Previous in Blog: States Battle Feds in Power War   Next in Blog: Future Energy Sources 3.1.4 Hydrogen from Coal
2 comments
Future Energy Sources 3.1.3 Hydrogen from Oil
Posted July 08, 2007 5:58 AM by masu
Hydrogen in the form of H2 is highly reactive and will explosively combust in air at concentrations as low as 4% V/V. As a result H2 is only found on Earth in its elemental form as traces in the atmosphere at concentrations of around 500 parts per billion. If we were to replace all fossil fuels with H2 the annual production of H2 would need to be around 3.5 Tg (3.5 billion tonnes) per year which is slightly over twice the amount of H2 in the atmosphere. Not only does the H2 economy need vast quantities of H2 but the production method needs to be efficient and pollution free. It's no good using H2 as a fuel to reduce greenhouse gases if the production of the H2 produces more than the fossil fuels do in the first place.
There are currently no process that converts liquid fossil fuels into H2 on a large scale commercial basis, however, H2 is generated from natural gas using a process called steam reforming. The process involves combining natural gas and steam at temperatures between 700-1,100° C forming H2 and carbon monoxide CO. The CO is then combined with water at around 130° C producing more H2 and carbon dioxide CO2. The equations for each of the reactions is:
CH4 + H2O → 3H2 + CO -191.7 kJmol-1
CO + H2O → H2 + CO2 + 40.4 kJmol-1
The whole process is about 80% efficient but it still produces CO2 and the more carbon in the hydrocarbon the more CO2 you end up with at the end of the process.
Most of the H2 currently produced is used to either improve the characteristics of existing fossil fuels or create ammonia NH3 which is then used to create things like fertilizer and explosives. If H2 produced this way were to be used as part of the hydrogen economy there are several problems that first need to be overcome.
  1. If the CO2 is released into the atmosphere as it currently is, we end up being worse off that if we used the fossil fuel directly. For the H2 to have any benefit the CO2 needs to be collected and stored infinitely using something like carbon sequestration.
  2. Using fossil fuels to generate H2 for the hydrogen economy would actually increase our dependence on fossil fuels not reduce it and only make things worse than they currently are.
  3. The current scale of H2 production is less than 1.5% of the sort of production that would be needed to supply H2 to a pure hydrogen fueled economy.
For the hydrogen economy to work there needs to be an economically viable and pollution free source of H2 and the use of liquid fossil fuels as that source raises several questions:
  1. If using oil to create H2 is only going to increase our consumption and dependence on it, is it worth investing in the technology at all?
  2. Since the concept is dependant on the development of a viable carbon sequestration system is it worth working on before carbon sequestration is proven practical?
  3. Can we expand the process by a factor of around 70 fold to cover our current fossil fuel consumption?
So, what do you think about extracting H2 from oil?
Re: Future Energy Sources 3.1.3 Hydrogen from Oil
07/09/2007 9:49 AM
This looks inherently like a break-even process at best. That is a net, CH4 + 2O2 = CO2 + 2H2O, exclusive of whatever is used to make the steam and heat the process. The only reason to do these processes starting from a hydrocarbon is if one need H2 for an industrial chemical use.
To get hydrogen, free of CO2 production, I think you have to split water, using a carbon free heat source to get the 700-1,100o C process temperatures. Personally, I favor a nuclear heat supply and the sulphur-iodine process described in the link below.
http://www.world-nuclear.org/sym/2003/pdf/schultz.pdf
An associate of mine likes heliostat based heating.
Regarding hydrogen hazards, a clarification. H2 in air has a flammability range of from 4 to 72%. These limits are frequently referred to as the LFL and UFL. The explosive range is 18 to 59%, i.e. LEL and UEL. Outside this narrower range you get deflagration or a fire ball. Inside you can get either a deflagration or a detonation, depending on geometry. Detonation or explosion is by definition when the flame front has reached a sonic velocity, creating a blast wave. You need some degree of confinement for the velocity to reach sonic. In either case, a respect and proper design for the hazard is required.
"For a successful technology, reality must take precedence over public relations, for nature cannot be fooled." -Richard Feynman
07/09/2007 10:11 AM
Hi N&P,
Thanks for the clarification it's important to get the details correct and I should have been more specific in my original post.
You might be interested in: Fuels and Fuel Products, Gas Sensors, Fuel Testers
