While we have become highly dependent on oil to supply us with energy, the most abundant fossil fuel is coal and while nobody knows exactly how much coal there is, it could supply all our energy needs for at least half a century and probably considerably longer. However, coal is by no means a clean fuel and produces more CO2, SO2 and NOX than other fossil fuels for a given energy output.
Coal mining operation can also produce large quantities of sulfuric acid and methane which then leak into the environment causing considerable damage and increasing the green house effect. Fires in abandoned coal mines are also a real problem. The carbon monoxides that leak from these underground fires is colourless, odorless and tasteless making it a silent invisible killer and subsidence can cause catastrophic damage to structures on the surface. Extinguishing these fires is extremely hazardous and trying to extinguish the fire with water usually results in massive explosion that only causes more damage and makes the problem worse. As a result many coal mine fires are sealed and left to burn unchecked.
The abundance of coal makes it hard to overlook and provided the byproducts can be prevented from being released into the atmosphere it would be an ideal source of hydrogen for the hydrogen economy.
In England in the 1790s Coal gas was the first commercially produced gas that was made from coal via a process called destructive distillation which produced a mixture of the following gases:
- Hydrogen 50%
- Methane 35%
- Carbon Monoxide 10%
- Ethylene 5%
The byproducts of the process were coke, coal tar, sulphur and ammonia which can all be utilized.
However, coal gas can be dangerous and with the exception of South Africa coal gas has been replaced with natural gas. There are several reasons for replacing coal gas but the two most relevant are to do with safety. The carbon monoxide makes it toxic and the only component that burns with a visible flame is the ethylene.
Syngas, the modern equivalent of coal gas, contains varying ratios of hydrogen and carbon monoxide and can now be produced from coal as well as oil and natural gas. The carbon dioxide component can then be utilized in other chemical reactions or combined with water at to produce carbon dioxide and more hydrogen.
Regardless of the process you are still left with sulphur, carbon and nitrogen compounds that need to be prevented from escaping into the atmosphere, otherwise we end up creating even more pollution and green house gases than burning the coal directly.
You can read more on coal gasification and the extraction of hydrogen from coal by following these links:
Extracting hydrogen from coal in the quantities required for a viable hydrogen economy is yet to be proven to be commercially and environmentally viable and there are questions that need to be answered:
- Are we just delaying the inevitable? Considering the large scale production of hydrogen from coal will deplete the reserves of coal faster, is it worth developing technology that has a limited supply of raw materials?
- The viability of hydrogen production from coal is dependent on there being a viable method of handling the waste products of CO2 SO2 and NOX. Considering this, is it reasonable to expect the process to ever be environmentally friendly and is it possible to indefinitely contain all the unwanted byproducts of the process.
