Fastening, Joining & Assembly Blog
The Fastening, Joining and Assembly Blog is the place for conversation and discussion about fasteners and hardware, design for assembly, adhesives and sealants, and welding and joining technologies. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: A Bright Future for Light-cured Adhesives   Next in Blog: Threads: How They are Made and Which to Use
3 comments
Robots Come Out of the Cage
Posted January 06, 2015 12:00 AM by Engineering360 eNewsletter
The barrier between robots and people is changing from cage-based to software-based. Section 5.12.3 of the ANSI/RIA 15.06-2012 standard allows safety functions to be programmed into the robot itself. Manufacturers are responding with a number of innovative techniques. A theme running through these solutions is allowing the robot's operating space to be designed for a particular application, so areas outside of the defined space don't require guarding. This approach generally leads to a smaller footprint. An embedded video link demonstrates this approach using a laser scanner that monitors four separate work zones simultaneously. Two other video links show motor-operated doors that protect against physical hazards like welding.
Editor's Note: This news brief was brought to you by the Fastening, Joining & Assembly eNewsletter. Subscribe today to have content like this delivered to your inbox.
Good Answers: 26
Re: Robots Come Out of the Cage
01/06/2015 12:51 PM
OSHA will never buy that.
01/07/2015 7:49 AM
A software 'glitch' or a hardware failure is always prone to causing catastrophe. If you're in the 'zone' you can become a 'target'.
Hobbies - CNC - New Member
06/01/2015 10:36 AM
I really don't see industry going "fenceless" as long as there are workers that may accidentally walk into the robot area even with light fences. I do see going to a less rigid fence structure and maybe going with a chained off barrier?
geraldpaxton (1); Original_Macgyver (1); texasron (1)
