Previous in Blog: Biofuel Byproducts Make Stronger Concrete   Next in Blog: Princess Leia Hologram Could Become Reality
4 comments
Vavuud Wind Meter For Smartphones Contains No Electronics, Delivers Accurate Ground Wind Speed Readings
Posted March 20, 2013 9:03 AM
From TechCrunch:
Smartphones have a lot of on-board sensors, but do they really have enough? No way, say a slew of recent hardware startups, of which Danish Vavuud is only the most recent. Vavuud is turning to Kickstarter to help build a smartphone-compatible wind meter, one that miraculously contains no electronics and yet still can communicate accurate wind speed measurements wirelessly to iPhones and Galaxy devices.
The Vavuud wind meter provides an easy way to measure wind speed exactly where you are, with a device that's remarkably inexpensive and deceptively simple. It plugs into the headphone jack of your device, but that's to give it a stable base; it actually uses two magnets in the rotor, which generate a magnetic field that the smartphone can pick up and process using algorithms normally used for sound processing to translate it to wind speed data. Vavuud co-founder Thomas P. Helms says it's been tested with iPhone 4, 4S, and 5, as well as Galaxy SII and SIII so far, and it has been calibrated in a wind tunnel at the University of Denmark to ensure accuracy.
Read the whole article and watch the video
Re: Vavuud Wind Meter For Smartphones Contains No Electronics, Delivers Accurate Ground Wind Speed Readings
03/20/2013 9:23 AM
Clever...
03/23/2013 11:14 AM
Smart phones for bowmans!
The English would have ruled the world with that!
03/21/2013 8:46 AM
Great idea. I'm wondering what the typical sampling rate is on the magnetic sensor or whether that is programmable.
03/21/2013 11:21 AM
Mount this on a hat, add bluetooth communications, and I could digitize the speedometer in my convertible!
MikeMack747
Anonymous Poster (1); MikeMack747 (1); Rixter (1); user-deleted-1105 (1)
