What do composite
materials have in common with lunch? Plenty, if you enjoy a sandwich for your
mid-day meal. In material science, composites are made from two or more materials
with different physical or chemical properties. Combining these ingredients
forms a new substance with distinct, and hopefully superior, characteristics. Hungry
for more information? Let's step into the kitchen and make a few ham
sandwiches.
Building in Layers
Some people like open-faced
sandwiches because there's fewer calories in one slice of bread than in two.
Others prefer thicker sandwiches with three slices of bread, plenty of ham, and
even some cheese and mayonnaise. No matter how you make your sandwich, the
combination of layered ingredients produces a taste that's different than any one
ingredient alone. Yet you wouldn't add jelly to a ham and cheese on wheat. Jelly
provides flavor, of course, but it doesn't complement the other ingredients.
The texture, calorie count, and
nutritional value of sandwiches can differ, too. Does that mean a ham sandwich
is better than a slice of bread? Is a triple-decker sandwich better than an
open-faced one? The answer depends upon your application
requirements for lunch. The triple-decker may taste better and provide more
carbohydrates and protein, but the open-faced sandwich is probably the right
choice if consuming fewer calories is your goal. Still, it's unlikely you'd
want to add jelly to either sandwich.
Sandwiches vs. Stews
If ordering lunch is this
challenging, how can buyers select the right composite materials? Knowing your
application requirements is important, but understanding this sandwich-like structure
helps. Still, some buyers think that all composites have a stew-like structure
instead. These so-called matrix materials
do resemble a stew of sorts, perhaps one with bits of beef and potatoes
"embedded" in a hearty broth. Yet just as stews can be served for lunch,
they're not the only items on the menu.
Sandwich-like composites satisfy
the appetites of applications that require thermal
insulation, acoustic insulation, and/or vibration dampening. These
composites aren't built with food, but consist of foams, fillers or barrier
materials, and adhesives. Just as smoked ham tastes different than honey ham,
foams made of ether, ester, and Triamid have different material properties. Just
as you can make a sandwich with wheat or rye bread and mayo or mustard, you can
choose different barriers, filler, and adhesives.
Meeting (Not Eating)
Application Requirements
So what's the "secret recipe" for
building the perfect sandwich-like composite for your insulation application? Balancing
all of your requirements is critical. Just as you wouldn't add jelly to a ham
and cheese sandwich, it's essential to avoid epoxy adhesives if you need to
meet requirements for flame, smoke, and toxicity (FST). Today, buyers in
industries such as mass transit and aerospace often choose water-based
adhesives instead of products that use toluene or heavy metals.
Striking a balance between
strength, toxicity, and the use of "green" materials can be difficult, but it's
not the only challenge to overcome. What types of foam can you use? How many
foam layers do you need? Do the barrier materials need to have a felt-like
appearance, such as the headliner in a car? Do you need to bond the composite
to a metal substrate and, if so, what is the metal's thickness? If the prospect
of designing a ham sandwich seems more appetizing, you're not alone.
How Can We Help
You?
Do you need to source composite
materials for cars, tractors, or military transports? How about thermal
insulation for engine compartments or acoustic insulation for the cabs of mobile
specialty vehicles? Let's talk about how custom
composites can meet your application requirements. For 25 years, Elasto Proxy
has been solving challenges and providing solutions.
About the Author: Doug Sharpe is the President of Elasto Proxy, Inc. (Boisbriand, Quebec, Canada), supplier of sealing solutions and custom-fabricated rubber and plastic parts to a variety of industries, including green power, automotive, aerospace, and defense.
