Previous in Blog: Make It or Buy It? Part 2: Opportunity Costs   Next in Blog: ETS Engineering Students Build Baja Dune Buggy
23 comments
Why Is There Plastic In My Toothpaste?
Posted October 28, 2014 11:21 AM by Doug Sharpe
"I've been seeing these blue particles flush out of patients' gums for several months now," wrote Trish Walraven, a dental hygienist from Texas. So she told a co-worker, consulted with other dental hygienists across the United States and Canada, and identified the source of the mysterious plastic microbeads. In a March 4, 2014 blog entry called Crest Toothpaste Embeds Plastic in Our Gums, Walravern described what she learned - and called the makers of Crest "sneaky".
Active Ingredients and Polyethyelene Microbeads
Proctor & Gamble (P&G) doesn't list "polyethyelene microbeads" as an ingredient on tubes of Crest toothpaste. Polyetheylene is the world's most commonly used plastic, but it isn't an active ingredient like the potassium nitrate or sodium fluoride found in brands like Crest Sensi-Relief. Instead, Crest adds polyetheyene beads "to provide color". Polyethyelene (PE) has abrasive properties, but it's not used to clean teeth or help disperse anti-plaque and anti-cavity ingredients.
Regardless of whether PE plastic is an active or inactive ingredient, Walraven calls its use in toothpaste "completely unacceptable". As a dental hygienist, she's concerned about patient health. The embedded plastic beads that hygienists are finding threaten the gingival sulcus, a shallow channel where diseases such as gingivitis begin. "When you have hundreds of pieces of plastic being scrubbed into your gums every day that are smaller than even a millimeter," Walraven says, "many of them are getting trapped".
FDA, ADA, and P&G Responses
Although Walraven is careful to state "I am not saying that polyethylene is causing gum problems", other critics are bolder. In a September 18, 2014 Washington Post article entitled Why dentists are speaking out about the plastic beads in your toothpaste, Arizona dentist Justin Phillip described the link between embedded plastic in the sulcus, bacterial growth, and periodontal disease. The on-line article also explains that polyethylene microspheres are FDA-approved for use in personal care products.
For its part, the American Dental Association (ADA) Council on Scientific Affairs continues to endorse Crest products. The council has the authority to withdraw the ADA Seal from toothpastes with plastic beads, but cities a lack of clinical evidence that disproves their safety. Crest also maintains that PE beads are safe; however, P&G recently announced that all microbeads will be removed from Crest products by March 2016. The reason, the company explained, is "changing consumer and dental preferences."
Are You Concerned About Microplastics?
As the co-founder and co-owner of a 25-year old company that custom-fabricates rubber and plastic parts, I've read my share of stories about synthetic polymers. Some critics claim that all petroleum-based plastics are "bad" because they're made of non-renewable resources. Others examine chemicals such phalates, plasticizers used in food packaging and polyvinyl (PVC) flooring, and cite studies about health problems such as endocrine disruption.
Naturally, some articles are more convincing than others - especially when you consider the source. For example, researchers from McGill University here in Montreal recently announced that plastic micro beads were found at the bottom of the St. Lawrence River. These microplastics are used not just in toothpastes, but also in face scrubs and shower gels. According to biologist Anthony Ricciardi, plastic microbeads could eventually enter the food chain.
Join the Conversation
As engineers, are you concerned about the use of plastic microbeads in toothpaste? Will you continue to buy personal care products that contain microplastics, or will you avoid them because of concerns about your health and the environment? Thanks for reading my latest CR4 blog entry. I look forward to your comments, and to what I hope will be a lively discussion.
About the Author: Doug Sharpe is the President of Elasto Proxy, Inc. (Boisbriand, Quebec, Canada), supplier of sealing solutions and custom-fabricated rubber and plastic parts to a variety of industries, including medical equipment.
Re: Why Is There Plastic In My Toothpaste?
10/28/2014 11:59 AM
Why stop there? The list is long.
How about Teflon. Food processing equipment has Teflon coated items and Teflon materials. Such as screws (augers) and internal walls in direct contact with food. Or as packing on seals. All USDA-3A approved, I believe also FDA approved.
The problem with this is that these Teflon coatings wear and the Teflon particles go into the foods stuffs.
Now Teflon itself is not directly linked to cancer, but has been found to be the source of other health ailments.
10/28/2014 2:09 PM
Thanks for your comment phoenix911. Yes, there is a specific type of Teflon that qualifies for food contact under FDA regulations. There are also PTFE compounds that do not. So this is a good example of why it's important to choose a supplier who can help with material selection and not just recommend a "PTFE seal". As part of that process, the supplier needs to consider the entire application environment. For example, will the seal come into contact with hydraulic fluids, lubricants, and cleaning agents? If so, which ones? And how will the seal react?
I'm using seals because it's an example I'm familiar with, but your point about Teflon is well-taken.
10/28/2014 2:21 PM
Sorry about the derailment
On all material for food contact, (Rubber, polymer, metals, etc....) there should be an approval letter from the 3A accreditations readily available.
On Teflon coated equipment even back in the 90's some myself as well as some customers avoided this coating. Even though there isn't solid proof of the effects of this Teflon, it is something that I myself would avoid when designing food process equipment.
Good Answers: 109
10/28/2014 5:25 PM
I do not like the idea of adding ingredients to toothpaste that serve no purpose other than to add colour. And yes many food products are coloured and there exists a whole industry that thrive on manufacturing and selling food dyes. Most are inert and do not present any problems. Adding plastic PE to toothpaste seems counter intuitive. As it enters the environment are some of the bottom feeding organisms affected in any way? Are there studies that prove or disprove affects? Why are people brushing their teeth with PE beads and then having the hygienist have to clean or flush them out? Does it cause an irritation if they are left in the gums? I brush my teeth to clean them of debris. I hate to think that between visits, I get a build up of PE in my gums.
10/28/2014 10:44 PM
"As it enters the environment are some of the bottom feeding organisms affected in any way?"
Nope! It has been found that lawyers thrive on this sort of stuff.
Good Answers: 109
10/28/2014 11:26 PM
Made my day.
Canada - Member - New Member
Good Answers: 11
10/29/2014 9:58 AM
In fact, there is concern regarding polymer micro particles in the environment and entering the food chain.
No need to be a lawyer, just sensible caution...
''What the hell has my a** got to do with magic?" Don Quixote
10/29/2014 10:25 AM
It would be identifying the polymer, and if there is any type of chemical leaching into the food stuffs
Good Answers: 11
10/29/2014 1:39 PM
A recent report for the Saint Lawrence river stated that microparticles are accumulating in sediments and are not being washed out in the ocean.
They enter the food chain from plankton and up to fish and us.
An useless risk so to have cosmetic color beads in toothpaste.
The argument that no harm has been proven is fallacious at best, on the contrary the proof that no risk exists should be the burden of the industry.
Good Answers: 92
10/30/2014 10:53 PM
This is a little bit aside, but with a density range from 0.86 to 0.975 for all the different types of polyethylene most of them aren't going to wind up in sediments, unless drawn down from the shore (although there could be a filler to adjust the density higher). I will venture a guess that hand soaps contribute much more than toothpaste.
Good Answers: 11
11/01/2014 9:19 AM
Look at the McGill University report cited in the original post.
Good Answers: 25
10/29/2014 7:17 AM
My question is does these particles get digested in human system or they get deposited in human body?. As such any non food particle will be dangerous for human body as it can create any sort of problem in system such as kidney, stomach, heart etc. Now a days medical treatment all around the world is very expensive so it is people who are real victims. I strongly suggest that such presence of foreign particle should be banned.
10/29/2014 10:25 AM
Personally, I can't see the added value of including a component that serves no functional purpose. In the auto industry, that is an absolute no-no, although I expect a few responses to the contrary based on opinons about available options in some cars.
Do we know if Crest is the only toothpaste that has these micro-beads. If so, use the best tool in a free market society - stop buying it. There are alternatives. I do understand that if the component is not listed on the packaging, then it is impossible to determine which toothpastes (and other food products) have the micro-beads, but the point is still valid with some research.
You can lead a horse to water...
Good Answers: 32
10/29/2014 10:34 AM
I recently heard that there is an effort to have the plastic beads removed due to their affect on the environment (aquatic life) as well as their questionable affect on gum health. http://www.foodsafetynews.com/2014/09/crests-parent-company-says-microbeads-in-toothpaste-will-be-removed/#.VFD6-leRF5c
Spinco
10/29/2014 11:00 AM
My preference is for the stuff with hydrogen peroxide and baking soda. They usually add some pumice for additional abrasive. Ever since I've been using it, my dentist has not been giving me the "lecture" about teeth cleaning specifically tartar and plaque build ups. I happen to use the Colgate brand but I'm sure there are other brands with similar formulation. I never liked the 'gel' style toothpastes. Maybe now I know why.
10/29/2014 11:32 AM
back to the basics.
Good Answers: 32
10/29/2014 1:12 PM
On occasion, I will take some baking soda and some peroxide, mix them in a glass and brush with the paste. Gives a very clean and refreshing feel after you rinse it out.
Spinco
Good Answers: 69
10/31/2014 9:30 AM
Despite all researches, I've found myself that the tooth paste with micro-beads, leaves a cleaner feel of my teeth, I can feel the surface smooth as glass when licking them. I changed to another brand but didn't like it at all and went back to Crest.
It does have an abrasive effect, without a doubt, and people likes it so much that Crest surely acquired a huge stock of the stuff, so I think that if pushed real hard, the sooner it could be withdrawn, would be a couple of years.
11/04/2014 11:05 PM
Shouldn't use floride toothpaste. Floride is dangerous.
11/04/2014 11:12 PM
You poor fool.
DO try to keep up.
"Floride" is not a word.
This thread is not about fluoride, either.
Good Answers: 11
11/04/2014 11:33 PM
Hehe!
Should ban NaCl too, chlorine is dangerous!
11/05/2014 12:03 AM
No, only clorine is dangerous.
Good Answers: 11
11/05/2014 12:24 AM
Glad not to be alone making off topic jokes!
Clorine is mainly bad for the brain, would you agree it doesn't react to anything else?
Reply to Blog Entry 23 comments
Brave Sir Robin (1); Data Management (1); David K (1); Doug Sharpe (1); gigaconcept.com (5); JNB (1); kevinm (2); lyn (2); phoenix911 (4); Spinco (2); suresh sharma (1); tcmtech (1); Yahlasit (1)
