Speaking of Precision Blog
Previous in Blog: Aging Society Megatrend – Impacts Precision Machining   Next in Blog: Time Management- Shaping Outcomes or Managing Emergencies?
5 comments
Chatter- It’s Not the Machine
Posted July 02, 2013 12:00 AM by Milo
"If you have a flat tire on a car, you fix the tire, you don't look at the tire balance, vibration of the motor, or the paint job…"
Thoughtful follow up to our post on Vibration, Harmonics and Chatter from William R. Shaffer, VP at Conicity Technologies.
Conicity provides specialized edge prep solutions for our industry.
Here's what Bill had to say:
So should I look at the engine mounts, the shocks and struts, the paint job, or should I just fix the tire?
"Perhaps there is some chatter that is a function of machine harmonics, but I have not seen that as of yet. My feeling is that the machines are designed and built with the high level of technology, much higher than the technology that is associated with the design of the cutting tool.
"Cutting tools used to drive the machine tool industry to higher levels of capability because the capability of the tool always exceeded the machine. Spindle speeds and rigidity often lagged tool designs and machine tools were not able to take full advantage of tool capability. That was then. Not today.
"Bottom line, machines have surpassed the tool capability and tools really have not made and significant breakthroughs to push the machine building community.
"I deal with chatter on a daily basis for our customers.
"We have successfully cured severe levels of chatter in metalcutting by addressing the micro-geometry of the cutting tool.
"At the end of the day, vibration starts at the tool because perhaps the tool geometry being suspect, friction, perhaps feed rates combined with tool design, but it starts with the tool.
"If the machine hums and vibrates when it not running a workpiece, then you do have a problem. If you have a flat tire on a car, you fix the tire, you don't look at the tire balance, vibration of the motor, or the paint job…
"So the question I would like to explore is "what do the people that make the machine tools feel about their machines having inherent vibration and harmonics that create issues in machining?"
"What do the folks who make the machines have to say about this?
"Is the picture that many may have in their minds that "the machine has it's own set of harmonics, so does the material that is being processed, perhaps even the tool," valid, or not?"
Your comments please…
Re: Chatter- It’s Not the Machine
07/03/2013 10:49 AM
Everything has inherent vibration and harmonics.
Press the grip of an unstrung longbow to your ear and tap along the limb with the edge of a finger it rings in a rather surprising way with loads of harmonics.
Even the Earth itself rings after earthquakes.
Good Answers: 243
07/03/2013 11:01 AM
Understood, Del. The question in this post is whether or not the machine itself is the primary cause of the chatter, or is it the tool edge prep that CAUSES the CHATTER.
I agree that we can "find" harmonics in everything; The question here is to proximate cause - machine or tool edge.
Milo
07/03/2013 11:11 AM
But each machine (New or used) has its own frequency, and imo the only way to address it, is after it's brought online.
Having experienced this problem......... we had a number of issues that caused this......
  • The machine design,
  • The Poor Maintenance/Operation of the Machine (We had Fretting in one of the tool holders)
  • Or the Tool
When I first started working around the machine tools Late 80's early 90's, I was really surprised that a different tool could cancel out some of the natural frequency 'chatter' out and the cut was acceptable.
Unfortunately at the time, it's trail and error to find the compatible cutting tool.......... Has this changed?
Good Answers: 243
07/03/2013 2:23 PM
So how do you know that it was the machine and not the original tool...
Milo
07/03/2013 4:47 PM
Most of the time, You don't. Unless its more obvious such the fretting on the tool holder, end of lifetime bearing going out, ect....
It was at the shipyard, where allot of our contracts was with the navy (avenger class minesweeper) we had (2) two Shoda CNC routers... Not only did we use it for wood, but also for phenolics, FRP, most nonferrous metals..... We had restrictions on the use of coolant, so chip load was our major process to carry away heat. And the routers minimum rpm was 7500, had our own r&d worker order number to test the best process (rpm, feedrates, tooling) to get the best results. Again trial and error, but we documented everything and the material we were cutting/machining, (silicon/brone, copper/nickel, aluminum, to the phenolics). We worked with Shoda as well as our tooling suppliers for our more difficult process. Again, their expertise was let's try this.
The tooling salesmen knew not the blow smoke......, because we would take the bit right there and try it in front of them. And the salesman, would rather be straight with us, or we tell them we are not interested and don't call us, we'll call you.
Got to a point that Shoda used our capabilies as a selling point for their routers.
Register to Reply 5 comments
Milo (2); phoenix911 (2); user-deleted-1105 (1)
