Carbon
dioxide is naturally sequestered by the accumulation of gas hydrates. To simplify discussion I would like to analyze their existence in marine
environments. The daily cyclic pattern of CO2 concentrations at or near sea
surface suggests that primary production is the driving force that allows the
otherwise saturated water masses to absorb carbon dioxide. Field studies show
that CO2 is only sequestered during daylight. When primary production shuts
down, our oceans act as a source for pumping CO2 back into the atmosphere.
The
sequestered CO2 is stored in organic matter, such as photo-plankton. The
organic matter dies off and settles in intermediate marine environments. These
organic-rich sediments decompose and contribute to gas hydrates as the empty
pore spaces fill with solid gas hydrates from decomposition.
These
hydrates exist dependent on the pressure and temperature of the environment. As
global temperatures increase, saline-rich waters that are warmer than normal enter the convection cycle. The warming trend then destabilizes the solid gas
hydrates allowing the gas to rise to the surface in a vertical column.
The question
arises, how much or quick of a temperature shift would be needed to destabilize
methane hydrates at a rate that the oceans could not dissipate the gas before
reaching the surface? Is an abrupt climate change induced by destabilizing
methane hydrates a plausible theory? Such a theory could explain unprecedented
changes in global climate, such as the Younger Dryas, but is it plausible and
is this a natural process?
Today, the gas
hydrate stability zone (GHSZ) exists between 250 to 500 meters below sea
level. As temperature increases the GHSZ
will drive deeper into our oceans while shallow methane hydrate beds
destabilize, releasing methane gas. While smaller scale gas releases could
explain sinking ships in the Bermuda Triangle, we should really be concerned
about climatic responses.
Resources:
http://www.agiweb.org/geotimes/nov04/feature_climate.html
http://usnews.nbcnews.com/_news/2012/10/24/14670511-climate-changing-methane-rapidly-destabilizing-off-east-coast-study-finds
