Technology is ever marching forward.
The latest development in upgraded tech is the growing prevalence of 4G
wireless networks. Augmenting or replacing your 3G will eventually be a
necessity, but how relevant is it today? Does your business need to invest in
4G, or can you safely ignore the standard for another year?
A Difference in Speeds
4G is a new standard, but really, telecommunications standards are all lumped
under the nebulous 3G and 4G banners. Some of the slowest 4G standards are
actually slower than some of the fastest 3G. When someone talks about the fast,
high end 4G, what they actually mean are the fastest 4G LTE
implementations.
Yes, 4G LTE system can be very fast. Real world testing shows
that the average download speed for a good 4G LTE implementation is easily much
faster than 3G from the same provider.
Upload speeds, however, are just as bad between both types of connection. 4G is
meant for those businesses that need to download large chunks of data on the
fly, from business Cloud storage or home base servers. You won't be uploading a
multimedia project from a 4G phone any faster than you will from a 3G device.
Situational Availability and Cost Issues
Currently the largest roadblock to 4G adoption is availability. Where do your
employees need to use 4G, 3G or any form of mobile data service? In your home
office, you'll have access to the office wireless network. You won't use a
smidge of your data plan regardless of speeds. When you head out on the road,
you may be surrounded by businesses offering their own free WiFi. It's not
always a good idea to use free signals for business data, of course, so using
your 4G in these areas would be a good idea. Get further away from the city
centers and the availability of 4G begins to drop. Far enough away and you may
not even receive 3G signal in some areas.
The other primary roadblock, as with any technology, is cost. 4G requires more bandwidth and technology on the part of the telecoms, which means they charge more for the use of that
hardware. At the same time, you need to invest in an upgraded mobile device to
even use the upgraded service. A new 4G phone for everyone who needs it in your
business is a significant expense. Or is it?
Business Mobility Uses
Think about what your business uses mobile devices for in day to day
life. As this infographic explains,
the three most common uses of a mobile device for business are emailing, SMS
and voice communications. What do these have in common? All three of them are
possible on low-end smartphones. For that matter, voice and SMS can be done on
old dumb phones. Email is trivial in terms of bandwidth for the vast majority
of cases; unless you're habitually downloading large email attachments, you're
going to be fine with a mid-range 3G network.
The primary benefit to businesses with 4G would be a switch from voice
transmission through phone carriers to voice over IP. VOIP can be significantly
clearer and more secure than traditional phone connections. However, VOIP has
limitations, including the limited availability of 4G at present.
The Value of Speed
Each business is different in how it weights the utility of a fast Internet
connection. Some will not have any use for an upgrade to 4G technology. Others
may be constantly showing off multimedia presentations on the fly, and will
find the increased speed of 4G to be a godsend.
So think about your business and what you do online. Anything that needs to be
done with a fast connection? If so, is it something that needs to be done
abroad, or can it be saved for a time when it can be done in the home office?
Generally speaking, a business WiFi connection is going to be faster than a
mobile connection, whether it's 3G or 4G.
While you're at it, think about the cost of the upgrade. Can your business
handle the increased bill for digital service? How many upgraded 4G devices
would you need to purchase? More importantly, how long before the increased
speed pulls its weight and its value outpaces the investment? If all your
employees do with 4G is stream Netflix while they wait for meetings, it's
certainly not a worthwhile investment.
4G is going to grow more widespread and cheaper over the next half decade. Some
businesses can benefit from investing in the change now. Most, however, will
find the expenses outweighs the added utility.
