Previous in Blog: Fuel Cells - Energy Empowering Technology   Next in Blog: Two Fuels, One Algae
2 comments
Microgrids – Nation’s Future towards Clean Energy
Posted March 01, 2015 12:00 AM by sanasyed24
A microgrid is an integrated energy system with control capability of operating independently or in parallel with an existing utility grid, managing distributed energy resources and interconnected loads. These localized grids have a great impact in transforming the electric grid of a nation because of their ability to help grid mitigate and strengthen grid flexibility.
Working of Microgrids
An electrical grid allow us to use electronic devices, electrical appliances and heating/cooling systems by connecting homes, buildings and businesses to central power sources. A drawback due to an interconnected system is that everyone gets affected if any part of the grid needs repair. This drawback is eliminated with a microgrid. Generally, a microgrid is connected to a grid for operation, but most significantly, it can operate independently using local energy generation in case of power crisis like outages or storms. Distributed batteries, generators or renewable resources like solar panels provide power to a microgrid. It can run indefinitely depending on its requirements and how fuel is provided.
Same voltage level is maintained of a microgrid as the main grid by connecting it at a common coupling point. A microgrid can be separated from a main grid manually or automatically by a switch to work independently.
Why and When to Use a Microgrid?
A microgrid not only improves efficiency and reliability, but also reduce costs required to extend or fix over capacity transmission and distribution system. It can eliminate the issues of fluctuating gas and electric prices and provide technological innovation by distributed generation, control grid stability, demand response and renewable resources. It allows our communities to be more environment friendly and energy independent.
A microgrid could be used for various reasons. There are certain factors that determine the use of a microgrid instead of grid extension. These factors include the cost, size of a community, terrain, environment, and distance from the existing grid.
Advantages of Microgrids
While the main grid is down, a microgrid has the ability to work independently, strengthen grid flexibility and help mitigating grid disturbances. It also offers faster system recovery and response by functioning as a grid resource. Microgrid supports electric grid efficiency and flexibility by enabling integration of distributed energy resources, such as energy storage, power and heat and renewable energy resources, such as wind and solar. Furthermore, efficiency of electric utility system increases by the use of local energy sources that help in reducing transmission and distribution losses.
References
http://energy.gov/articles/how-microgrids-work
http://www.districtenergy.org/assets/pdfs/03AnnualConference/Monday-A/A5.2SANCHEZIvette-Sanchez-IDEA.pdf
http://energy.gov/oe/services/technology-development/smart-grid/role-microgrids-helping-advance-nation-s-energy-system
http://www2.ee.ic.ac.uk/daniel.mewton09/yr2proj/whymicrogrid.htm
image - http://upload.wikimedia.org/wikipedia/commons/d/d3/Microgrid.jpg
Re: Microgrids – Nation’s Future towards Clean Energy
03/01/2015 11:06 PM
A new name on a very old concept.
In fact, for many paper mills, they only consumed electric power if the plant was shut-down or in the process of re-starting. Once up and running, most paper mills produced more electricity than they consumed.
As for grid reliability, microgrids really don't improve that unless you happen to be 'inside the moat' when the grid goes down. If your microgrid is able to produce more power than you consume, then in theory your capacity can help the regional operator with peak shaving. And you've designed in too much capacity ($$).
The way to harden our electrical power distribution infrastructure will be to 'de-couple' various regions with HVDC links between the regions so that if a failure occurs in one area, you don't get cascading failures from the linkages of all these synchronous machines tied together. It is much easier to control the flow of power between regions when it is DC.
Good Answers: 102
03/02/2015 2:06 AM
GA.
A new name for how it all started really.
Before interconnected grids there were ( and here there still are) independent generating and distribution systems.
Yes, HVDC transmission is looking very attractive.
