM
09/24/2012 2:20 PM
OK, Plan B -- issue "fox-tail brushes & dust-pans" to each ISS resident and have them "clean-up" on "orbit 9" whenever they go outside to stretch their legs during a space walk (wink,wink).
09/24/2012 4:38 PM
How 'bout a little magnet fishin'?
09/24/2012 8:11 PM
You'll need a special magnet.
09/24/2012 9:49 PM
Didn't we have a big long talk about this already...best solution I remember was to use a laser to cause one side to plasma and jet the part back to earth.
Drew K
09/24/2012 10:51 PM
I would think altering the trajectory of space junk in an unpredictable way, would be dangerous to surrounding satellites...
09/25/2012 10:43 AM
Careful consideration would have to be taken before any piece is targeted. The goal would be to slow it so that the object will fall and burn up.
Is there a way we can move in orbit (even very slowly) without consuming fuel by using magnetic fields or solar wind or such? If so it would be a much better idea to collect the junk into a big single area where it could be harvested later. After all, it cost thousands for each nut and bolt to be put up there!
The solar wind would require an eccentric orbit that went outside the magnetic field that protects us from it. It could have it's trajectory corrected out there so it would collide with the object and trap it as it dipped closer.
Drew K
09/25/2012 12:11 PM
I don't know of any way to move around while in orbit without some sort of propulsion....It's a tough problem....
09/25/2012 6:06 PM
Like this? I know the article starts with "fictional or theorized" but how many science fiction tricks are now a reality?
I like the GIT thruster myself. The E.M. fields and solar wind are not quite reaction-less and demonstrate genuine forces.
Drew K
09/24/2012 11:00 PM
Once we get a good radar fix on each piece of space junk, then we can focus our tractor beams on the offending material and carefully guide it to a fiery death in our atmosphere.
09/25/2012 12:38 AM
We constantly track all debris and satellites, how do you think we are able to launch new satellites and space flights without hitting stuff, it's called the launch window....any attempt to destroy these objects that involves fragmentation would be like turning a 45 slug into a shotgun blast....Some debris is 10's of thousands of miles away....
FAQ's space debris....
http://orbitaldebris.jsc.nasa.gov/faqs.html
09/26/2012 11:04 AM
Yeah, I know. I was just injecting a little Gene Roddenberry. We haven't got the tractor beam thing figured out quite yet.
Popular Science - Cosmology - New Member Popular Science - Paleontology - New Member Popular Science - Weaponology - New Member Popular Science - Evolution - New Member Popular Science - Genetics - New Member Popular Science - Biology - New Member
Location: The Nevernever as much as possible, Earth when I have no choice.
Good Answers: 11
09/24/2012 11:19 PM
Large Aerogel panels, deployed in the path of the smaller debris, Then lase the larger items, shattering them into small enough to be captured or burn up in the atmosphere.
Near Earth orbits could be cleared in about ten years or less. The Aerogel panels could be disassembled and returned to Earth.
Dragon
Ignorance is the beginning of knowledge. Heresy is the beginning of wisdom. The ignorant heretic is the wisest of all.
09/25/2012 12:45 AM
15000 Miles per Hour = 22000 Feet per Second
typical high velocity 45 cal = 1000 fps
09/25/2012 3:23 AM
"Ground control to Major Tom
Your circuit's dead, there's something wrong
Can you hear me, Major Tom?
Can you hear me, Major Tom?...."
with apologies to David Bowie.
09/25/2012 8:40 AM
I personally thought we got the mock up to fix a problem like this done a while ago
The first law of thermodynamics is you do NOT talk about thermodynamics.
70AARCuda (2); Brave Sir Robin (2); Dragonsfarm (1); Drew K (3); lyn (1); Mizuti (1); PWSlack (1); SolarEagle (6)
