Biomedical Engineering Blog
Previous in Blog: The Truth Behind Calories   Next in Blog: 3D Printer Body Parts
5 comments
The Future of Gene Therapy
Posted October 06, 2013 3:52 PM by Chelsey H
In the simplest terms, gene therapy introduces genetic material into cells to compensate for abnormal genes or to make beneficial proteins.
The modified gene is delivered via a carrier, called a vector, either by an injection or intravenously directly into a specific tissue. The vector is taken up by individual cells and if the treatment is successful, the new gene delivered by the vector will make a functioning protein.
But this is not as easy as it sounds. Gene therapy has been around for decades and while many challenges have been overcome, researchers and scientists around the world are still having only limited success. Some of the bigger challenges include.
  • Mass delivery and activation - the gene needs to be delivered to the right cells, in the right tissue, in the right quantity (which is several million cells). Once there the gene must be turned on to produce the proper protein. This is the biggest challenge facing gene therapy researchers.
  • Immune response - the immune system is designed to battle intruders and therefore gene delivery vectors must be able to bypass the body's surveillance system. An immune response may cause severe or deadly complications.
  • Missing the target - gene therapy is successful when the newly-introduced gene becomes a permanent part of the cell's genome by "stitching" itself into the cell's existing DNA. If the gene stitches itself in the wrong spot it can cause interruption in the function of a normal gene, leading to diseases such as cancer.
So what is the future of gene therapy?
If successful, gene therapy has the potential to cure millions of people of hereditary diseases that currently have very few treatment options. Last November (2012) the European Medicines Agency gave the Dutch biotech startup UniQure permission to sell its treatment. Although this is giving gene therapy a new boost of research efforts (and investors) it may be a few years before the treatment is approved in the U.S.
The UniQure treatment involves a gene needed for the body to break down fats; without it, patients can develop painful and even fatal inflammation of the pancreas. The treatment uses a modified version of the virus to deliver the gene therapy. Several other gene therapies, including treatments for early blindness, cancer, and neurodegeneration, are nearing the final stage of testing.
The completion of clinical trials is no guarantee that the technology will become approved or available in the U.S. but many companies and hospitals are prepping to begin manufacturing gene-based therapies.
Re: The Future of Gene Therapy
10/06/2013 11:17 PM
Why would an intravenous injection go directly to the specific tissue? If that tissue is the blood stream or the heart itself then I'd understand that concept but an intravenous injection is into a vein. This is a direct path to the heart. After the heart, the lung, then a return to the heart followed by dispersion to the rest of the body. If localized injection to a tissue is desired then intravenous delivery is the wrong path.
10/07/2013 6:46 AM
My guess is that it depends on what mechanism is used for the actual delivery through the cel wall.
It should be possible to target specific types of cells by programming the vector to only bind to specific types of protein receptors. In this way you can selectively apply genetic material to the target cells you want and ignore the remaining cells.
If that is the mechanism used with intravenous delivery, then a broad broadcast approach is not a problem and possibly the best method as it can better target more of the desired cells that may be hard or impossible to reach by direct injection.
I should add that this is the method used by virus capsids (colds, AIDS, etc.). Generally, a virus attack is cell type specific. One of the potential treatments for averting infection is to clog or denature the protein binding mechanisms of the virus, which prevents it from ever attaching to the target cell in the first place.
10/07/2013 7:22 AM
So you agree with me. The intravenous injection is just the mechanism to get the vector into the patient. The design of the vector is what makes it tissue specific.
10/07/2013 7:38 AM
Yes, that's my take on it.
10/07/2013 7:54 AM
This technique has been around for a while, but it hasn't been until the last few years that some progress has been made.
Basically, we have been engineering custom vectors and they work pretty well in vitro in the lab, but there appears to be a number of unforeseen hurdles to get this to work reliably in vivo or in the actual living organism.
The beauty of this approach is that you can engineer a delivery vessel so it binds only to the cells that need the therapy (like a targeted mail ad campaign) and then send it via the general post, so to speak.
The theory is a lot simpler than the practice, but so many things are like that in life.
I remember in high school thinking about writing a story where similar technology could be employed for targeted assignations where a specific person's DNA sequence would be the trigger to poison the target victim, but leave others unaffected. I think I arrived a little late to the party on that idea as I recall other authors using that theme. I am just slightly behind my time. :)
