Fastening, Joining & Assembly Blog
The Fastening, Joining and Assembly Blog is the place for conversation and discussion about fasteners and hardware, design for assembly, adhesives and sealants, and welding and joining technologies. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Your Own Personal Robot   Next in Blog: How to Fine-tune Robots for Maximum Benefit
5 comments
Making and Using AIM Solder
Posted September 06, 2013 12:00 AM by CR4 Guest Author
Although soldering, the process of joining together metallic materials by melting and manipulating an alloy to fill the joint space, has a slew of modern day applications, it has actually been in use for nearly 5,000 years. There is evidence that ancient Sumerian swords and other weapons from around 3,000 BC were made by soldering different metal components. It has also been used throughout history in making jewelry, cookware, and stained glass, among other things.
What exactly is solder?
Firstly, it is important to differentiate soldering from welding. Soldering is not the same as welding because welding involves melting the pieces of metal you are joining. In contrast, soldering requires the melting of a filler metal (alloy) to bridge the gap, but does not involve thermal manipulation of the other metal components that are being joined. Therefore, the filler metals that are utilized in soldering must possess a lower melting point than the other elements. Conventional soldering usually incorporates lead into the solder mixture. However, increased awareness about environmental protection has made lead a less popular choice. The three main types of soldering are soft soldering (often involving tin/lead alloy), silver soldering (silver alloy), and brazing (brass alloy).
What industries is it used in?
AIM solder is used in a number of industries including electronics, plumbing, jewelry, metalwork, canning, stained glass, fishing, radiator, automotive, and ammunition industries. Soldering is useful in products that require strong but potentially reversible joining of metal parts without damaging the structure of the components. Electronic work often includes soldering because the low melting point of solder means delicate circuits aren't damaged by heat, and solder mixtures are generally good electrical conductors.
How to make solder (alloy)
Solder is available in a range of different alloy mixtures. The ideal alloy mixture will depend on your intended application. For instance, 60/40 and 63/37 tin and lead alloys have a relatively low melting temperature (meaning they require low heat) and are often used in PCB or stained glass assembly. There are also 50/50 Aquasol and Econosol alloys which are used for plumbing purposes since lead cannot be used in plumbing due to its toxicity. Some tin solders contain less than five percent tin and are used in instances where temperatures can exceed 250°F.
It is possible to actually make your own tin/lead solder alloy, although precaution should be taken to avoid burns and lead poisoning. First, you should weigh out 1g each of tin and lead. Use a crucible to melt the lead and add some carbon powder to prevent formation of a film on the top surface. Next, add the tin and stir until both metals are molten. Pour the molten metal into casting sand or a ceramic tile and wait for it to cool. After it has cooled completely, you can test the integrity of the alloy's hardness, density, and melting point by scratching the alloy with lead, comparing the weight of lead and the alloy, and comparing the melting point to that of pure lead. The alloy should be harder, less dense, and have a higher melting point than pure lead. Again, be careful not to inhale fumes from the lead as this could pose a serious health threat.
How to use solder
We've already discussed all of the industries and products that use solder, but how is it actually applied? Soldering is a skill that has to be developed over time. Basically, you use a soldering gun or soldering iron (there are many different variations of these tools commercially available) to heat the alloy until it melts, then manipulate it while it's still molten to solidify a joint. You will need to select a type of solder that is appropriate for your intended application. For instance, you may use solder wire for small electronic work that requires precision and low melting point.
Editor's Note: Written by Steve Ruzumna. Steve is a master distributor for AIM Solder. He has served many industries ranging from radiator, stained glass, industrial and jewelry.
image credit
Re: Making and Using AIM Solder
09/08/2013 2:52 AM
Helo.. Good morning...
I wish to get your advice on following..
We manufacture Stain less steel cylinders having copper coil ( Copper tube of 3/8 inch dia and 1.2 mm thk) MIG brazed inside the cylinder. It is quite time consuming and the aesthetics is not as good as expected. Actually the joining of copper coil with the cylinder is meant for heat transfer only.
Cylinder is made out of SS304 and thk is 3 mm. Copper copper coil (Tube) size is 3/8inch and thk 1.2 mm. The working temperature will be 50 degree Celsius to minus 196 degree Celsius.
Can you suggest a suitable brazing method and consumable for this. ( main factor is the joint should withstand the working temperature - Cryogenic temperature)
Or if you know any equipment manufacturer who can develop a soldering equipment which may give higher productivity.
Thanks N regards,
CKM
(C K M)
09/08/2013 10:00 AM
Oh, AIM is the name of the company that employs the author. I was at first trying figure out the alloy ingredients to make the acronym AIM. Antimony, Indium, Magnesium fits the acronym but would at least require an inert gas. The original article probably came from a site that introduces the author before the article instead of afterwards.
09/08/2013 5:22 PM
Yes, AIM are one of the reputable solder suppliers.
Worked in that industry for 28 years, we peaked at using around 50kg solder per day for electronics.
No longer in that business, so cannot provide comparison to others in the market.
09/08/2013 8:33 PM
I happen to have used Kester solder predominantly in my career.
Just goes to show that the slang definition of assume is often correct.
07/09/2020 7:48 AM
one more recommendation is http://www.soldertools.net/
C K ManojKumar (1); Just an Engineer (1); msbettyhunt (1); redfred (2)
