Previous in Blog: Solar Power vs. Fossil Fuels: Which Will Stand the Test of Time?   Next in Blog: Alternative Energy Sources You Never Knew About
8 comments
Finding Ways to Innovate Green Technology
Posted November 25, 2013 12:00 AM by CR4 Guest Author
Environmental sustainability is such a current concept that it is often associated with cutting edge technology. But not all green technologies are new inventions. Designers and engineers are reaching into the past to shape creative adaptations of century-old techniques; or implementing a green modernization of time-tested technologies that will produce an immediate positive environmental impact.
1. Your own personal windmill
Windmills are believed to date back to the sixth century AD. Early windmills were a feat of ancient engineering, harnessing the power of wind to pump water and mill grain. Today's modern commercial wind turbines are the fastest growing energy source in the U.S., according the the U.S. Department of Energy (DOE) 2012 Wind Technology Report.
Now, the little cousins of these behemoth wind turbines are available as residential small wind electric systems. Rising energy costs and a number of state and local incentives have made these products economically feasible from a payback perspective. The DOE estimates that small wind electric systems can save between 50 and 90 percent in electricity costs.
Homeowners are generally best off using a grid-tied generation system that can transfer power back through the grid to the utility company. As with solar panels, utility companies agree to purchase the energy at predetermined rates. Any time the windmill generates more energy than the occupants of the home are using, the energy is sold and credited on the homeowner's bill.
Small wind electric systems are ideal for rural areas. Tall turbine towers can conflict with zoning laws in urban areas and are subject to wind block from adjacent structures. Turbines perform better higher off the ground, so it is much easier to reap a return on investment with a taller tower.
2. Let there be daylight
Before Thomas Edison, humans heavily relied on natural light for day-to-day activities. In the new era of environmental sustainability, our love affair with the light bulb has officially ended. Architects design green buildings to allow for maximum transmission of natural light, or daylighting.
Daylighting minimizes the need for artificial lighting, saving a tremendous amount of energy in commercial buildings like offices, schools, and retail spaces that typically have their lights on throughout the business day. Multiple studies have shown that adequate daylight actually improves mental alertness and leads to better productivity from students and workers.
Today's daylighting strategy goes beyond just throwing in a few more windows. Architects meticulously calculate window locations and shading to allow for optimum daylight without causing solar heat gain in the summer.
Advanced daylighting controls sense the amount of natural light present in a particular room and dim the electric lighting accordingly, ensuring that no energy is wasted and that the occupants are receiving the maximum allowable dose of productivity-boosting sunshine.
Photosensors that sense the amount of daylight communicate with a central lighting control unit that can dim lights, switch them off, or even raise and lower shades on a room-by-room basis. These can be paired with motion sensors that will communicate to the lighting control unit when a room is unoccupied. Building managers can opt to switch lights off in unoccupied rooms for further energy savings.
3. Space heater revival
Electric space heaters have long been considered an inefficient heating method. But these old preconceptions are being broken by a new generation of eco-friendly low-wattage space heaters.
The use of portable space heaters can be a green concept if they are used to heat a small area or room that is being used while a building's central heating system is kept at a much cooler temperature.
Low wattage space heaters use only a fraction of the energy of their predecessors and allow for a more consistent temperature. A commercial building with 10 low-wattage space heaters could prevent 14.58 tons of carbon dioxide emissions over the course of a year when compared to 10 conventional space heaters, according to this chart from space heater manufacturer Cozy Products.
Most modern high end space heaters also feature adjustable thermostats and advanced fire safety controls.
Editor's Note: Chris Schwind is a freelance technical writer and Principal of Schwind Communications, a firm specializing in business-to-business marketing in the construction and tech industries. He regularly writes about green building, architecture and energy efficiency. He has been published in Eco-Structure, Walls & Ceilings Magazine, Wood Design & Building Magazine, Michigan Builder, Wend Magazine, Modern Materials, and Timber Framing. Connect with Chris on Google+, Twitter, and LinkedIn.
Re: Finding Ways to Innovate Green Technology
11/25/2013 1:16 AM
"Electric space heaters have long been considered an inefficient heating method. But these old preconceptions are being broken by a new generation of eco-friendly low-wattage space heaters.
Low wattage space heaters use only a fraction of the energy of their predecessors and allow for a more consistent temperature."
HUH????
As I learned the physics behind electric heaters they are for the most part 100% efficient at converting electrical power into heat.
Did I miss something in physics 101?
11/25/2013 4:12 AM
"low wattage" = less heat.....I think improved insulation and double paned low e windows play an important role here....The more insulated the space is, the less heat you need ....Trying to just heat one room is nothing new, and still marginally effective at best.....
Location: OHIO, tri-State design and installation, and travel nationally and consults also are international
01/05/2014 5:10 PM
Spot space heating
Well they were obviously selling Eden Pure's higher volume airflow over resistance 1200 to 1500 watt heaters or the like...
which per comment 1 ) electric is electric and heat is heat, yes, COP of 1: then 100% efficient to the electrical input.
But WHY do so many save a bundle in the past 5 years doing the SPOT heating thing?
And recently learned to use two or three 19 dollar heaters on one or two room space heating for comfort instead of one $300 or $179 heater (of only ~ 1500 watts ( about 5000 btuh) ) ?
Tracking results in my geothermal customers' homes where some one else sold single stage or just 2 stage units handling only 85% of the peak loading, those keeping the 5kw (cycling as needed) or 10kw strip heater "OFF" and using a few low-setting's of a few small inexpensive safe space heaters. Those small directional heaters/ and others, for spot comforts, relatively, DO use as much as 35% less of the KWH as instead of just letting the supplemental, last-staging electric furnace strip heaters from the central heat pumps... burn the duct from the a far-away (perhaps uninsulated ducted) blower to a needed comfort .
Better Utility Rates (choice)
Better Building (construction to insulation and maybe ERV's)
BETTER DISTRIBUTION / air rotation to SPOT COMFORT (also like all that mini-split heat pumps provide (subjectively) )
Tiny power-using HVAC - HW for desired space conditioning
Along the lines of BETTER DISTRIBUTION is the fact in Northern homes , floor return air designs air failing in the comforts found of the also better comfort and savings of forced air rotation with high returns (even better are the high return designs implemented when installing just air-cooling ducting to a previously all radiant heated home) .
Those who live in the north and have tracked this closely know that a high return on low continuous blower set ups in the winter and a little more cooling operation resulting in more dehumidification is really beneficial. now better ducting and register location can off set older designs that give up savings to say using little spot heaters, keeping a central forced air or inefficient radiant or convector system more so "off-line" and off the check book.
Simply choose your utility supplier contracting WITHOUT BROKERS and opt-out of community aggregations for free choices.
11/25/2013 8:31 PM
Yeah, I think some people are getting a little too drunk on their green theories to see reality.
11/25/2013 10:55 PM
In my junior high school library I found a book titled "Modern Inventions" that was published in 1903. One of those inventions was a parabolic reflector lined with a thousand mirrors and a steam boiler in the middle. It looked a lot like a modern radiotelescope. It had an output of about five horsepower. It was located in Arizona where there was plenty of sun.
Good Answers: 117
11/25/2013 10:58 PM
couple good solutions. Not really "out of the box" solutions though. I rather like the idea of blinds going up and down in response to a pre-programmed initiative. And Architects will NEVER trump Tract Developers who all demand ridge lines to be parallel with the road.
Still, all the ideas suck compared to trombe walls and heavy 10 inch insulation. Light pipes and fiber optics carrying light to the basement. I have a hundred more! Build your own windmill? Are you freakin' serious? I bet you sell windmills! I mean, build one to take of your own needs if you like (I tried to power an air compressor for awhile until I just gave up) , but to lock yourself into the grid is setting yourself up for the grid to suddenly abandon you for a much cheaper option. Contract? Good luck with that.
The utility companies I know of won't continue paying 48 cents for a kilowatt of power they have to sell for 10 cents, especially when the local subsidy runs out suddenly. Happening all over, so the free ride is coming to a stop.
So what is THIS guy sellling?
11/25/2013 11:18 PM
Evidently the're selling foot warmers that draw 150 watts, and saying they replace 1500 watt space heaters....I can top that....
USB powered foot warmer.....HA!
11/26/2013 6:16 AM
Just wait until they post the "Mobile Windmill" that mounts on your car roof so you generate electricity while you drive.
Anonymous Hero (2); Charlie Greenwood (1); JP76 (1); SolarEagle (2); tcmtech (1); Yusef1 (1)
