The Engineer's Notebook Blog
Previous in Blog: LEGO: Sturdy Enough for the Next Generation   Next in Blog: Truly Superhuman
12 comments
Grow Your Own Pineapple
Posted April 22, 2013 8:45 AM by SwissMiss
If you're looking for an attractive, low-maintenance houseplant that also makes delicious fruit, you might want to think about growing your own pineapple plant. Growing pineapple plants indoors is very easy, making it a great project for just about anyone. You will only need a few things to get started, and after a few days you should have your very own pineapple plant.
You Will Need:
  • Ripe pineapple
  • Sharp knife
  • Planting pot at least 8 inches (about 20 cm) in diameter
  • Potting Soil
  • Plenty of sunlight
Selecting the Pineapple
Head over to your favorite local grocery store and look for a pineapple with nice golden-brown skin and firm green leaves. Avoid pineapples that appear green, as they are not fully ripe yet as well as pineapples that appear to be overripe or unhealthy. If you're not sure, try smelling the bottom of the pineapple. If it smells sweet and heavenly, it will probably work for your new plant. Be sure to inspect the leaves of the pineapple for any signs of pests or diseases.
Preparing the Pineapple
After you select the perfect pineapple, you are ready to begin your pineapple plant. The first thing you need to do is separate the crown from the fruit. Grasp the crown firmly (watch out for spikes) and twist it until it comes out. Once you have separated the crown, remove the lower levels of leaves and any remaining fruit from the base. You should have about 1 inch of the crown exposed at the bottom. Next, look at the base of the crown for little brown dots around the outer edge. These are the root buds. If you cannot see them, cut very thin slices from the bottom until they are exposed. At this point, it is best to let the crown dry out for a few days so the scars have some time to heal. This helps prevent rot, and gives you plenty of time to enjoy eating the remainder of the pineapple.
Plant the Pineapple
Now that the pineapple crown has had some time to itself, it's time to plant. Place some potting soil in a pot at least 8 inches in diameter. Place the crown firmly at a depth of 2 inches below the surface of the soil. Some people prefer to let the roots sprout in a glass of water before they plant the pineapple crown in soil, while others find this extra step unnecessary. Feel free to experiment, and stick with whatever method works best for you.
Caring for the Pineapple Plant
Place your new houseplant in an area where it will get plenty of sunlight and have room to grow. If you've planted your pineapple successfully, it may very well grow to be about 5 feet tall and 4 feet wide. If you plan on bringing your pineapple plant outdoors, keep in mind that they are damaged at 32 F degrees and could die at 28 F degrees. Depending on where you live, you may need to bring them indoors during colder months, or if the overnight temperature in your area dips particularly low. Pineapple plants do not require a lot of water, so they will be fine if you only water them once a week.
Reaping the Reward
You won't see pineapples growing right away, but don't be discouraged. Your plant could start to produce fruit after only a couple of years. Though the fruit you get will likely be smaller and less sweet than the fruit you will find at the grocery store, I have enjoyed eating many fresh pineapples grown by my father in New Hampshire. When you do finally see a fruit growing, wait until it ripens on the plant before you harvest it. Consuming the fruit or juice from unripe pineapples can make you sick. If you grow your own pineapples, don't forget to save the crowns and repeat the process!
References
http://www.rickswoodshopcreations.com/pineapple/pineapple.htm
http://www.tropicalpermaculture.com/growing-pineapples.html
https://www.hort.purdue.edu/newcrop/morton/pineapple.html
https://www.livestrong.com/article/407906-pineapple-side-effects/
http://thailandfruitsandfood.blogspot.com/2008/12/how-to-grow-pineapple-in-your-home.html
Good Answers: 15
Re: Grow Your Own Pineapple
04/22/2013 9:49 AM
I'm totally trying this! Thanks to Pintrest I was inspired to try regrowing green onions and romaine lettuce by keeping the base, putting it in a little cup with water, and setting it on my kitchen window sill - it's been successful so far and pretty fun to follow (it's exciting to see how much they grow each night). Now with the addition of the pineapple, I wonder how big of a garden I can get going in my one little window.
Sharkles
04/22/2013 9:55 AM
Cool post! I planted some Meyer lemon seeds this past weekend - I'm looking forward to seeing how those do. You can also grow avocado trees pretty easily, or so I'm told.
04/22/2013 10:59 AM
I managed to grow an avocado tree for about a year before it died. I think I over watered it. My dad has more success with those than I do.
Good Answers: 52
04/22/2013 9:59 AM
I tried something like this in the office when I had a pineapple, but instead of using soil we started it in water, which many instructions suggest. Instead of growing it just began to rot and smell and had to be tossed.
04/22/2013 11:01 AM
Some people swear by the water method while others say it's an unnecessary step. I guess it all depends on what works best for the individual. If you do decide to go with the water method, change the water every few days to help prevent rot.
Re: Grow Your Own scrap garden
04/22/2013 12:51 PM
04/22/2013 4:27 PM
Very cool! I have tried growing pineapples and avocados in the past with little success, but you have inspired me to try again with the pineapple. Even if it doesn't produce fruit for awhile, it looks like a beautiful plant.
LakeGrl
04/25/2013 5:36 AM
I've managed to get avocado to grow into quite nice looking house plants. No fruit, but they did look nice. I'm not sure how, my approach has been a bit hit and miss.
Call me stupid, but even after viewing the links I'm still not 100% sure on what is being described in the method. No matter, a bit of experimentation is fun. I had no idea that pineapple were so hardy and easy to grow. Being a hapless gardener, this one sounds ideal for me - they might survive a few days neglect if I go on hols. I had expected pinapple to need a lot of water, and a fairly tropical climate.
Down in Cornwall,UK, is a place called 'The lost Gardens of Helligan'. It's a big old Edwardian estate (once forgotten and lost in time, hence the name). They have a restored pineapple house. The building is built such the horse dung can be piled around the outside. As it 'matures', the heat goes into the building and keeps the plants at the right temperature thruought the year.
As a kid I recall growing carrot tops. Kick start them in a saucer of water. Alas, I forget what we did with them after that. Another classic is growing cress in eggshells. A lot of stuff people buy in the greencrocers that can be cultivated, and many plants are incredibly robust. My mother is a fanatical geardener, and most of her stuff is taken from cuttings - sadly the 'green fingered gene' did not seem to pass on to me, biut it's always a buzz to see her garden. It looks like it must have cost a fortune, but it's all by taking cuttings, using bits from the kitchen and so on.
One year I planted a mass of spuds. They were delicious (and it was fun to swap veg with my more clued-up neighbour), but when I costed out how much water I had used, they were several times more expensive than in the shops. Still, it's nice to know that they aren't doused in chemicals, and a bit of physical activity such as gardening has got to be a good thing. I was much impressed recently to hear from a young niece that her school have all the kids actively engaged in growing stuff at school. As with kramarts recent post (I Got my Patent), I'm very much pro schools doing such activities.
04/26/2013 5:05 PM
You need to put them in the right place so they grow big and strong!
Madness is all in the mind
04/27/2013 3:03 AM
..or plant them upside-down
04/22/2013 6:27 PM
I grew a pineapple plant outdoors when I lived in the Tampa Bay area. Unfortunately, some person or thing stole the fruit just as it began to ripen.
Now that I live in GA I started growing blueberries. Blueberries have got to be the easiest fruit/berry to grow outdoors, anywhere. They don't need much space; they require almost no maintenance; insects don't bother the berries, nor do the birds or squirrels; they can almost be treated like a hedge plant. There are varieties that are hardy all over the US from zone 3 to zone 10.
You need to plant at least 2 different varieties because they need to cross-pollinate, and if you pick 3 varieties that come into fruit at slightly different times, you can harvest the berries once a week for up to 8 weeks.
Blueberries are extremely high in anti-oxidants and are reported to have numerous health benefits such as: improved vision, enhanced memory, help prevent urinary tract infections, strengthen blood vessels, and promote weight control.
04/22/2013 11:55 PM
I planted a pine apple tree from a fruit in 1970s and got a fruit from it but it was small because I didn't apply any fertiliser
pnaban
frankd20 (1); GM1964 (1); Hannes (1); Kris (2); LakeGrl (1); pnaban (1); Sharkles (1); SolarEagle (1); SwissMiss (2); Usbport (1)
