Previous in Blog: Slideshow: 3D Printing Shifts to End-Production Manufacturing   Next in Blog: Scenic Mexican Coastal Highway Collapses
20 comments
Solve This Pzzlr: Filling the Tank
Posted January 01, 2014 7:38 PM
From Neatorama:
Neatorama presents our collaboration with Pzzlr, a site where you can always find a riddle to exercise your brain. Can you solve this one? A tank has three taps. The first can fill the tank in 4 hours, the second can fill the tank in 2 hours and the third can empty the tank in 8 hours. How long will it take to fill the tank with all three taps operating at the same time? (You can assume the tank is empty to begin with). Think you know the answer? Find out at Pzzlr!
Re: Solve This Pzzlr: Filling the Tank
01/01/2014 8:54 PM
Long enough to have a few beers at lunch....
01/01/2014 9:16 PM
Close the drain valve, fool.
01/01/2014 10:58 PM
1-3/5 hours.
01/02/2014 8:36 AM
Let tank capacity = 80 units
tap 1 fills at 80/4 = 20 units/hr
tap 2fills at 80/2 = 40 units/hr
tap 3 empties at 80/8 = 10 units/hr.
Net flow = 20+40-10 = 50 units/hr.
80 units / 50 units per hour = 8/5 hours = 1 hr 36 mins
(but it only takes 80/60 = 1 hr 20 mins with drain tap closed)
Reply Good Answer (Score 4)
01/03/2014 12:09 PM
1/(1/2 + 1/4 - 1/8) hours.
01/03/2014 3:02 PM
Same equation and answer as #4, packaged more neatly. Both are right, and together (it would take both parts), they would satisfy the math teacher in me.
A+
01/03/2014 6:25 PM
I was always taught to write down/explain where the numbers/equations whatever came from. Maybe that's the difference between a maths and an applied science background. Jus' sayin'.
01/03/2014 8:44 PM
Yep, JohnDG, and without the work you showed, I'd have given credit, but only for about 40% of the value. Like I tell my students, if you don't show every step (including the logic behind the calculation) you MIGHT have the formula correct in the end, and even get the right answer. But IF you make a mistake, and you didn't show every step, I can't help you see WHERE you made the mistake, and thus help you learn from what is, after all, usually a boring exercise. And if you can't even get THAT value out of the exercise, I agree, you should probably have stayed in the field tending the crops.
And I'm a stickler for applied math, also, because I am by nature and avocation, if not by vocation (I'm and unpaid, volunteer, teacher and tutor, but I practice, and did practice, everything I teach), I am a scientist, specializing in Physics. But as I tell my students, God didn't JUST make physics work. He also created everything Biological and everything Chemical, and in the most marvelous and complex of systems, those that live, he used ALL the disciplines.
So my students have to be versed in the background of every discipline, and there are two glaring attributes of scientific skills that cut across all disciplines. Logical thinking (which led to your clear, discursive layout of the information behind the calculation) and Math Skill (which led to the clear layout of the formula itself, by Rixter).
Hence, high marks to both of you, together, but low to either alone. Just my two cents worth.
I think it was GOOD WORK! And fun to see.
01/09/2014 6:08 AM
Have been thinking this over for a while, and must disagree. If I, or either of my daughters, had given my solution and been given low marks in a test, I would be having some serious words with the teacher, or maybe their head of faculty.
01/09/2014 7:33 AM
My apologies. I should have proof-read my own statement more accurately, and then re-written it for clarity.
Let's see if this works. Were I giving partial credit, as I sometimes do (as a "doorway" to re-inforcing information already given, and only on quizzes or homework), and were the final answer wrong, <everything from "40% credit" onward goes here> ...
Since your answer was right, all marks for getting it, and elegantly.
My point was that when the answer is WRONG (a case I DID NOT make; again, my apologies for my lack of clarity or of accuracy), even when partial credit is available, an incomplete answer, since it precludes my being able to help the student who wished to do less work, and hope for a right answer, to see where they "erred from the path of righteousness" (nope, I'm not a Jesuit School Math teacher, either. I just liked the way that rang!) can't hope for much credit, even on quizzes and homework.
But, lest someone howl about the new math and feel-good, on tests there ain't NO partial credit. By the time a student is taking a test, it's either right or wrong, and they either get it, or they don't.
01/09/2014 8:44 AM
No problem - I can rest easy now .
01/03/2014 6:32 PM
Maybe so. But I understand #4.
01/03/2014 8:56 PM
So did I, Lyn. It was well laid out, and very straightforward. But JohnDG's addition was the "pocket kit" version of the knowledge, as opposed to Rixter's "take the parts out of the scrap box and lay them out for use" version. Both have their place. I would not REMEMBER JohnDG's answer, if the problem were real-life, and came up when I didn't have a computer handy. But I could remember Rixter's version, and reapply it, tweaked for my situation, remembering the logic JohnDG supplied.
I am reminded of a use I made of an obscure fact when I was answering a question on CTM-2 (PO2, but with a specialty, in the USN, NavSecGru) test.
The question was multiple choice, and had to do with the wavelength of a signal in the Lower Megahertz band. I don't remember exactly where it hit, but it was something that was multiple of 60 Hz, like 15 MHz, or 30Mhz, or 22.5 Mhz (yep, that one is, too!), and I couldn't for the life of me remember the formula for calculating it from the capacitive reactance given in the problem. But the resonant frequency was given.
But I DID remember that my High School Electronics teacher had once mentioned casually that 60 Hz had about a 3300 mile wavelength.
Since I also remembered how to work ratios, and ("60hz/3300mi" = "the giiven frequency/ one of the wavelengths given") I was able to apply algebraic manipulation, and come up with the right answer.
I'd like to say that after I finished the test I ran right out and brushed up on my reactance equations, but I haven't lied yet, and I don't want to start now.
Being able to remember the "pocket kit" version of the info pulled my fat out of the fire. After I passed the appropriate Mil-Lead test that week, I made 2nd Class Petty Officer in no time, and my wife and I were very pleased with the results.
So, both pieces of info are necessary from a dedicated teacher's point of view. I want my students to have full toolboxes, AND a well supplied pocket "emergency kit", when I get done with them.
01/09/2014 6:25 AM
For a full-bore algebraic equation, x/4 + x/2 - x/8 = 1 gives the results already obtained.
01/10/2014 1:27 PM
Here's a pedantic version to push one of my favorite tools: Dimensional Analysis
In High School Chemistry I learned Dimensional Analysis, which is almost
all I took away from the class, but perhaps one of the most useful and
reused lesson I learned. It is (arguably) one of the most valuable tools in any
engineering discipline.
By keeping the units of measure in the equation, and matching or cancelling
the units in the numerators and denominators, you ensure your answer is in
the correct units. Many an error has crept in when doing distance, temperature,
time calculations that would be eliminated using Dimensional Analysis.
Using it, I'd present the solution this way:
(multiplying by dimensionless unities (2/2) and (4/4) to get common denominators)
Flow 1: (1 tank / 4 hours) * (2/2)
= 2 tanks/8 hours
Flow 2: 1 (tank) / 2 (hours) * (4/4)
= 4 tanks /8 hours
Flow 3: 1 (tank) / 8 (hours)
flow 1 + flow 2 - flow 3 = (2 tanks/8 hours + 4 tanks/8 hours - 1 tank/8 hours)
= (2 + 4 - 1) tanks / 8 hours = 5 tanks / 8 hours
Since you want one tank full you have the equation
5 tanks/8 hours = 1 tank/ x hours
cross multiplying results in:
(5x)tank-hours = 8 tank-hours
5x = 8
x = 8/5
Q.E.D.
01/10/2014 2:52 PM
Gorgeous!!!
Prior to this, with all the math of studied, I've never heard of Dimensional Analysis. I'll have to take back all the kind things I've said through the years about my great math teachers. THIS is a TOOL. It looks especially helpful to new Algebra Students, trying to make the jump from simple numerical values, to variables with no intrinsic, recognizable place in the scheme of things. Tanks, in place of X, would greatly simplify that understanding, and looks like it would be a neat few steps to put into the intro to Algebra classes.
It looks simple enough, but to avoid missing anything, are there any books you know of that teach it?
Links (or references to books I might find via Amazon) would be most helpful.
01/10/2014 5:24 PM
"I've never heard of Dimensional Analysis" - where you bin, man? Big up and GA to RufusVS for bringing it up. I do it so automatically that I forget it has a name! Especially handy IMHO for stuff like energy calculations (Joules, Watts, time, mass, distance etc.).Even more important when mixed units are used (metric/imperial etc.).
01/10/2014 6:02 PM
Product of California Public High Schools, Class of 72. Learned a lot of technical stuff, took all the Science they offered (Physics in my Junior Year, Chem in my Sophomore Year, Bio in Freshman), finished all the available Math by the end of my Senior Year, took three years of hands on Electronics Design. Never one time heard the term Dimensional Analysis, nor saw a presentation that looked like this one. Took both Algebra and Algebra II, plus Geometry and Trigonometry. Calculus wasn't available. Joined the Navy as a Crypto Tech, when that required the highest scores possible on all entry testing (a 114 combination on Gen and Math testing). Spent the first 9 months out of boot camp in ET-A school (before moving on to the classified stuff), with the first 3 weeks supposed to be used for a Vector Analysis course, self-paced (finished it in one week, had to sit around for two weeks till my lock-step ET-A school course started). In ET-A school, the Navy started us on Nuclear Particle Theory with an emphasis on what moves electrons in an Atom, and why. Got into advance circuit theory in about week 5, but I'd already studied all of it in High School.
I say all that to say I'm neither stupid, nor ignorant (you didn't say I am, but I wanted it on the record), but I NEVER saw that presentation, nor heard that term. And I suspect that my math teachers would have been apoplectic had they seen anyone teach something that clearly could so simplify polynomials, and probably even matrix math, while eliminating the confusion of every first-term Algebra student I've ever met or taught, about the value of something so nebulous as "X".
So, I want to learn it. Now tell me where I can. And quit acting like the blow-hard bully in the school-yard, lording your knowledge over the guy who only asked how he could find answers to his questions.
Put up, or SHUT UP!
01/10/2014 6:55 PM
There's no magic to it (sorry if I sounded snotty). All yer do is make sure that on both sides of any equation, the dimensions are the same. Trivial example:
distance = speed x time
Say distance in miles, time in hours,
miles = (miles/hours) x hours
Hours "cancels out" on the right, and you're left with miles on both sides. Pretty good indication that it's correct.
You could use it to find the formula for speed, just from the units:
speed(mph ≡ miles/hours) =? Oh, yeah, miles divided by hours, so that's distance over time.
01/11/2014 8:32 AM
Thanks, got that one. I'd like to see how the process deals with a lot of other mathematical issues. I WANT to learn it.
And I apologize for being so prickly. I meant that to start, AND END, with "product of California Public Schools", but it hit a hot spot, because I grow ever so tired of the instructor who tells the students "the only silly question is the question not asked" and then berates the student for asking the question to which the student truly needs (and does not have/understand the answers already given). If it is asked, it needs to be asked. And most of the time, the one who is willing to ask it is not the only one who needs it answered, just the bravest (or the best target for the bullying instructor. One wonders WHY those take up teaching.).
JohnDG (6); lyn (2); micahd02 (7); Rixter (1); SolarEagle (1); Tornado (2)
