Fastening, Joining & Assembly Blog
The Fastening, Joining and Assembly Blog is the place for conversation and discussion about fasteners and hardware, design for assembly, adhesives and sealants, and welding and joining technologies. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Taking the UV LED Cure   Next in Blog: Robots Come Out of the Cage
2 comments
A Bright Future for Light-cured Adhesives
Posted December 07, 2014 12:00 AM by Engineering360 eNewsletter
A recent survey cites expanding use of UV and visible light technologies, predicting continued growth. UV/Vis adhesives cure in seconds rather than minutes or hours. In addition, their overall cost is lower than that for two-component systems. There are other benefits as well. Because they use smaller amounts of solvents and volatile organic compounds (VOCs), UV and Vis adhesives cause less damage to the environment. The equipment takes up less floor space and uses less energy. Finally, new packaging is available to block UV and visible light that might initiate a cure, while still enabling the liquid level to be viewed.
Editor's Note: This news brief was brought to you by the Fastening, Joining & Assembly eNewsletter. Subscribe today to have content like this delivered to your inbox.
Re: A Bright Future for Light-cured Adhesives
12/08/2014 11:13 AM
Light-cured Adhesives are already established in dental industries.
12/08/2014 12:41 PM
I saw them being used on one of the How Its Made shows also.
