Previous in Blog: Why Is There Plastic In My Toothpaste?   Next in Blog: Will 3D Printing Reduce or Increase Plastic Waste?
ETS Engineering Students Build Baja Dune Buggy
Posted November 12, 2014 10:19 AM by Doug Sharpe
École de technologie supérieure (ÉTS), a public engineering school in Montreal, awards the most engineering diplomas in Quebec and is Canada's third largest engineering school. Founded in 1974, ETS is part of the Université du Québec system and esteemed for its emphasis on cooperative education. Each year, students combine classroom instruction with hands-on experience such as participation in international competitions. In the process, ETS students work with local companies.
Since 2008, Elasto Proxy has custom-fabricated rubber and plastic parts for student-built vehicles. This year's project, a yellow dune buggy, took fifth place in a competition among engineering schools from Canada and the United States. Powered by a modified 10-hp Briggs & Stratton snow blower engine, the small two-wheel drive specialty vehicle is capable of achieving speeds of 60 to 70 km/hr. Although the students who visited us didn't drive quite that fast around our parking lot, the Elasto Proxy employees who tried the dune buggy had a great time, as you can see from these photos on our Facebook page.
Custom Fabrication with Water Jet Cutting
Elasto Proxy custom-fabricated two main types of parts for the Baja ETS dune buggy: HDPE plastic parts for the vehicle's body, and silicone foam insulation for the engine compartment. Using our water jet cutter, we made fast, clean cuts in a variety of sizes. Unlike die cutting, water jet cutting eliminates tooling costs and creates smooth edges. Water jet cutting is ideal for polymers and elastomers, but also works well with the thermal and acoustic insulation used in engine bays.
To produce durable plastic parts for the dune buggy's body, Elasto Proxy cut sheets of yellow HDPE plastic. Known for its large strength-to-weight ratio, high-density polyethylene (HDPE) is a thermoplastic that's used in products ranging from fuel tanks and pipes to bumpers and ballistic plates. At our custom fabrication facility here in Boisbriand, Quebec, our skilled production team crafted HDPE auto parts such as the fender, roof, scoop, and 7' x 20" undercarriage component.
Custom Insulation and Specialty Seals
Water jet cutting also allowed Elasto Proxy to create a heat insulation barrier from silicone foam sheets. Snow blower engines are designed for cold weather environments, of course, but the powerplant that the ETS students modified generates plenty of heat. Without a thermal barrier, heat from the tuned-up engine could cause the transmission to overheat - and sideline the dune buggy during a race. Silicone, a heat-resistant material with an excellent service life, was the right choice for the heat shield.
In addition to water jet cutting, Elasto Proxy applied its expertise in cold bonding, a splicing technique that uses a quick-setting adhesive to join precise, angled parts without tooling costs. The rubber seal that we cold bonded for the dune buggy's transmission was produced from an EPDM U-channel. A synthetic elastomer, EPDM offers outstanding heat resistance. EPDM rubber's resistance to ozone and weather also make it a popular choice for the door, window, trunk, and hood seals used on cars.
Join The Conversation
As engineers, have you had the opportunity to work with students on projects such as the ETS Baja Dune Buggy? When you were an engineering student yourself, did you participate in projects like this? What do you remember most, and how did what you learned support both your classroom education and subsequent professional career?
Thanks for reading my latest CR4 blog entry. I look forward to hearing from you.
About the Author: Doug Sharpe is the President of Elasto Proxy, Inc. (Boisbriand, Quebec, Canada), supplier of sealing solutions and custom-fabricated rubber and plastic parts to a variety of industries, including automotive and mobile specialty vehicles.
